go_a_way1
Old 01-26-2021, 07:35 PM   #4341
meWant
Drives: '16 BRZ Limited
Originally Posted by DarkSideFRS View Post
-1.6 will prob hit. -1.4 is cutting it close.
For your reference, i had 17x9 +38 rims with 245/40R17 tires. Max camber i could run was -1.7 before the rims hit the shock perch
I'll keep that in mind, I don't remember exactly how much camber is up front as it has been a bit since an alignment.
update: found my alignment sheet. I'm at -0.4 deg of camber up front and -2.1/-2.2 in the rear
meWant is offline   Reply With Quote
Old 01-26-2021, 07:42 PM   #4342
DarkSideFRS
Drives: 2013 pearl white FR-S
i thought OEM specs call for at least -1 of camber up front? lol
DarkSideFRS is offline   Reply With Quote
Old 01-26-2021, 07:46 PM   #4343
meWant
lol I'm not sure about that, I just fount my alignment sheet when I had it done.
Old 01-27-2021, 10:52 AM   #4344
Vital
Drives: 2015 BRZ
Was this on coilovers or stock shocks and springs?
OEM specs from the fronts dont really have much camber it is usually less than -1 its very conservative the rears might get around -1 if you're lucky.
Old 01-27-2021, 02:14 PM   #4345
DarkSideFRS
stock shocks with TRD springs and camber bolts
The Following User Says Thank You to DarkSideFRS For This Useful Post:
Vital (01-27-2021)
Old 02-04-2021, 01:58 PM   #4346
DomBRZ
Drives: 2013 BRZ Limited
Wanted to check with the experts before buying a set of Varrstoen ES2 18x9.5 +34. They are wrapped in 245/40 tires and i’m on full stock suspension. Any help is greatly appreciated!
DomBRZ is offline   Reply With Quote
Old 02-04-2021, 02:51 PM   #4347
Vital
Drives: 2015 BRZ
Yep it will fit. Just remember it will poke a lot in the front and look like a 4x4
Old 02-06-2021, 03:48 PM   #4348
DomBRZ
Thanks! Is there a way reduce the poke, or will I need to find some wheels with less width for the front?
Old 02-07-2021, 03:21 PM   #4349
Vital
Drives: 2015 BRZ
Yes correct, you will need to find wheels what are not as wide. Also once you lower a car it kinda reduces the poke naturally or you can run negative camber to tilt the wheels in the fender a bit but with stock suspension you will not be able to get much camber with that wheel and tire size. Not sure if you plan to lower your car or not, but if you are not then stick to a more conservative wheel and offset.
Old 02-22-2021, 05:46 AM   #4350
Dphillips1127
Drives: Soon BRZ
I have a 13’ BRZ. I plan on running the following:
-Sportline springs
-KYB Struts
-17x9+35 TC105X
-255/40/17 continental extreme contact sport tires
Will these fit with the 1.5” drop? I am looking for something as flush as possible. Any tips would be appreciated. Thanks!
Dphillips1127 is offline   Reply With Quote
Old 02-22-2021, 10:17 AM   #4351
Vital
Drives: 2015 BRZ
-Sportline springs
-KYB Struts
-17x9+35 TC105X
Yes that will fit fine.
The Following User Says Thank You to Vital For This Useful Post:
Dphillips1127 (02-22-2021)
Old 03-02-2021, 12:47 PM   #4352
Lopeskii
Lopeskii's Avatar
Drives: Toyota 86
Besides the speedo being off will this setup fit without any rubbing or other issues ?
18x8.5+35 Artisa Art-formed Carriers
245/40/18 or 235/40/18 tires
Eibach Sportline springs
Lopeskii is offline   Reply With Quote
Old 03-04-2021, 10:26 AM   #4353
Vital
Drives: 2015 BRZ
It will fit fine. Only thing i would suggest is maybe getting a 245/35/18 tire or a 225/40/18 tire. Only reason I suggest those size tires is because they are close to stock tire size specs.
Old 03-06-2021, 03:09 PM   #4354
CannibalPie
Drives: 2018 BRZ Premium
Upgrading from stock wheels and suspension.
17x8.5+45 TE37 Sagas (square setup)
245/40/17 Tires
Tein Flex Z Coils (likely a 1'' drop, want to retain daily drivability)
Any concerns?
CannibalPie is offline   Reply With Quote
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 10:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 03:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 03:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-13-2012 12:21 AM
