Old 05-18-2021, 09:16 PM   #29
BrahmaBull1990
Howdy
BrahmaBull1990's Avatar
Drives: 2020 BRZ PP
Originally Posted by Capt Spaulding View Post
I'm not sure how much weight to put on the oil warming part of the JR's mission statement. Their oil cooler sits in the radiator and the water in the radiator is only going to get warm when the thermostat opens and that may take a while in cold weather.
If someone is really interested in temp "regulation," the best choice is still probably the Subie unit. They just need to make sure to plumb the cooler into the coolant bypass circuit. That water warms up much quicker than the radiator. Some implementations of the Subie cooler plumb it into the lower radiator hose. I don't think that is going to circulate water until the thermostat opens either.
Agreed. For my DD, no track application, my bigger fear is goosing it when the oil is too cold, not too hot.
There's a point at 7,000 RPM... where everything fades. The machine becomes weightless. Just disappears. And all that's left is a body moving through space and time. 7,000 RPM. That's where you meet it. You feel it coming. It creeps up on you, close in your ear. Asks you a question. The only question that matters. Who are you?
BrahmaBull1990 is offline   Reply With Quote
Old 05-18-2021, 09:25 PM   #30
deca
Drives: Halo 860
I run the JR dual cooler and while it has been perfect for my application I don't feel that it has much impact on warming up, if any. My car doesn't get driven in the winter, so I can't say if it would be more effective in truly cold temps. The coldest I've run in is the odd 40F-ish day in spring or fall.
My car is NA, catless header without any kind of wrap or heat shielding. On the street it hangs around 190F, on the highway it's usually between 200 and 205 depending on ambient. On track I'm stable in the 230s for full 20 minute+ sessions, down from 255+ after two hot laps prior to install.
deca is offline   Reply With Quote
Old 05-18-2021, 09:42 PM   #31
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Oil pressure
I didn't intend that to mean the JR dual's sole benefit was warming up the oil. I should have broken it down farther to say the JR setup has better temp regulation then an air to oil, but more thermal capacity then the oe forester unit, which I really don't consider much of a cooler.
Here is a shot of my water temp gauge after 3 hours of freeway driving in 50 degree weather. My oil temp only got to 140F using air to oil cooler. I am pretty sure the JR setup would have given me more "normal" temps, not that I really consider this that much of an issue periodically.
The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post:
BrahmaBull1990 (05-18-2021), Capt Spaulding (05-19-2021), Ultramaroon (05-18-2021)
Old 05-18-2021, 11:47 PM   #32
My completely arbitrary protocol is to keep the oil pressure as low as I can while still being able to drive until I can drive reasonably normally with it under about 100 PSI. The dump valve opens at 140 PSI and I've proven to myself that it's easy to hit that right after cold start when everything's super tight. Not that I'd ever want to but it doesn't take long for the engine to loosen up enough to redline safely.
It's a tight engine but it doesn't need to be babied. Maybe all modern engines are like that. Dunno.
BrahmaBull1990 (05-19-2021)
Old 05-19-2021, 12:03 AM   #33
Limitless_BRZ
Limitless_BRZ's Avatar
Drives: Crystal White BRZ
My cooler is mounted on the JDL bash bar, made some tabs for it and welded them on.
Limitless_BRZ is offline   Reply With Quote
The Following User Says Thank You to Limitless_BRZ For This Useful Post:
Ultramaroon (05-19-2021)
Old 05-19-2021, 12:07 AM   #34
Limitless_BRZ
Also thinking of upgrading mishimoto shroud fans to Spal ones. These temps are steady at 205
Fabricator at JDL Auto Design
Old 05-19-2021, 10:15 AM   #35
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Def, getting enough air flow then. I know the under tray mounted setups like mine get masked a bit by the bumper. The fans are not really going to make a difference unless you can force them on in stop/go traffic, and won't really make any difference moving. Vented hood will make a much larger difference. What also made a difference on my car was a splitter, car run runs much cooler with that on though I have a feeling it may not be as noticeable if my hood wasn't ducted already.
Old 05-19-2021, 01:26 PM   #36
Petah78
Drives: 2022 BRZ sport-tech
This. No one know if 40psi of oil pressure @ 7400rpm, 270F oil temp, is enough for the FA20.
