Old 05-11-2021, 10:35 AM   #1
frostyfrs
Drives: Supercharged 2013 Scion FR-S
Best way to make 300hp out of Innovate SC?
Is this even possible? I'm trying to figure out the best path to take and what internal parts I should upgrade or install to make this possible. Open to all the help I can get with recommendations!
frostyfrs is offline   Reply With Quote
Old 05-11-2021, 11:37 AM   #2
bfrank1972
Drives: 2013 FR-S Argento
300 "crank" or "wheel"? Crank it should be close to 300 with stock pulley 93 octane and a good aftermarket tune. 300whp is possible but you'll probably need to go E85 + catless header + good custom tune.
Old 05-11-2021, 12:27 PM   #3
frostyfrs
To the wheels. I have catless headers, I just dont have access to e-85, its just not around in my area.
Old 05-11-2021, 01:18 PM   #4
JSIdriver51
Drives: 2014 Subaru BRZ WRB
It is possible. However, you will need to run e85 or WMI with the 69mm pulley for the 210 kit, exhaust and intake (maybe injectors and FP). Additionally, I would recommend clutch, vents/vented hood, ceramic coated header at least, oil cooler, pcv catch can, coil packs, heat reflective tape on the intake pipe, and the Perrin Intake to mitigate the heat soak.
If you don’t already have the kit I would recommend just jumping up to the 335 kit. Get the 90 or 85mm pulley and it’ll leave you at 300/300ish (this is more than then 300/240 top end of the 210 kit). You will just need clutch, FP and injectors; the other parts I mentioned would also be highly suggested, as well as e85/WMI.
Lastly, get a good tuner: I am tuned by Mike from Moto-East (now Xero Limit) and he probably has the most experience with the Sprintex Kits. Otherwise, Bill at Delicious or Zach at CSG will be your next best bets
JSIdriver51 is offline   Reply With Quote
Old 05-11-2021, 05:10 PM   #5
bfrank1972
Good advice, especially on Mike - he has a thread somewhere on here (older) on the 335. I think I remember reading that it's a much bigger unit and thus loads the engine more to power it, which increases stress on the motor to reach a certain power level. Translation, a 335 unit might bring you closer to the point where you'll need to build the motor for FI. Realistically, if you don't have E85 and you're new to aftermarket FI (not saying you are necessarily) then you might want to lower your expectations to somewhere around 250+/- on pump gas with the Sprintex units. Still will be plenty quick btw. Going about that without E85 requires a lot more complexity and you're pushing the limits of the blower at 300 whp.
Old 05-11-2021, 05:51 PM   #6
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
The way these make power down low, you're going to want to build or have a conservative tune. These win the "most likely to blow an engine" award.
The Following User Says Thank You to EAGLE5 For This Useful Post:
kev0 (05-12-2021)
Old 05-12-2021, 07:17 PM   #7
kev0
Drives: '14
Pretty sure 69mm pulley will get you pretty close to 300 to the wheels. As EAGLE5 said, these make a lot of power down low so if your tuner is good, he'd make sure the power delivery isn't too much down low for the sake of your rods.
kev0 is offline   Reply With Quote
Old 05-12-2021, 08:13 PM   #8
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
At the top of this section there is a sticky'd thread "FI Dyno Thread" that shows how much power they made, what parts, PSI, fuel, who tuned it, and other ancillary items they ran on the car. If you can't figure it out from that I don't know if you can be helped.
Anyone blow a stock engine running 8 psi(<300HP) mrloko Forced Induction 42 12-25-2020 07:02 PM
FRS Turbo, Supercharger or none? Trying to get 300HP. Elliryx Forced Induction 22 09-06-2015 02:15 AM
300HP Jackson Supercharged BRZ neroman98 BRZ First-Gen (2012+) — General Topics 18 08-03-2015 08:28 PM
300hp vs 380hp evo sosick Tracking / Autocross / HPDE / Drifting 20 08-12-2014 08:35 PM
Innovate OT-2 jamesm Engine, Exhaust, Bolt-Ons 0 12-03-2013 11:38 AM
