Old 08-30-2021, 04:39 PM   #1
Myriad
Myriad's Avatar
Drives: 2017 86, 2012 Tundra, 1999 Integra
Air conditioner drain tube clog
It’s been awhile since I posted. Usually I can search and find most any answer, but I don’t see too much written about the AC drain tube. Mine is clogged and causing water to overflow into the passenger footwell, sloshing and leaking all over the place. I had this happen once before a few years ago and the dealer fixed it under warranty, telling me the drain tube was clogged with tree debris. They said they cleaned it out and it was good as new. But they didn’t tell me *how* they did that. Can anyone give me pointers? I think the tube is at the footwell and runs down to an exit under the car somewhere. Is there an easy way to take it off and flush it out?
Thanks,
Myriad
Myriad is offline   Reply With Quote
Old 08-30-2021, 07:07 PM   #2
Myriad
Myriad's Avatar
To follow up, I’m home from work and tried to pour some water on the cowl by the wiper blades to see where they drain out to. I figured I’d see a hole or tube, but it dribbles out right below the hinges of the doors near the jack points. Is that right? I’m thinking both sides are clogged. Neighbor’s trees drop the messiest crap. Is there a DIY to fix these clogs or do I need a mechanic to figure this out?
Thanks,
Myriad
Old 08-31-2021, 01:12 AM   #3
Brz866
Brz866's Avatar
Drives: Series Blue WRB JRSC C38 HBP Flex
Never happened to me, but I've heard other fix this by blowing compressed air into the drain tube to unclog it. Might be worth a shot.
Brz866 is offline   Reply With Quote
The Following User Says Thank You to Brz866 For This Useful Post:
Myriad (09-22-2021)
Old 09-02-2021, 02:16 AM   #4
Mykart
Drives: 2017 BRZ w/PP
I had to do this recently thanks to a spider making a nest in mine. All you have to do is pull back to carpet on the passenger's, remove the tube going from the AC unit to the floor and blow it out with compressed air.
This thread is what I followed.
Mykart is offline   Reply With Quote
The Following 2 Users Say Thank You to Mykart For This Useful Post:
jeepmor (10-04-2021), Myriad (09-22-2021)
Old 09-06-2021, 12:34 AM   #5
RippedManiac
Jedi
Drives: Pikachu BRZ
I second this.
Happened to me a few months back. Blew on the tube and the clog came off. Worked like a charm.
RippedManiac is offline   Reply With Quote
The Following User Says Thank You to RippedManiac For This Useful Post:
Myriad (09-22-2021)
Old 09-22-2021, 01:38 AM   #6
Myriad
Myriad's Avatar
Thanks guys. I took the advice and blew some air through it. The top of the tube under the passenger feet was easier to detach than I thought. It just pops right off with a firm tug. And here I thought I was going to have to disassemble some air conditioner part or do something complicated. Used an air compressor with a blower attachment, and voila—no more sloshing noises or wet feet.
Myriad
The Following User Says Thank You to Myriad For This Useful Post:
Wally86 (09-23-2021)
Old 10-04-2021, 06:53 PM   #7
jeepmor
Drives: 84 CJ7, 08 Duramax, 2014 FRS
Such good help in here, chops to the community!
jeepmor is offline   Reply With Quote
Old 10-04-2021, 06:54 PM   #8
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
This info should go in the DIY section.
Air Conditioner Stopped Working rb6freak Issues | Warranty | Recalls / TSB 63 05-26-2024 03:57 PM
AIR CONDITIONER ND-OIL8 QUANTITY Z06ZN6 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 03-08-2020 12:36 AM
Greddy Magnetic Oil Drain Plug or Fumoto Drain Valve? tracerit Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 20 01-04-2016 08:36 PM
Center air conditioner trim removal? Jake_86 Cosmetic Modification (Interior/Exterior/Lighting) 6 03-13-2015 06:17 PM
Air conditioner issue TStafford Scion FR-S / Toyota 86 GT86 General Forum 3 08-29-2014 09:36 AM
