Old 06-02-2018, 03:20 PM   #1
apatel471
apatel471's Avatar
Drives: 2017 World Rally Blue BRZ
2017 OEM Sequential turn signal
Does anyone know of a plug and play solution to make the tail lights on MY2017+ sequential?
Something like the diode dynamics Tail-as-Turn, except for adding a sequential function.
apatel471 is offline   Reply With Quote
Old 06-04-2018, 07:20 PM   #2
andrewsbutt
andrewsbutt's Avatar
Drives: 2017 BRZ LTD
Found a potential solution. Other forum members found a knock off MY2017 tail lights that have the sequential turn function built in:
https://www.ft86club.com/forums/showthread.php?t=127839
andrewsbutt is offline   Reply With Quote
Old 06-07-2018, 03:56 PM   #3
apatel471
apatel471's Avatar
I would prefer to not purchase a whole new set of tail lights and rather find a better cost-effective solution.
Old 06-07-2018, 04:32 PM   #4
wparsons
wparsons's Avatar
If the factory LED bulbs are all wired together, no fancy electronics before them is going to make them light sequentially. They have to be wired in a way that lets each one light independently to be able to work sequentially.
flickr
The Following User Says Thank You to wparsons For This Useful Post:
Tcoat (06-07-2018)
Old 06-07-2018, 04:40 PM   #5
gpvecchi
gpvecchi's Avatar
That should not be difficult. Can you easily open the tail lights?
gpvecchi is offline   Reply With Quote
Old 06-07-2018, 09:45 PM   #6
fx1mark
fx1mark's Avatar
Drives: red 2014 FR-S
It would be difficult if the led's are sealed and not easily accessible individually.
fx1mark is offline   Reply With Quote
The Following User Says Thank You to fx1mark For This Useful Post:
wparsons (06-09-2018)
Diode Dynamics Tail-as-Turn™: Make your LED tail a turn signal & add backup LEDs! Diode Dynamics Exterior Parts - Lighting 192 10-04-2017 11:51 AM
FS:GCS V.1 Turn signal Vesalera Exterior Parts (Aero, Lighting, Etc.) 1 01-07-2017 07:14 AM
Anyone seen these turn signal/drl less? djliquidsteele Cosmetic Modification (Interior/Exterior/Lighting) 7 07-15-2012 03:32 AM
