Old 07-08-2021, 10:37 PM   #1
jgold
Drives: 2017 Toyota 86
2017 86 tach signal
Ok, let me put this in other words. From what I've searched so far, there are various places to get an RPM based pulse in a base model 86. I started at the ECM (and I have no desire to go back into can of worms
with my old eyes), and apparently the four locations on the bottom connector are all to ignition coils. They all go through the AC1 connector in the engine bay. Where is there a diagram of that connector? I've entered every set of search words I can think of.
jgold is offline   Reply With Quote
Old 07-08-2021, 11:03 PM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Which connector? The plug at the coil pack has 3 wires. Brown w/white stripe is keyed 12vdc hot. Black w/white stripe is chassis ground. The 3rd is colored and is the ECM trigger, on pack 1 it is blue w/yellow stripe I believe on my 13'. You can test this by pulling the connector and probing for continuity. The one that has chassis ground is, well ground. Key on check which one has 12vdc. The other will be your trigger. Then correspond to the AC1 connector. The only AC1 pinout I could find was for a 15' but did not give wire colors.
NoHaveMSG is online now   Reply With Quote
Old 07-09-2021, 09:25 AM   #3
jgold
Just what I needed, with a "why didn't I think of that?" thrown in.
The Following User Says Thank You to jgold For This Useful Post:
NoHaveMSG (07-09-2021)
2017 86 tach signal jgold Scion FR-S / Toyota 86 GT86 General Forum 0 07-05-2021 06:57 PM
2017 OEM Sequential turn signal apatel471 Cosmetic Modification (Interior/Exterior/Lighting) 5 06-07-2018 10:45 PM
HELP: Need Tach Signal!! Lil Abner Electronics | Audio | NAV | Infotainment 39 02-24-2016 09:59 PM
Cant see the top of my tach... MadFRS Scion FR-S / Toyota 86 GT86 General Forum 31 07-29-2013 05:11 PM
BRZ tach to FRS? lavisxice Cosmetic Modification (Interior/Exterior/Lighting) 7 04-01-2013 04:48 PM
