Old 09-19-2013, 11:32 AM   #15
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by Foobar View Post
Yeah, I've seen stuff like that too, but in this case, I've had these lights in place for months and the issue just started happening this week. The bulb is definitely dead. Does it sound right that a dead bulb would cause grounding or other wiring issues?
If in the proccess of dying it got too much current or something melted such as some contacts then it is possible. What did the dead bulb look like inside?
Old 09-19-2013, 11:51 AM   #16
Foobar
SLO NO MO
Foobar's Avatar
The filament looks intact. I don't see any abnormalities anywhere but connecting it to voltage shows that it's dead.
Perhaps a short inside the plastic base that I can't see from outside?
Sent from my Nexus 4 using Tapatalk 4
Old 09-19-2013, 12:21 PM   #17
King Tut
NASA SpecE30 Racer
King Tut's Avatar
That would be my guess. I would be worried about the design of the wiring that is feeding it as it may just happen again in the future.
Old 11-01-2021, 02:53 PM   #18
Simok
Drives: 2013 FRS
Sorry for bringing up an old post. I am having a similar issue. I installed the phastek 4th brake light kit using the tap connectors supplied. It has been installed for years. I havent noticed any issue the whole time. I recently realized it wasnt working.
Assuming a burnt out bulb I bought a new sylvania silverstar bulb which is what the kit came with. Still didnt work. I purchased a harness that connects to the brake light that has wires coming off to connect to the 4th brake light instead of taping into the stock wiring. I removed the old connectors verified only insulation on wires were damaged and shrink sleeved over the exposed portions and reinstalled with the new harness. Light worked again.
I then noticed that when I hit the brake it dims the clock and turns the aftermarket head unit backlight on. This seems to correct if the headlights are turned on. I removed the wires from the new harness and it fixed the problem. I then removed the bulb and this also corrected the problem. I tried the second bulb in the package and even the old bulb and had the same issue with them all. Is there a special bulb to use to correct this issue? Or am I stuck living with it or not having a 4th brake light?
Simok is offline   Reply With Quote
Old 11-01-2021, 03:36 PM   #19
I'll guess that the incandescent bulb load takes the whole system over the top. Try using an LED bulb instead.
DIY-- How to bypass your NAVI without moving out your NAVI (Canadian BRZ only) 8987846 DIY (Do-It-Yourself) Guides 77 04-29-2015 02:45 PM
Pressing/releasing clutch pedal - audible click sound (not the clutchs switch tanner BRZ First-Gen (2012+) — General Topics 26 06-03-2014 09:24 PM
Bypassing your NAVI without moving out your NAVI 8987846 CANADA 0 12-24-2012 03:20 AM
CLOCK QUESTION poudre BRZ First-Gen (2012+) — General Topics 16 07-02-2012 03:20 PM
Details: Interior dims, glass, light bulbs Ryephile Scion FR-S / Toyota 86 GT86 General Forum 17 03-01-2012 11:28 AM
