Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 09-01-2021, 08:07 PM   #43
Blighty
Drives: WR Blue Pearl 2022 Subaru BRZ
Originally Posted by Sasquachulator View Post
Seems like Japan gets additional infotainment choices.
The blank option, a larger touch screen that takes up all the bezel, and I think theres a double-din non-integrated unit.
I haver noticed that they use a different head unit part in the JDM models (and I kind of prefer it tbh as its makes the car seem that little bit more premium inside), but I haven't seen anywhere that its an optional.
Blighty is offline   Reply With Quote
Old 09-01-2021, 08:14 PM   #44
Blighty
Originally Posted by FlyingJett View Post
Xmm.. is it a right time to look at GR Yaris ?)
If you want AWD then for sure!, although it might be worth waiting for the new WRX and STI to compare.
But do you really want AWD?
Old 09-02-2021, 12:43 AM   #45
PulsarBeeerz
Drives: JRSC BRZ SOLD
Originally Posted by austintampa View Post
not when emissions is the goal.
my ecoboost mustang would ping on sudden low RPM application of throttle - I dont assume that to be a rich condition.
This dip has been a point of contention for 8 years now and it apparently still exsits. No data log has ever shows ping from running lean at WOT as the cause..
PulsarBeeerz is offline   Reply With Quote
Old 09-02-2021, 12:50 AM   #46
OwlDance
Drives: Halo 86, '19
The only thing this suggests to me is that the torque dip has always been an overblown issue as a result of people fixating on it via dynos considering literally no reviewer mentioned it in the early reviews based on feel alone.
I'm also 99% sure it has everything to do with emissions and catalytic warmup processes. An early article discussed the FA20 moving back the CC back a some CM or so compared to the Impreza FB20 while maintaining faster warmups. This, coincided with the fact that the Ace 350 sees the largest peak gains in the middle of the torque curve because of its long, catless runner length suggests to me that there's nothing that can be done about it OEM wise without massively compromising emissions and critical warmup emissions.
But I'm sure it's barely an issue anyways. I don't have an issue stock on the 2 liter, it's going to be even less of an issue on the 2.4 liter. As said by numerous people here before, the torque dip is either barely more than a brief passing moment in a low gear, or you're otherwise lugging the car in too tall of a gear where you should be downshifting to begin with.
OwlDance is offline   Reply With Quote
The Following User Says Thank You to OwlDance For This Useful Post:
Dzmitry (09-02-2021)
Old 09-02-2021, 12:53 AM   #47
austintampa
Drives: honda element
well im not as book learnt as other people with their fancy equations and maths to understand why a car can have torques and then have that fall off and then make torques again.
austintampa is offline   Reply With Quote
Old 09-02-2021, 08:56 AM   #48
Baldeagle
Drives: VW GLI 6MT
Only a test drive will confirm our speculations. But to add to our speculation, I threw together a very quick spreadsheet to show speed in gears and different shift points. In my current 2.0T-6MT car, for normal daily driving I use 2,500 rpm shift points with no problems. And that’s pretty much off boost.
If we use a 3,500 rpm shift point (or less) it appears we will enter the next gear in the low to mid 2,000 rpm range, right in the “pre-dip” sweet spot. That might prove fine for daily driving. If we are concerned about avoiding the dip when driving faster, it seems we’ll need to use a 6,000 rpm shift point, except for first gear. To enter second gear above 4,500 rpm we need at 7,500 rpm shift point from 1st gear.
This may not be a major issue. Even if we do spend time near the 4,200 rpm dip, if it still has a fair amount of torque, it may not be irritating.
Baldeagle is offline   Reply With Quote
The Following 2 Users Say Thank You to Baldeagle For This Useful Post:
Ohio Enthusiast (09-02-2021), Stonehorsw (09-02-2021)
Old 09-02-2021, 09:44 AM   #49
Dirty Harry
Dirty Harry's Avatar
Drives: 2013 BRZ Satin White Pearl
30% front / 70% rear in sport mode. They still look like fun, clip only a little less than 2 1/2 mins, worth a look.
Dirty Harry is offline   Reply With Quote
The Following User Says Thank You to Dirty Harry For This Useful Post:
slimfit (09-02-2021)
Old 09-02-2021, 10:47 AM   #50
slimfit
Drives: ‘22 BRZ
I’d sell organs to own a GR Yaris, but it’ll never come to the states in that form. A bloated Corolla with a 3 cylinder is DOA.
slimfit is offline   Reply With Quote
The Following User Says Thank You to slimfit For This Useful Post:
Dirty Harry (09-08-2021)
Old 09-02-2021, 11:31 AM   #51
CincyJohn
Drives: 2022 MT Neptune GR86 Prem.
