Old 11-22-2021, 10:50 PM   #15
dynarun55
Drives: 2015 midnight blue limited edition.
Originally Posted by Calum View Post
Does that hold true for 91 octane?
FWIW, mine was just 93 octane pump gas. I even install JR engine oil cooler at the same time as the JRSC. And mine let go.
Sent from my Pixel 3 using Tapatalk
dynarun55 is offline   Reply With Quote
The Following User Says Thank You to dynarun55 For This Useful Post:
Calum (11-25-2021)
Old 11-23-2021, 01:02 AM   #16
alphasaur
friendly
Drives: 17' 86
Originally Posted by Xero-Limit View Post
Every shop is different, but we generally do 3k flat rate for R&R of the motor and building the motor. If the car is not here, then it is 2k for long block assembly, 1500 for short block assembly. We're one of the very few shops that will do an actual FA20 long block and not just a short block.
Either way there's no "easy" or cheap way to do it. You have to pull the motor, tear everything apart, and then reassemble the right way. The best thing to do is to do all this before the motor blows. If it is low mileage, we usually do a quick hone for a new ring sealing surface, deck the heads and engine cases, and that is enough for 99% of people up to 600 whp or so. Probably more, but that's as far as we have gone without closing the deck. Given that the cylinder wall thickness is pretty robust for an open deck motor, you may be able to get away higher without closing it...but that's a whole other conversation.
Most builds we see range from 5k in and out with a simple rebuild of a non-damaged motor, up to 11k if the cases are shot and heads are damaged. The price difference is pretty staggering, so the earlier you build it the cheaper it is in the long run. The only caveat is that if you're running under 275 whp, you'd be very unlucky to have the motor go. Even at low to mid 300's it is pretty rare.
R&R is removal and reinstallation?? That sounds like a super deal and I probably don't know what R&R is
Seek comfort in discomfort.
alphasaur is offline   Reply With Quote
Old 11-23-2021, 08:36 AM   #17
Remove and replace. You were close.
alphasaur (11-23-2021)
Old 11-23-2021, 11:13 AM   #18
BrahmaBull1990
Howdy
BrahmaBull1990's Avatar
Drives: 2020 BRZ PP
Sorry to hear that. How many miles on the motor when it popped and how much whp/tq? Any plans to rebuild?
There's a point at 7,000 RPM... where everything fades. The machine becomes weightless. Just disappears. And all that's left is a body moving through space and time. 7,000 RPM. That's where you meet it. You feel it coming. It creeps up on you, close in your ear. Asks you a question. The only question that matters. Who are you?
BrahmaBull1990 is offline   Reply With Quote
Old 11-23-2021, 11:19 AM   #19
dynarun55
Put C30 JRSC on 100k engine. Standard 50% increase in HP. Street tuned it with CSG. Yeah i calling around for quotes on swapping out to an IAG. Tried to call Xero this morning but didnt pick up.
BrahmaBull1990 (11-23-2021)
Old 11-23-2021, 12:16 PM   #20
BrahmaBull1990
Howdy
Drives: 2020 BRZ PP
Good plan. Let me know what the labor cost is. I was hoping to do an IAG swap for $10kish (including block) at some point. But when adding a clutch and that, it can add up.
Old 11-23-2021, 03:16 PM   #21
TommyW
TommyW's Avatar
Drives: '13 Whiteout
You can get an IAG short block Stage 1. with all the good stuff all ready to go. Rated for 500HP.
TommyW is offline   Reply With Quote
Old 11-23-2021, 09:19 PM   #22
BrahmaBull1990
Howdy
Drives: 2020 BRZ PP
I just got quoted by my shop $10-15k to install a short block. That seems high, no? Granted they do quality work, but damn.
Old 11-23-2021, 09:26 PM   #23
TommyW
TommyW's Avatar
I was 12 with everything including clutch, heads redone. Amazing motor. Headers and tune car is fantastic. Fantastic shop. You can get a stock shortblock for about 1,400 less. IMO spend the extra on IAG and be bulletproof
The Following User Says Thank You to TommyW For This Useful Post:
Old 11-23-2021, 09:44 PM   #24
BrahmaBull1990
Howdy
Drives: 2020 BRZ PP
I am leaning towards IAG (sale right now, too). This quote was for labor only, so I would be about $20k all in with the block.
Old 11-23-2021, 10:41 PM   #25
TommyW
TommyW's Avatar
thats too much. 12 was a stretch. A rebuild from most shops is around 8 with a new stock shortblock. I’d look into a K24 conversion for that kind of money
machine work for forged rods with stock pistons? Andew727 Engine, Exhaust, Transmission 17 07-27-2017 03:47 AM
Which Forged Rods and Pistons sam69 Forced Induction 19 01-13-2015 09:13 PM
Building my motor I need help on which pistons and rods and which ones to get at a Anthony7515 Engine, Exhaust, Transmission 23 09-21-2014 11:03 PM
12.5/1 Comp Forged Rods and Pistons Darryljr11 Engine, Exhaust, Transmission 1 10-26-2013 08:11 PM
Forged pistons and billet rods paraguin Engine, Exhaust, Transmission 0 09-25-2012 10:55 PM
