Old 01-10-2022, 08:39 AM   #1
manwichmakesameal
Drives: 2020 86, 2023 GR86, 2002 IS300
Fuel pump sound when car is off
So, I have a 2020 86 and every once in a while when I go into my garage I hear a sound that sounds very much like a fuel pump running in the rear of the car on the passenger side. Does anyone else have this happen? It only does it once in a while and it *does* stop on it's own.
manwichmakesameal is offline   Reply With Quote
Old 01-10-2022, 08:45 AM   #2
Check 2020 Owner's Manual page 15
Approximately five to ten hours after the engine is turned off, you may hear
sound coming from under the vehicle for several minutes. This is the sound
of a fuel evaporation leakage check and, it does not indicate a malfunction.
The Following 4 Users Say Thank You to Dadhawk For This Useful Post:
bcj (01-12-2022), humfrz (01-12-2022), Tcoat (01-10-2022), Ultramaroon (01-10-2022)
Old 01-10-2022, 09:14 AM   #3
manwichmakesameal
Awesome! That explains it. Thanks.
The Following User Says Thank You to manwichmakesameal For This Useful Post:
Dadhawk (01-10-2022)
Old 01-10-2022, 10:24 PM   #4
2020BRZtS
2020BRZtS's Avatar
Drives: '20 BRZ tS (15/300) / '09 Scion tC
It will really freak you out when it's on jack stands and you are under it.
2020BRZtS is offline   Reply With Quote
The Following 2 Users Say Thank You to 2020BRZtS For This Useful Post:
Dadhawk (01-11-2022), pope (01-14-2022)
Old 01-12-2022, 02:04 AM   #5
That was nice of you -
Dadhawk (01-12-2022)
What Power Level for Upgraded Fuel Pump - Pump Gas DarkPira7e Engine, Exhaust, Transmission 10 08-02-2020 11:07 AM
Fuel pump squeak sound dampener? radroach Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 19 08-01-2018 10:25 PM
Clicking / tapping sound + fuel pump noise + clutch grinding Mikeez Issues | Warranty | Recalls / TSB 11 04-27-2015 12:19 AM
Sound shield over fuel pump? Pacific Auto Engine, Exhaust, Transmission 1 08-20-2013 05:27 AM
2013 FRS fuel pump sound MosesFRS Issues | Warranty | Recalls / TSB 9 02-23-2013 10:01 AM
