Old 04-08-2020, 07:01 PM   #1
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
What Power Level for Upgraded Fuel Pump - Pump Gas
As the title states, at what point were you forced to upgrade your fuel pump FOR PUMP GAS? I'm planning on 350-400whp on my rebuild and made about 330whp and 250wtq on 93 with 440cc injectors and stock pump on stock engine.
I'm lowering compression to 10:1 so I'm expecting that it'll take more fuel to get me there than before.
If you're going to comment, please don't give reason without evidence; I do not want to tamper with the stock fuel system if I can avoid it.
Let me know if you changed because of fuel pressure drop, or at the advisory of your tuner.
Please also include your octane rating and fuel injector size.
We will be dyno tuning the car so it's not like I'll run at risk and the tuner will wait for a datalog, we'll monitor rail pressure regardless.
Thank you in advance!
Old 04-09-2020, 09:20 AM   #2
Fred E
Drives: WRB BRZ
I made just shy of 400 whp on E85 with the stock fuel pump + 700cc injectors. E85 inherently requires a lot more fuel, so even with the compression drop I don't expect you to need an upgraded fuel pump running exclusively pump gas. If your tuner does notice insufficient fuel pressure in datalogs, it's a fairly quick process to install a fuel pump.
I'm not sure if 440cc injectors would continue to be sufficient given the increased fuel demand, but I don't know enough to be certain.
Fred E is offline   Reply With Quote
Old 04-09-2020, 08:34 PM   #3
Ashikabi
Ashikabi's Avatar
400hp on e85 sounds pretty far north of where tuners like you to replace your pump. I would certainly consider it. It's not hard
Old 07-28-2020, 06:53 PM   #4
DarkPira7e
DarkPira7e's Avatar
Bumping this to see if I can get more input. This will be specific to pump gas, no e85; somehow we don't have e85 in Vermont. I know, go figure.
I will obviously be upgrading my injectors, probably to ID1050X for their tunability
Old 07-28-2020, 09:49 PM   #5
Ashikabi
Ashikabi's Avatar
Well if the guy above made 400 on e85 then you should be fine on pump gas.
A new pump isn't exactly expensive.
Old 07-28-2020, 09:59 PM   #6
DarkPira7e
DarkPira7e's Avatar
It's not the expense, it's that I don't want to complicate something that has been working. I'll accept limiting my power before I replace the fuel pump. I'm just a stubborn ass
Old 07-28-2020, 10:01 PM   #7
Ashikabi
Ashikabi's Avatar
So you're willing to modify anything else to make the power you desire but not the fuel pump?
Old 07-28-2020, 10:27 PM   #8
DarkPira7e
DarkPira7e's Avatar
Not anything else. I won't replace my crash bar, I won't replace stock style struts with coilovers for clearance with larger wheels, I won't replace my throttle body or intake manifold, I won't remove my a/c components, I won't get slim fans. I'm sure there's more I'm not thinking of.
Aside getting a new engine block, (which is not something I'm doing because bi just wanted to) the only things I've changed are engine mounts, and the fuel injectors. Injectors are easily accessed and replaced within minutes, and mounts only cause noise.
I'm not disagreeing that I'm crazy. But I've replaced fuel pumps in several cars that had aftermarket pumps. I've had to disfigure in-tank pumps to accommodate the new pumps.
I just have had the worst times with aftermarket fuel systems and will avoid modifying -anything- I don't have to.
If I can only run 300whp, I'm happy with that. If I make it to 400, that's good too. The purpose of this inquiry was to help ungrey an area there there's not a lot of evidence with that's posted on this forum.
Is there such an issue with not replacing things that don't need to be replaced that aren't easily accessible? I'm replacing all of my pulleys with OEM replacements, I am replacing the serpentine belt, I am having my heads hot tanked and cleaned, I am replacing my plugs for the 3rd time in 500 miles, I am replacing all 4 OCVs. This build is about quality and longevity before power. But if we can document generally on pump gas where the stock fuel pump can't keep up, I'd like to capture that data.
My plan is as follows, whether I get responses or not-
If I run out of fuel, I'll document it here
If I don't run out of fuel, I'll document it here
I'm not trying to come across as argumentative; I just want you to have a thorough understanding of what my goal is and hopefully it'll help you see why I'm leaving the fuel pump alone. And to help others who may search "BRZ fuel pump limit" in Google, to have their answer quickly and passively.
Old 07-28-2020, 10:37 PM   #9
Ashikabi
Ashikabi's Avatar
You know there are aftermarket pumps that fit the stock hanger right? I have a DW65C and it for just fine. There are higher flow ones too. Not difficult to replace either.
Good luck on your journey. I hope you find the information you're looking for
Old 07-29-2020, 08:11 AM   #10
Grady
Grady's Avatar
I only made 160whp on stock pump stock injectors.
Old 08-02-2020, 10:07 AM   #11
jflogerzi
jflogerzi's Avatar
Just do pump and injectors now. Peace of mind and you know you will have plenty of headroom.
2013 Series 10 FRS #553
Upgraded fuel pump with stock injectors? Fizz Forced Induction 2 07-22-2019 07:18 AM
Wtt upgraded fuel pump & injectors misooscar Brakes, Suspension, Chassis 0 04-09-2015 04:35 PM
Deatschwerks Holiday Power Package Sale!! Fuel pump and injector bundle! Moddiction Forced Induction 0 12-03-2013 05:46 PM
FS: Agency Power Header, DW Injectors, DW Fuel Pump, 500hp intercooler Dustin@Dynosty Engine, Exhaust, Bolt-Ons 11 09-23-2013 10:49 AM
So what horsepower level are people needing to upgrade the injectors/pump? seven Forced Induction 24 01-01-2013 11:28 PM
