Old 06-15-2021, 01:30 PM   #1
nkobns
Drives: Sideways
Tein CSG FLA pillowball bearings replacement
Hi everyone,
I’m sharing my experience since I expect to be the first one to have to replace those (I was on pre-order for those, I drive 15.000 miles per year, track the car - including nurburgring, and drive awful B-roads a lot - but that will definitely change !)
Pillowball bearings are not mounted with silent blocs, so they wear fast.
I had some play after around 30.000 miles.
It is relatively easy to get the entire camber plate assembly (around $300 a pair), and after getting in touch directly with Tein japan, I (EU resident) managed to get just the ball joints from Tein UK (£42 a piece)
You need a special tool to open the housings which I built. Beware, the tool needs to be well built and extra strong, the torque needed is huge. I used a drilling bit for extra stiffness.
Part number :
With my gorgeous tool :
nkobns is offline   Reply With Quote
The Following 3 Users Say Thank You to nkobns For This Useful Post:
CSG Mike (06-18-2021), MrSkubi (06-17-2021), Thefalls (06-15-2021)
Old 06-16-2021, 11:52 AM   #2
FinleyBull
Drives: red
Recently I had to change.
FinleyBull is offline   Reply With Quote
Rod Bearings/Main Bearings Fa20Toybaru Forced Induction 8 06-17-2021 11:00 PM
Rod Bearings/Main Bearings Fa20Toybaru Engine, Exhaust, Transmission 2 06-02-2021 02:15 AM
LCA PillowBall Joint Rubber Cover Bach415 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-22-2016 03:01 AM
Pillowball trailing and control arm bushings? Proof Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 03-17-2014 07:23 PM
Pillowball or urethane for lca / uca diss7 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 09-23-2013 12:40 PM
