Old 10-25-2020, 02:59 PM   #1
ThaDonJsuan
Drives: 2020 Subaru BRZ Sport-tech
215 or 225 sticky tire for a 7.5x17 wheel?
Hi all,
I have stock rims that are 7.5/17 and currently with a 215 stock tires which need upgrading. For the track, would you go with a 215 or 225 tire? Some said the 225 is good and others say just stick with 215. Not sure what I should do.
ThaDonJsuan is offline   Reply With Quote
Old 10-25-2020, 03:32 PM   #2
TommyW
TommyW's Avatar
Drives: '13 Whiteout
How much track experience do you have?
Old 10-25-2020, 03:35 PM   #3
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
I had Falken Azenis RT615K in 225/45 on stock size wheels and loved them. Depends what you're looking for though. 225 is good
Old 10-25-2020, 03:59 PM   #4
Breezio
Breezio's Avatar
Drives: 2017 BRZ series.yellow
225/45 all the way on a '17+ with 7.5" wheel width.
Breezio is offline   Reply With Quote
Old 10-25-2020, 06:29 PM   #5
ThaDonJsuan
Ive only gone 5 times to the track but my tires are shredded. Pieces of rubber peeled off during my last session so I need new tires.
Old 10-25-2020, 07:08 PM   #6
TommyW
TommyW's Avatar
then I’d go with a 225 but not super sticky yet
Old 10-26-2020, 10:48 AM   #7
CrowsFeast
CrowsFeast's Avatar
Drives: 2013 BRZ Sport-Tech
https://www.ft86motorsports.com/wheelitfit/
225's look a bit pinched to me. I'd also recommend not going to 200 tw but stick with 215's.
CrowsFeast is offline   Reply With Quote
Old 10-26-2020, 01:42 PM   #8
Ernest72
Drives: 16 Silver BRZ, 04 Silver WRX wagon
I would stay 215s because lighter.
Ernest72 is offline   Reply With Quote
Old 10-26-2020, 01:58 PM   #9
ZDan
ZDan's Avatar
Drives: '23 BRZ
For me, 225/45 on 17x7.5, 215 on 17x7.
Tire make/model WAY more important than 225 vs 215...
Also, get some front camber before going to the track!
The Following 3 Users Say Thank You to ZDan For This Useful Post:
Plumbus (02-18-2021), Racecomp Engineering (10-27-2020), ScoobsMcGee (10-26-2020)
Old 10-26-2020, 06:02 PM   #10
TommyW
TommyW's Avatar
225 45 is recommended for 7"-8" wheels. You CAN go with 215 however nothing wrong with 225
Old 10-26-2020, 11:34 PM   #11
Decep
Drives: 2013 FR-S Series 10
215 will feel sharper and is lighter too.
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers
Corsa Catback
Edelbrock Supercharger installed @ 50k
Old 10-27-2020, 09:53 AM   #12
ZDan
ZDan's Avatar
Drives: '23 BRZ
I just looked at four Extreme Perf tires on Tire Rack. Two of them are 1 lb. heavier in 225 vs. 215, the other two are same weight either size. You're not gonna feel that... On a given wheel width, the 225 will be slightly more "pooched" and have very slightly less stiff sidewalls, but will yield a smidge more ultimate grip and should give slightly more grip per slip angle after turn-in.
For *me*, for best balance of aesthetics, feel, and performance, I'd go 225 on a 7.5" wheel, 215 on a 7" wheel.
The Following 2 Users Say Thank You to ZDan For This Useful Post:
DarkPira7e (10-27-2020), dragoontwo (10-27-2020)
Old 10-27-2020, 10:13 AM   #13
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
I only have one thing to add to what you say, and that's to not forget that tires may run wide or narrow for a given size. I just had some 215 put on 8" wheels, and the sidewalls are slightly "pooched". Continental DWS 06 for reference. I still haven't measured the tread width to see the actual size.
dragoontwo is offline   Reply With Quote
Old 10-27-2020, 11:18 AM   #14
TommyW
TommyW's Avatar
I had a coach at Laguna Seca a couple years ago that had a BRZ and liked the 215’s. I let him drive my car when it had 225’s while I rode right seat. He was due for tires soon and said he was going to 225’s after that.
Understand there are several factors that will determine what tires will work best for each car/driver
Performance package wheel/tire weight vs. regular wheel/tire combo qqzj Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 09-26-2019 02:27 AM
Wheel Directory: MIM TecnoMagnesio Sao Paulo 7,5X17 +35 Daria Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 04-14-2015 04:13 PM
General wheel questions (Yes I have read the sticky's) milleniacinder Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 07-13-2014 05:53 PM
Steering wheel/dashboard getting sticky in the heat. daftpunk Issues | Warranty | Recalls / TSB 15 06-26-2014 06:58 PM
WTB: One FR-S OEM 17'' Wheel (don't need tire) brillo Wheels and Tires 1 09-17-2013 10:32 PM
