Old 08-15-2021, 08:01 PM   #1
PetrolioBenzina
PetrolioBenzina's Avatar
Drives: 17 86
"Dice-in-a-cup" rattle help...
If I'm driving at a steady speed, in any gear, and give the gas pedal a stab I get a dice-in-a-cup rattle. It does not rattle with a gentle roll-on of the throttle. Seems to be coming from under the car, not engine knock.
Any ideas?
Thanks!
PetrolioBenzina is offline   Reply With Quote
Old 08-15-2021, 09:27 PM   #2
Maybe throttle body chatter?
Something on the floor under the seats rolling around?
Someone put a rock in your cars tailpipe?
A VC put a hand grenade the pin pulled a rubber band holding the handle down, in your gas tank?
(it must be my nap time - )
Old 08-15-2021, 09:34 PM   #3
PetrolioBenzina
Drives: 17 86
Grenade would have detonated by now, but one small enough to fit in the pipe would rattle around. I'll check under the seats.
The Following User Says Thank You to PetrolioBenzina For This Useful Post:
humfrz (08-16-2021)
Old 08-16-2021, 03:29 PM   #4
soundman98
ProCrastinationConsultant
soundman98's Avatar
What mods do you have?
Old 08-16-2021, 03:45 PM   #5
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
When I first got my FR-S, one of the first things I did was install puddle lights in each door. While I had the door panels off, I found coins in my driver's side door that would roll back and forth as I accellerated and braked. Removed them and the noises disappeared along with.
My pubes are shaped like the number 86. There for I’m car. Derp
Count to muffens and call again.
I’m 40. So....... say hi to your sisters or daughters.
FR-S2GT86 is offline   Reply With Quote
The Following User Says Thank You to FR-S2GT86 For This Useful Post:
Ultramaroon (08-16-2021)
Old 08-16-2021, 04:06 PM   #6
LimitedSlip
Senior Citizen Member
LimitedSlip's Avatar
Drives: Then-1977 Celica GT Now-2017 860SE
When you "stab the pedal" perhaps it is causing the engine/exhaust system to "torque twist" just enough for something to momentarily come into contact with the chassis or a heat shield?
LimitedSlip is offline   Reply With Quote
The Following User Says Thank You to LimitedSlip For This Useful Post:
PetrolioBenzina (08-16-2021)
Old 08-16-2021, 04:38 PM   #7
PetrolioBenzina
Drives: 17 86
Thanks. Others have had heat-shield rattles, hoping that's it, or something else not serious.
Old 08-31-2021, 07:32 PM   #8
xtyson
Drives: 2018 Toyota 86, Ablaze Red
Hey OP, did you end up figuring out what it was? My car has the exact same rattle. 2018 86.
xtyson is offline   Reply With Quote
The Following User Says Thank You to xtyson For This Useful Post:
PetrolioBenzina (09-01-2021)
Old 09-01-2021, 06:18 AM   #9
PetrolioBenzina
Drives: 17 86
Still no luck, going to poke around underneath this weekend.
Old 09-01-2021, 02:56 PM   #10
trippinbillies40
trippinbillies40's Avatar
Drives: '22 WRB
Sounds like it could possibly be a DI seal.
trippinbillies40 is offline   Reply With Quote
Old 09-01-2021, 03:01 PM   #11
StraightOuttaCanadaEh
Wes
For me it was the front pipe bolt that rattled itself loose gradually. It sounded pretty embarrassing before I finally had it tightened. Could be that. Doesn't exactly match what you're experiencing but apparently this bolt is known for loosening. The sound was coming from directly under the trans tunnel/bulkhead basically
Instagram: @gt86ws
Old 09-07-2021, 01:37 AM   #12
Turdinator
Señor Member
Turdinator's Avatar
If the car is manual and you're doing it under 3k rpm it could well be knock
1974 TA22 Celica
2013 86 GT
The Following 2 Users Say Thank You to Turdinator For This Useful Post:
PetrolioBenzina (09-08-2021), soundman98 (09-08-2021)
Old 09-08-2021, 01:04 PM   #13
PetrolioBenzina
Drives: 17 86
Thanks, taking out the OFT and checking this weekend, at least thats the plan. I just found out I have a broken bone in my foot.
Old 09-09-2021, 04:03 AM   #14
Turdinator
Señor Member
Turdinator's Avatar
Dude! How hard were you stabbing that gas pedal?!?
1974 TA22 Celica
2013 86 GT
sato (10-17-2024), soundman98 (09-10-2021)
Low RPM rattle when "lugging"? topazsparrow Issues | Warranty | Recalls / TSB 61 05-31-2018 03:10 PM
Toyota/Subaru D4S "engine cover" rattle canadaRS1.0 Issues | Warranty | Recalls / TSB 4 06-14-2015 08:12 PM
Yet ANOTHER "Clutch Rattle" Thread, With a Difference FlamingRectumSyndrome Scion FR-S / Toyota 86 GT86 General Forum 33 09-19-2014 10:31 AM
15" wheel fitmen = no dice 7thgear Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 11-03-2012 09:22 PM
Steering wheel/dash "rattle?" upon heavy acceleration? brett_g Issues | Warranty | Recalls / TSB 2 08-04-2012 05:52 AM
