Drives: 2016 scion frs
clutch pedal on floor.
Hey guys,
So i put my new built block in my car. and while the car was sitting(+5months) I obviously bought upgrades, like Chase Bay's clutch line.I removed the stock clutch line assembly and installed the chase bay unit. Prior to removing the OEM clutch line assembly, i handpumped out most of the old brake fluid from the reservoir. I got someone to pump the clutch pedal 6-8 times then i open the bleeder valve while the clutch pedal is pressed down to bleed. I did this for 10-20 minutes until i saw no air bubbles in the fluid, but the whole time the clutch would not want to go back automatically after releasing the fluid through the bleeder. Pumping the clutch pedal a few times would eventually get it to go back up, but it doesnt do it fast at all or right away. Anyone got any pointers or might be the issue? i took off the slave cylinder to check if the boot was damaged or leaking, all good on the Slave cylinder. Also, no leaks from the clutch master either. Could it be, since the car was sitting for over 5 months? Last edited by jrhudson; 09-02-2021 at 11:35 PM. |
#2 | |
Sent from my ONEPLUS A5010 using Tapatalk |
| The Following User Says Thank You to Ashikabi For This Useful Post: | jrhudson (09-02-2021) |
#3 | |
Yes, before the clutch pedal is released i close the bleeder valve. |
#4 | |
#5 | |
So maybe i did put it in the incorrect way. I'll bleed it for an hour straight tomorrow. If it doesn't work then I'll pull that dang trans. (ugh) |
#6 |
I'll suggest this for bleeding: use grease to seal the sides of the valve. Use a length of hose to reach from the slave to the reservoir. Bleed in a complete loop
| The Following User Says Thank You to Ashikabi For This Useful Post: | jrhudson (09-03-2021) |
#7 |
Good idea! ill try that. one question, if my clutch disc is installed wrong, would the car even start?
#8 |
Drives: '14
I had some trouble bleeding mine after swapping the slave cylinder. Jacking the car up (so the bleed screw end is elevated), and pressing in the slave pin while the pedal is depressed and bleeder is open got everything working again.
Always learning.
| The Following User Says Thank You to itschris For This Useful Post: | jrhudson (09-03-2021) |
#9 | |
question, when you say slave pin, you mean the pin/piston thing that contacts the clutch fork? |
#10 |
Drives: '14
Yep, that's it. Bleeding via the service manual method I was getting zero bubbles after a while. Pressed the pin in and a bunch of air came out.
Always learning.
#11 |
| Clutch pedal squeaking when clutch is in motion | Brz_racer | BRZ First-Gen (2012+) — General Topics | 1 | 01-31-2018 09:27 PM |
| Clutch pedal adjustment gone wrong? Clutch issues. | PulpBrah | Engine, Exhaust, Transmission | 12 | 03-06-2017 04:08 PM |
| Clutch Pedal | rick s | Engine, Exhaust, Transmission | 51 | 09-20-2015 10:08 AM |
| floor mounted pedal | mokinbird87 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 12-09-2014 01:46 PM |
| Clutch Pedal Noise Help!! | ZackZ | Scion FR-S / Toyota 86 GT86 General Forum | 6 | 09-06-2013 05:35 PM |
