Old 08-03-2021, 11:45 AM   #1
Netrick
Drives: MY2020 Subaru BRZ Ts
Stuck Odometer
Hello,
I recently bought used MY2020 Subaru BRZ Ts and i seem to have an issue:
Odometer is stuck at 36 545km (22 708 miles) while car is still displaying speed, engine RPM and "Trip" distance correctly. No error codes are present. Cruise control is working. Is my instrument cluster damaged?
I checked for possible loose connections. There is no warranty due to hte fact that the previous person serviced the car himself.
some more info:
When i was driving home the car still counted miles, the next day it stopped at some point.
As i said before: all systems are working, speed is shown correctly as well as trip distance is shown properly.
What may be the problem and how can i fix it?
Netrick is offline   Reply With Quote
Old 08-03-2021, 11:51 AM   #2
soundman98
ProCrastinationConsultant
soundman98's Avatar
Where in the world are you? Because self maintenance doesn't normally void the warranty
Also, is your name Carmen Sandiego?
The Following 3 Users Say Thank You to soundman98 For This Useful Post:
FR-S2GT86 (08-03-2021), JD001 (08-07-2021), The Red One (08-04-2021)
Old 08-03-2021, 12:43 PM   #3
LimitedSlip
Senior Citizen Member
LimitedSlip's Avatar
Drives: Then-1977 Celica GT Now-2017 860SE
Take the vehicle to a dealership and ask them if it is still under warranty. Won't cost anything to ask.
LimitedSlip is offline   Reply With Quote
Old 08-03-2021, 01:11 PM   #4
Netrick
I already asked, well, it came from USA to Europe, it had not been in any accident, i paid for warranty transfer and papers i got said that it is not valid anymore because of "self maintenance". Dealership want me to pay for diagnosis and repair. The thing is, cars leave more broken than they arrive where i live, always something is broken or not how it suppose to be. My friend's car even had loose parts after valve spring recall.
And no, my name is not "Carmen Sandiego"
Old 08-03-2021, 03:59 PM   #5
Grady
Grady's Avatar
Don’t fix it until you sell the car. 10 years from now you will have a car with 36k km on it.
The Following User Says Thank You to Grady For This Useful Post:
JD001 (08-07-2021)
Old 08-03-2021, 04:57 PM   #6
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
A one year-old USDM car exported to Europe? Time to invest in a good scan tool that can access enhanced diagnostics. You need to verify the mileage recorded in the ECU, possibly the body control module or instrument panel control module. I'll bet that someone has electronically "rolled back" the odometer before it was sold and exported, and it has caused some sort of malfunction. It's actually a federal crime here in the States to do this, but if the new owner is abroad, there's not much backlash that will occur to the person because of it.
Or it may simply be some strange gauge malfunction.
Either way, you should do some more research on the history of this car. You can register the VIN in the Toyota database to view it's repair history, even if you're not the original owner. You should access the US Toyota website though, not the EU website.
Here is a link:
https://www.toyota.com/owners
Begin there and keep us informed, I'm curious as to what you find.
My pubes are shaped like the number 86. There for I’m car. Derp
Count to muffens and call again.
I’m 40. So....... say hi to your sisters or daughters.
FR-S2GT86 is offline   Reply With Quote
Old 08-03-2021, 08:45 PM   #7
2020BRZtS
2020BRZtS's Avatar
Drives: '20 BRZ tS (15/300) / '09 Scion tC
Can you post a pic of the gauges?
2020BRZtS is online now   Reply With Quote
Old 08-04-2021, 01:35 PM   #8
Netrick
picture may seem blured because of how bad i'm at making photos.
https://imgur.com/a/KFUkEuv
Old 08-04-2021, 01:51 PM   #9
I suggest you check the fuse that controls that circuit.
Then purchase an inexpensive code reader and read any codes.
Unplug the negative side of the battery, drink a half a beer then plug it back in. Check for codes.
OR
Just don't worry about it -
Grady (08-04-2021)
Old 08-04-2021, 05:27 PM   #10
Grady
Grady's Avatar
I think we see the root of the issue. That is not a US cluster. Whoever changed it out did not do it correct? Europe cluster is not compatible with a US car? The 2 may need to be married together?
2020BRZtS (08-04-2021)
Old 08-04-2021, 05:29 PM   #11
Grady
Grady's Avatar
That may not work, Dependent on where he is in Europe a half a pint will not be enough time or it needs to be Wine.
humfrz (08-05-2021)
Old 08-05-2021, 02:57 AM   #12
OR ....... a bigger "container" -
Grady (08-07-2021), soundman98 (08-05-2021)
Old 08-06-2021, 06:13 PM   #13
Netrick
This actually is a US cluster. The only thing that was done is units translation by a professional, and i changed this black unit sheet, still have original (US) one. As i said before IT WAS counting distance as it suppose to be, the issue appeared over night when i parked the car.
I have not found solution yet, i'll keep you notified of any news
Old 08-07-2021, 09:28 AM   #14
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
Since it WAS counting distance, and the trip meter and speed are still working, it sounds like an internal issue, all those things are going to get calculated from the vehicle speed data coming in over CAN bus.
I guess the only thing you could try is disconnect both battery cables and short them together (keeping them away from the actual battery posts) and leaving it like that for a few minutes to actually kill the power and drain any caps that may be keeping computer memory alive.
Fun anecdote: A few years ago a guy I know had a Dodge Journey and after a night of having left the lights on, the battery fell completely flat. Once it was jump started back to life, the odometer had actually reset to zero but incremented fine like nothing had gone wrong. All in all the car had lost about 30000km by accident.
So these kinds of computer errors do happen sometimes
The Following User Says Thank You to RZNT4R For This Useful Post:
soundman98 (08-08-2021)
BAC Mono for sale. Full Visible Carbon Fiber, 3 miles on the odometer,California car supra2nv Miscellaneous 2 01-09-2017 12:29 PM
Incorrect odometer reading Ft-86 Please Off-Topic Lounge [WARNING: NO POLITICS] 14 12-24-2014 04:19 PM
key keeps getting stuck Covo_86 Issues | Warranty | Recalls / TSB 14 04-21-2014 09:55 AM
Trip Computer / Odometer Accuracy brillo Scion FR-S / Toyota 86 GT86 General Forum 9 01-21-2014 12:20 PM
What 18 and 19 in tire sizes will not mess with odometer Frs32907 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 08-07-2013 04:59 PM