Spec/test oil temp is 176 F (80 C). The whole boiling thing is just wrong. We don't bake our clothes to dry them. Oil pressure drops off sharply as temp increases but here's the rub. Is that bad? We really don't know because the operating limits aren't published.
All synthetic oils on the market today should be able to last 3500OCI with ease. I don't see how an oil cooler will have any tangible effects unless we are talking about a mostly tracked car.
I can say this for sure. Before my oil cooler, I could literally hear/feel my engine begin to rattle (queue the flamers) as the oil began to break down after about 3500 miles. I never even paid attention to the odometer. I just drove until I didn't feel comfortable with it anymore. Again, is that bad? I don't know, but the drop in viscosity was real.
With the cooler it feels fine right up to the 7500 mile interval. I've gone over because, again, I don't really keep track. I just go by feel. I wish I had done UOA before the cooler but I only considered it after I got involved with this forum.
Daijiro Katoh - Champion Forever!
Past: 92 EG w/JDM B18C, 00 EK w/JDM B18C, 04 600RR, 97 ITR #421, 10 Acura CSX-S, 17 BRZ
Current: 22 BRZ, 00 S2K - #0220
Petah78 is offline   Reply With Quote
The Following User Says Thank You to Petah78 For This Useful Post:
Wally86 (05-20-2021)
Old 05-19-2021, 02:51 PM   #37
I'm sure it's fine. Oil's cheap and I love my machine so if my ears and ass say it's time to change, it's getting changed.
Tracked or not has little to do with it. If the engine is operated in the upper range, the oil will get hot. Period. Just cruise in fourth gear for a couple minutes and watch the oil temp. Tangible effects right there.
Old 05-19-2021, 03:24 PM   #38
Petah78
Likewise. I change my oil every 3500 miles as well. But I think under "normal" street operation, I just don't see an oil degrading to the point where you can physically feel a difference (sounds/vibrations)? I did noticed smoother operation when I went from 0-20 to 5-30. And I do hoon my cars on the street.
Old 05-19-2021, 03:46 PM   #39
Transport3r
Drives: -
Oil pressure
Wow you guys love wasting oil I guess. My German cars see 10-15k mile intervals (as per documentation and the computer’s oil life algorithm) and they’re fine.
Any decent synthetic should be fine to 7500 miles at the very low end.
Transport3r is offline   Reply With Quote
The Following User Says Thank You to Transport3r For This Useful Post:
Old 05-19-2021, 06:50 PM   #40
The Following 4 Users Say Thank You to Ultramaroon For This Useful Post:
BrahmaBull1990 (05-19-2021), DarkPira7e (05-19-2021), NoHaveMSG (05-19-2021), Transport3r (05-19-2021)
Old 05-19-2021, 08:21 PM   #41
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
In previous cars (e36 and 3000gt vr4) the oil change interval depended on usage. The vr4 turned Mobil 1 5w30 into water within 1200 miles of really hard driving. E36 got its oil changed before an autocross, or after about 3k, whatever came first.
After I switched to amsoil dominator in the vr4, I managed 3k between intervals and the oil looked like oil still.
After seeing those cars destroy oil (Admittedly, Mobil was shit, but I figured that out on my own) I don't believe in a standard interval unless it's activity based.
Old 05-19-2021, 08:39 PM   #42
BrahmaBull1990
Howdy
Drives: 2020 BRZ PP
With the stupid prices I pay for “add-ons” to this car, it would be pretty lame to draw the line at early oil changes haha
The Following 6 Users Say Thank You to BrahmaBull1990 For This Useful Post:
Capt Spaulding (05-19-2021), DarkPira7e (05-19-2021), Jdmjunkie (05-20-2021), PulsarBeeerz (05-23-2021), rixter145 (05-25-2021), Ultramaroon (05-19-2021)
Oil Pressure drz400dude Engine, Exhaust, Transmission 9 04-30-2019 11:32 PM
Oil Pressure nearvincent Engine, Exhaust, Transmission 3 04-12-2017 08:46 AM
best tire pressure gauge (tire pressure question) steveholt Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 03-21-2015 11:27 PM
Stock clutch+flywheel+pressure plate+ ACT lightweight flywheel & pressure plate PineappleFriedRice Transmission and Driveline 0 11-08-2013 05:54 PM
Oil Pressure.. too low? Dave-ROR Tracking / Autocross / HPDE / Drifting 65 08-24-2013 01:43 AM
