Old 06-26-2021, 03:07 PM   #1
TheRealBFKR
Drives: '18 WRB BRZ Limited w/ PP
Best way to remove thread sealant from oil line fittings?
Hello!
I have a very small leak where the oil line goes into the adapter between the sandwich plate. I have opted to replace the line as well as the m22-AN10 adapter itself.
The m22 side of the adapter going into the sandwich plate has some Permetex thread sealant on it when I last installed it. What's the best way to clean it up for the new adapter?
Tooth brush?
TheRealBFKR is offline   Reply With Quote
Old 06-27-2021, 04:09 PM   #2
It's good that you're thinking gentle to start. There are gasket removal products available at auto parts stores. Problem is that they work slowly. Anything that works quickly is also super nasty.
I'd soak it in a glass or metal bowl just large enough to do the trick. Set it face down in the stuff and walk away for a while.
Old 07-03-2021, 03:30 PM   #3
Grady
Grady's Avatar
Originally Posted by TheRealBFKR View Post
Hello!
Tooth brush?
What side is leaking? Both AN threads and straight threads with an o-ring should not have sealant applied. Tooth brush and IPA (not the beer) or any kind of paint thinner should work.
2qt Accusump, -10 AN line, fittings, bracket, remote operating cable Joesurf79 Engine, Exhaust, Bolt-Ons 29 02-24-2023 02:04 PM
SOLD - PLEASE REMOVE/CLOSE THREAD Initial_RD Exterior Parts (Aero, Lighting, Etc.) 10 08-13-2016 03:10 PM
Replacing oil cooler line fittings? 1Cor10:23 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 09-17-2015 02:43 AM
Remove poll from thread MrAnthonyC Site Announcements / Questions / Issues 1 10-24-2014 10:39 AM
Brake Line Sealant Spray? Pacific Auto Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 02-27-2014 12:47 AM
