Old 05-23-2021, 12:37 AM   #57
Originally Posted by Limitless_BRZ View Post
yeah, JDL bash bar
Lots of air flowing straight over the top of the oil cooler, or something like that. Need some ducting between it and the rear of the grill.
NoHaveMSG (05-23-2021)
Old 05-23-2021, 07:59 PM   #58
Limitless_BRZ
Limitless_BRZ's Avatar
Drives: Crystal White BRZ
Yeah, Im gonna have to readjust and sit the Cooler just right on the Bash bar, to clear as much of the intercooler & be all open still
Fabricator at JDL Auto Design
Limitless_BRZ is offline   Reply With Quote
Old 05-25-2021, 06:39 PM   #59
rixter145
Sleep Chomper
rixter145's Avatar
Originally Posted by BrahmaBull1990 View Post
Are people ever concerned about too cold of oil? Ambient temp here around Seattle hardly ever gets above 80* and that's for a month at most.
It seems operating temp for these oils with 0W-20 is around 100*C or 212*F. This is to ensure you are boiling off any condensation in the motor. I do not plan on adding an oil cooler with my Edelbrock, initially, until I see high temps on normal driving (I do not track). I will be adding a PCV catch-can, though.
It seems like everyone screaming oil coolers are parroting or reps looking to sell them.
Hello from Mill Creek over here! I recently installed my Emtron gauge and finally got my oil pressure sensor working... I been pretty much cruising at around 180+ F with an oil cooler that opens at around that temp. I think I broke 200 F when I was hooning around but so far no problems...
Oil pressure was within 20-60 psi range. Will drive more and see how the data looks.
Have to mention that I am using 5w40 oil and with a rebuilt motor. Also am kinda scared to drive that right now since my stupid retainers that sit on the rocker arm sheered off (And I don't know how!)...
Really need to get that retainer kit back in...
rixter145 is offline   Reply With Quote
The Following 2 Users Say Thank You to rixter145 For This Useful Post:
BrahmaBull1990 (05-25-2021), Ultramaroon (05-26-2021)
Old 05-25-2021, 06:49 PM   #60
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Originally Posted by rixter145 View Post
Please don't tell me that's from the Denstoj kit
rixter145 (05-25-2021)
Old 05-25-2021, 07:02 PM   #61
rixter145
Sleep Chomper
rixter145's Avatar
It is... they sent me more as replacement
Old 05-25-2021, 07:07 PM   #62
DarkPira7e
DarkPira7e's Avatar
I would be certain to post this in a their forum post to spread awareness. https://www.ft86club.com/forums/showthread.php?t=142047
Old 05-25-2021, 07:17 PM   #63
rixter145
Sleep Chomper
rixter145's Avatar
Will do, want to have proper wording as this is the first time they have seen this happening and not trying to put blame on them or anything.
They have been responsive and apologizing for this incident.
Edit: Upon further discussion, they would request to wait to share until I pulled the motor out and installed the new pieces. We need to verify if it was installation error or if there's something else weird going on. Will be working with them and post updates
Old 05-25-2021, 07:37 PM   #64
DarkPira7e
DarkPira7e's Avatar
Yeah definitely- it could have nothing to do with the retainer itself and is only a symptom of something else having dislodged it, who knows.
In the interest of full disclosure, I decided against using the retainers for this reason- if they're real this easy to install, I figured that it could potentially just be something else bouncing around and decided to wait it out. I'm hoping I'm far from right and that this is a freak accident
Old 05-25-2021, 07:40 PM   #65
rixter145
Sleep Chomper
rixter145's Avatar
For sure. The reason I got these retainer kit was because my rocker arm fell and flung itself out of the valve cover a few months after the engine came back... fully rebuilt. This retainer kit was to solve that issue and now this happened.
They are sending me a new set so I will get them put on and disclose all the info when all is said and done.
The Following User Says Thank You to rixter145 For This Useful Post:
DarkPira7e (05-25-2021)
Old 05-25-2021, 07:54 PM   #66
DarkPira7e
DarkPira7e's Avatar
Damned if you do, damned if you don't!
Old 06-05-2021, 07:08 PM   #67
Limitless_BRZ
So, Arizona today around 108.. in the car 116, temps got high af in stop go traffic & driving.
Coolant hit a high of 235, oil 230..
I bought a vented hood last night thankfully, now I need to figure out oil cooler shit & upgrade my radiator fans. Got so hot AC wasn’t really keeping me cool ��
Old 06-05-2021, 08:06 PM   #68
gen3v8
30 minute maintenance
gen3v8's Avatar
Drives: My18 wrxsti
That`s a high coolant temp if you were normal driving.
Old 06-06-2021, 02:04 AM   #69
Limitless_BRZ
Stop and go traffic for about 70% of the drive today
Old 06-06-2021, 02:09 AM   #70
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I suggest picking up a trac box or some other way to force the fans full on.
Oil Pressure drz400dude Engine, Exhaust, Transmission 9 04-30-2019 11:32 PM
Oil Pressure nearvincent Engine, Exhaust, Transmission 3 04-12-2017 08:46 AM
best tire pressure gauge (tire pressure question) steveholt Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 03-21-2015 11:27 PM
Stock clutch+flywheel+pressure plate+ ACT lightweight flywheel & pressure plate PineappleFriedRice Transmission and Driveline 0 11-08-2013 05:54 PM
Oil Pressure.. too low? Dave-ROR Tracking / Autocross / HPDE / Drifting 65 08-24-2013 01:43 AM
