Old 05-19-2021, 09:25 PM   #43
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
I didn't intend that to mean the JR dual's sole benefit was warming up the oil. I should have broken it down farther to say the JR setup has better temp regulation then an air to oil, but more thermal capacity then the oe forester unit, which I really don't consider much of a cooler.
Here is a shot of my water temp gauge after 3 hours of freeway driving in 50 degree weather. My oil temp only got to 140F using air to oil cooler. I am pretty sure the JR setup would have given me more "normal" temps, not that I really consider this that much of an issue periodically.
Got it. The comment was aimed at folks who want to get cold oil warmed faster. I wish I could spend more time driving at 50f. Down here it's 90s up from March to November.
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
The Following 3 Users Say Thank You to Capt Spaulding For This Useful Post:
NoHaveMSG (05-19-2021), Ultramaroon (05-19-2021), vintagemxer (05-25-2021)
Old 05-19-2021, 09:43 PM   #44
Tokay444
Originally Posted by Transport3r View Post
Wow you guys love wasting oil I guess. My German cars see 10-15k mile intervals (as per documentation and the computer’s oil life algorithm) and they’re fine.
Any decent synthetic should be fine to 7500 miles at the very low end.
Has BMW built an engine yet that didn't have well documented rod or main bearing issues?
They're fine, for now...
Old 05-19-2021, 09:57 PM   #45
Transport3r
Drives: -
Oil pressure
Any M or N engine should make it to 200k easily. The bearing problems is mostly S54/S85/S65 engines.
My M54 had 190k when I sold it. I had 2 N54s with over 100k, an N52 with 90k, and my current N55 that’s hitting 100k soon. Not worried in the slightest, and my miles are low compared to some local club members. I am way more worried about everything around the engine breaking than the engine itself.
Transport3r is offline   Reply With Quote
Old 05-19-2021, 10:03 PM   #46
Tokay444
That should also be of grave concern.
Old 05-19-2021, 10:24 PM   #47
Originally Posted by DarkPira7e View Post
After seeing those cars destroy oil (Admittedly, Mobil was shit, but I figured that out on my own) I don't believe in a standard interval unless it's activity based.
Haha... I use Mobile 1. It's the official NASCAR oil so it must be good.
Old 05-19-2021, 11:20 PM   #48
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
It's likely better now!
Old 05-20-2021, 12:26 AM   #49
Meh... I'll keep following my instincts. It lasts way longer now that I'm not cooking it.
Old 05-22-2021, 03:52 AM   #50
Limitless_BRZ
Limitless_BRZ's Avatar
Drives: Crystal White BRZ
Well, my bumper sorta fell of (quick release nut vanished) so i took my bumper off completely to work on it this weekend. Drove to work today, oil temps stayed at 170-175 the entire time..
Fabricator at JDL Auto Design
Limitless_BRZ is offline   Reply With Quote
The Following User Says Thank You to Limitless_BRZ For This Useful Post:
Ultramaroon (05-22-2021)
Old 05-22-2021, 04:24 AM   #51
Ha! Airflow! I knew it!!!
DarkPira7e (05-22-2021)
Old 05-22-2021, 01:16 PM   #52
DarkPira7e
DarkPira7e's Avatar
Those temps were ambient without the car running, he's just trying to make you feel good
Old 05-22-2021, 02:50 PM   #53
lolol.... Good times.
Now the hard part is figuring out how to restore flow that was lost with replacement of the bumper with a crash bar. Panel above and to each side of the bumper (beam) are deliberately designed to channel that flow.
Old 05-22-2021, 04:34 PM   #54
Limitless_BRZ
The original bumper is all good, but I like the temps Without bumper, now to make it Look good
Old 05-22-2021, 05:08 PM   #55
Not the cover/fascia, the beam. It was replaced by a crash bar, right?
Old 05-22-2021, 09:07 PM   #56
Limitless_BRZ
yeah, JDL bash bar
Oil Pressure drz400dude Engine, Exhaust, Transmission 9 04-30-2019 11:32 PM
Oil Pressure nearvincent Engine, Exhaust, Transmission 3 04-12-2017 08:46 AM
best tire pressure gauge (tire pressure question) steveholt Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 03-21-2015 11:27 PM
Stock clutch+flywheel+pressure plate+ ACT lightweight flywheel & pressure plate PineappleFriedRice Transmission and Driveline 0 11-08-2013 05:54 PM
Oil Pressure.. too low? Dave-ROR Tracking / Autocross / HPDE / Drifting 65 08-24-2013 01:43 AM