Originally Posted by ZDan View Post
You're repeating exactly the same point: *glad* there's a torque dip because that means you can spend time and $$$$ and effort to eradicate it (while making car illegal).
How on earth is that *better* than simply not having a torque dip (or having a more minimal one) in the 1st place?
I'd way way WAY rather see torque/power curves more similar to the graphs on the info screen we've seen...
Well, maybe for you. But I can't see why you can't see my (our) point.
I know what the numbers are (at least claimed) already for the 2022.
I know that they are probably pretty similar to what I have on my 2020 with two/three simple mods (OFT Tune/e85/catless header).
I know that I like what I have but would like a little more.
I know that I am likely to get a 2022 at some point.
I don't have any issues with spending the relatively small amount of money/time doing these same three things to the 2022 and I don't care if someone says its possibly illegal and/or voids the warranty.
THEREFORE:
I am happy to see that it APPEARS as if the engineers at Toyaburu ran into some of the same issues they ran into with the FA20 and had to make compromises in order to meet emissions/MPG issues and therefore did not ring every ounce of available power out in their factory tune and that gains similar to those available on the FA20 per above will likely be available on the 2022.
I respect the fact that you may not want to do tune/header/e85 and that's fine. But I am more than willing to do it.
CincyJohn is offline   Reply With Quote
Old 09-02-2021, 11:35 AM   #52
CincyJohn
You really can't be serious. Stock my 2020 felt like I was hitting a wall when I ran into the torque dip. I mean, I could literally feel myself moving forward in my seat. I personally don't see how anybody could drive it that way for very long...
The Following 2 Users Say Thank You to CincyJohn For This Useful Post:
DriveDriftDogfight86 (10-03-2021), FlyingJett (09-02-2021)
Old 09-02-2021, 11:51 AM   #53
OkieSnuffBox
Drives: '23 BRZ Limited
That's because they are almost always on a track.
On the street, in say third gear needing to accelerate, you could always feel it fall flat on it face for a few then pick back up noticeably.
Old 09-02-2021, 12:02 PM   #54
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
Obviously a little exaggerated there... I felt like it was fine, and I certainly never moved forward in my seat lol. Just didn't have more pickup. would hit the dip and all of a sudden the acceleration felt flat and no different than prior to the dip (that's because power is flat in this region).
The one neat thing with the dip, I always thought, was the acceleration you would feel right as the torque starts to rise again, because at this point the power began to rise much quicker than at any other point in the powerband.
One thing that actually destroyed this feeling was putting in a header and tune. It was certainly quicker I recall, but the acceleration never felt like it did during that torque increase out of the dip. Instead it's just a gradual increase through the powerband.
Anyways, all that is just feels. It's obviously not ideal, in any case, to have the dip. But as I said earlier, I'm really not worried about the torque dip in the new gen as the whole torque curve is a good bit higher now, to the point that the lowest point of the dip is around the highest point of gen1's torque peak.
Dzmitry is offline   Reply With Quote
Old 09-02-2021, 12:10 PM   #55
trippinbillies40
trippinbillies40's Avatar
Drives: '22 WRB
Actual image of CincyJohn hitting the torque dip while gently accelerating.
trippinbillies40 is offline   Reply With Quote
The Following 5 Users Say Thank You to trippinbillies40 For This Useful Post:
BigTuna (09-02-2021), CincyJohn (09-02-2021), DriveDriftDogfight86 (10-03-2021), Dzmitry (09-02-2021), OwlDance (09-02-2021)
Old 09-02-2021, 12:15 PM   #56
DarkSunrise
DarkSunrise's Avatar
My friend with an ap2 s2000 and I joke that it’s Subaru’s VTEC lol.
2022 BRZ Build
2013 FR-S Build
The Following 2 Users Say Thank You to DarkSunrise For This Useful Post:
Dzmitry (09-02-2021), FlyingJett (09-02-2021)
Typical Mustang Dyno Numbers? Rockz222 Engine, Exhaust, Transmission 6 07-11-2015 08:33 PM
Dyno numbers ogrowup Engine, Exhaust, Transmission 7 12-27-2014 08:04 AM
Average Stock Dyno Numbers? KONVERTER Engine, Exhaust, Transmission 23 10-12-2013 10:13 PM
Dyno numbers list from Evasive Motorsports Meet/Dyno Fish Southern California 29 02-24-2013 03:16 AM
dyno numbers seem low stealth_fighter Scion FR-S / Toyota 86 GT86 General Forum 9 02-02-2013 09:01 PM
