Old 03-21-2021, 02:33 PM   #1
holeeray
holeeray's Avatar
Drives: 2015 BRZ Limited
Not too sticky tire recommendation?
I'm looking for a set of tires that aren't super sticky so I can break the rear loose on stock power, but will break grip progressively. I'm also planning on doing some AutoX for fun this season so not complete woodplanks (not looking to be competitive, just want to learn the car) . Decent rain performance would be a plus as well.
Not huge factor, but I prefer a stiffer sidewall that puts a bit more burden on mechanical grip.
Bone stock
holeeray is offline   Reply With Quote
Old 03-21-2021, 03:29 PM   #2
soundman98
ProCrastinationConsultant
soundman98's Avatar
i'm loving my bridgestone comp2 a/s.
holeeray (03-21-2021)
Old 03-21-2021, 06:16 PM   #3
Grawlix
Drives: '14 fr-s \\ 6mt \\ white
GT Radial Champiro SX2 in the stock size: Good grip but not a 200tw tire, they start making noise well before they lose grip so you will not be surprised when approaching the limit. They are track tested, as they were/are the contingency tire for the 86 Cup, and cheap to boot. They also do well in the rain. I'm on my second set.
Grawlix is offline   Reply With Quote
The Following 2 Users Say Thank You to Grawlix For This Useful Post:
holeeray (03-21-2021), jflogerzi (04-25-2021)
Old 03-21-2021, 06:20 PM   #4
holeeray
holeeray's Avatar
Damn, never heard of these. Thanks for the recommendation, they look really promising.
Bone stock
Old 03-21-2021, 06:50 PM   #5
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Conti ECS.
NoHaveMSG is online now   Reply With Quote
holeeray (03-22-2021)
Old 03-22-2021, 11:40 PM   #6
wil5bart
Drives: '16 BRZ
I bought my Continental ECS from 4wheelonline last year. For daily driving, these tires are excellent. Wet performance is another strong point. Went to an autocross last summer and they did fairly well, although I can say that the PS4S has more grip.
wil5bart is offline   Reply With Quote
The Following 2 Users Say Thank You to wil5bart For This Useful Post:
Goingnowherefast (03-23-2021), holeeray (03-23-2021)
Old 03-23-2021, 01:50 AM   #7
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
I tried out bfg rival s 1.5 this weekend with stock power, 245/40/17, no problems breaking the rear end loose, no problem when I use re71rs either. If it feels grounded to the ground you can drive faster.
Falken rt660s would be my choice for you, if you're real nervous about sticky tires for whatever reason the 615ks are a step down. I have ECS now and the sidewalls are the softest I've put on the car, pss and oe primacy and indy 500s were stiffer, ecs are good tires though, I think the tire you are asking for is the ps4s but I think you'd be happy on the falken 660 which are way cheaper and are actually competitive.
ineedyourdiddly
The Following 2 Users Say Thank You to strat61caster For This Useful Post:
holeeray (03-23-2021), NoHaveMSG (03-23-2021)
Old 03-23-2021, 02:46 AM   #8
Israel Moore
Drives: 2015 Subaru BRZ Limited
Most of the people I know prefer sticky tires. You may want to check out Goodyear Viva 3 A/S tires and Falken Azenis RT615K+.
Israel Moore is offline   Reply With Quote
Old 03-23-2021, 11:34 AM   #9
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I noticed that too, but I was happy with their mixed weather performance for a summer tire that I could overlook it. I know @ZDan runs them for TT, or had at one time and like them as well.
Old 03-23-2021, 12:03 PM   #10
ZDan
ZDan's Avatar
Drives: '23 BRZ
I was gonna run them in a slower class, but then friend o mine got Pirelli slicks so I ran A7s for TT
I tracked on the ECS on non-time-trial days though. They're pretty good, obviously a couple/few seconds behind the best 200tw tires. Hold up well to 15 minute lapping sessions, gonna use them this year as well for non-TT days.
Old 03-23-2021, 12:30 PM   #11
RayRay88
Drives: 2017 86 860 Special Edition
Can you speak about the soft sidewall in terms of feedback and input especially vs the oem primacy's which are notoriously stiff. Also what type of target hot pressure's were you using at the track. Looking for a sticky daily tire on OEM wheels but something that won't shit the bed on the few track days I plan on doing this year. With the amount of daily driving I do I can't justify tearing up a set of 200tw tires. Plus need something with decent wet performance/hydroplaning resistance.
RayRay88 is offline   Reply With Quote
Old 03-23-2021, 12:48 PM   #12
ZDan
ZDan's Avatar
Drives: '23 BRZ
Good feedback, not RE71R level of course... I don't think the sidewalls are particularly soft, I thought they felt fine at the track. More so after worn down a bit, thinking back my first sessions on them were a little squirmy. 36psi hot pressures.
They've held up great, I did 4 track days on them last year and probably ~5000 street miles, just checked them and they're all ~4/32nds tread depth. Remarkably even wear across the treads and between the four tires, I musta been good about rotating them when swapping back and forth with the Hoosiers. -3.5F and -2.8 rear camber.
RayRay88 (03-23-2021)
Old 03-23-2021, 07:30 PM   #13
ZDan
ZDan's Avatar
Drives: '23 BRZ
I had to time-trial on the Contis last event last year as I flat-spotted a Hoosier to the cords (doh!). First non-podium in forever :'( Anyway, looking at results I would have won T40 class (which I was legal for with the Contis) by *20 seconds*!
https://www.comscc.org/events/result...?id=2020-11-01
Yeah, they're pretty good...
The Following 3 Users Say Thank You to ZDan For This Useful Post:
churchx (03-25-2021), Ohio Enthusiast (03-23-2021), RayRay88 (03-24-2021)
215 or 225 sticky tire for a 7.5x17 wheel? ThaDonJsuan Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 46 04-01-2021 11:18 PM
Tire Recommendation 8inchAzN Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 17 05-05-2018 10:02 PM
Tire recommendation EzyBrzy Northern California 30 03-31-2018 10:16 PM
Summer Tire Recommendation Is Always Angry Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 07-23-2017 06:22 PM
Tire recommendation help Davesta619 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 10-21-2016 07:32 PM
