Drives: 2017 Subaru BRZ
Anyone blow a stock engine running 8 psi(<300HP)
As title states, has anyone blown a stock engine running a conservative 8 psi tune with less than 300 hp? if you did was it due to the tune or the engine internals just gave up? I searched but only found threads dating to the earlier years of the twins and people mostly seemed to have issues with tunes or really pushing the engine past 350hp
Anyone who has a simple turbo setup with low psi and <300 hp, how has the engine managed and has anyone have over 50k boosted at this low power level? Thank you guys very much for your input!!! |
Drives: 2013 frs
I bent a rod at 7psi with a bull blown stage one kit.
But it can happen to anyone honestly. I have a friend making 400 on stock block 14psi Sent from my iPhone using Tapatalk |
Drives: 2013 frs
Drives: 2018 Subaru BRZ tS
What kind of FI installation? What brand? What were the conditions when it failed?
Drives: 2013 frs
Lmfao 13 frs full blown stage one with GTX28 didn’t even have 30k on the car. After I bent the rod I took engine apart and built it. when I went to start I found out why I bent a rod and it turned out that I had a direct fuel injector staying stuck open at times
Woahh man that's a huge bummer, it wasn't even the power you were pushing but just a malfunction damn. Do you think that it had something to do with the tune?
#9 | |
Drives: 2013 frs
No it was a mechanical failure in the injector. Took them to get flow tested and the one that bent the rod was stuck open pretty bad. James even told me that was the first direct injector he ever saw stay stuck open. Coming from him that he’s tuned a lot of these cars means it’s really not common at all |
#10 |
Anti stance.
Does it have to be specifically 8psi?
#11 |
Rust bucket enthusiast
If you cannot afford to replace an engine, do not go FI. yes, people get lucky. More people get unlucky. There's a reason more cars in the world don't just get a turbo slapped on them: the cost of entry into the carnival is the cheapest part of the endeavor.
Boost for the most part is irrelevant. Knock, af/r, supporting mods, the tune, not making a ton of wtq low in the rpm bands are things that contribute to survival chances if TUNED correctly. If you don't have catch cans and oil enters your intake, you get knock; oil lowers your octane significantly. Oil supply is tied to rpm; low rpm high load conditions mean the weak rods sustain more load for longer. This is the surface of theories, rumors, facts, and things you need to consider when you think you'll take a coin flip and go turbo. |
#12 |
#13 | |
I agree with you that it all comes down to how well you maintain the turbo and how much thought you put into the lines and cooling and tune. |
#14 | |
| Slight engine stutter when AC is running? | select20 | Issues | Warranty | Recalls / TSB | 19 | 08-18-2016 11:46 PM |
| FRS Turbo, Supercharger or none? Trying to get 300HP. | Elliryx | Forced Induction | 22 | 09-06-2015 01:15 AM |
| 300HP Jackson Supercharged BRZ | neroman98 | BRZ First-Gen (2012+) — General Topics | 18 | 08-03-2015 07:28 PM |
| Car running poorly after check engine light cleared | AlexK | Engine, Exhaust, Transmission | 4 | 07-07-2015 03:16 AM |
| 300hp vs 380hp evo | sosick | Tracking / Autocross / HPDE / Drifting | 20 | 08-12-2014 07:35 PM |
