| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
#43 | |
Persona Non Grata
Drives: '15 BRZ (WRB)
Slow is smooth, and smooth is fast
| The Following 3 Users Say Thank You to Capt Spaulding For This Useful Post: |
#44 | |
They're fine, for now... |
#45 | |
Drives: -
Oil pressure
Any M or N engine should make it to 200k easily. The bearing problems is mostly S54/S85/S65 engines. My M54 had 190k when I sold it. I had 2 N54s with over 100k, an N52 with 90k, and my current N55 that’s hitting 100k soon. Not worried in the slightest, and my miles are low compared to some local club members. I am way more worried about everything around the engine breaking than the engine itself. |
#46 |
That should also be of grave concern.
#47 | |
#48 |
Rust bucket enthusiast
It's likely better now!
#49 |
Meh... I'll keep following my instincts. It lasts way longer now that I'm not cooking it.
#50 |
Drives: Crystal White BRZ
Well, my bumper sorta fell of (quick release nut vanished) so i took my bumper off completely to work on it this weekend. Drove to work today, oil temps stayed at 170-175 the entire time..
Fabricator at JDL Auto Design
| The Following User Says Thank You to Limitless_BRZ For This Useful Post: | Ultramaroon (05-22-2021) |
#51 |
Ha! Airflow! I knew it!!!
| The Following User Says Thank You to Ultramaroon For This Useful Post: | DarkPira7e (05-22-2021) |
#52 |
Those temps were ambient without the car running, he's just trying to make you feel good
| The Following User Says Thank You to DarkPira7e For This Useful Post: | Ultramaroon (05-22-2021) |
#53 | |
![]() Good times.Now the hard part is figuring out how to restore flow that was lost with replacement of the bumper with a crash bar. Panel above and to each side of the bumper (beam) are deliberately designed to channel that flow.
#54 |
The original bumper is all good, but I like the temps Without bumper, now to make it Look good
#55 |
Not the cover/fascia, the beam. It was replaced by a crash bar, right?
#56 | |
yeah, JDL bash bar
| Oil Pressure | drz400dude | Engine, Exhaust, Transmission | 9 | 04-30-2019 10:32 PM |
| Oil Pressure | nearvincent | Engine, Exhaust, Transmission | 3 | 04-12-2017 07:46 AM |
| best tire pressure gauge (tire pressure question) | steveholt | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 19 | 03-21-2015 10:27 PM |
| Stock clutch+flywheel+pressure plate+ ACT lightweight flywheel & pressure plate | PineappleFriedRice | Transmission and Driveline | 0 | 11-08-2013 04:54 PM |
| Oil Pressure.. too low? | Dave-ROR | Tracking / Autocross / HPDE / Drifting | 65 | 08-24-2013 12:43 AM |
