| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#4341 | |
Drives: '16 BRZ Limited
update: found my alignment sheet. I'm at -0.4 deg of camber up front and -2.1/-2.2 in the rear Last edited by meWant; 01-26-2021 at 06:39 PM. Reason: alignment details |
#4342 |
Drives: 2013 pearl white FR-S
i thought OEM specs call for at least -1 of camber up front? lol
#4343 |
#4344 | |
Drives: 2015 BRZ
OEM specs from the fronts dont really have much camber it is usually less than -1 its very conservative the rears might get around -1 if you're lucky. |
#4346 |
Drives: 2013 BRZ Limited
Wanted to check with the experts before buying a set of Varrstoen ES2 18x9.5 +34. They are wrapped in 245/40 tires and i’m on full stock suspension. Any help is greatly appreciated!
#4347 |
Drives: 2015 BRZ
#4348 |
#4349 |
Drives: 2015 BRZ
Yes correct, you will need to find wheels what are not as wide. Also once you lower a car it kinda reduces the poke naturally or you can run negative camber to tilt the wheels in the fender a bit but with stock suspension you will not be able to get much camber with that wheel and tire size. Not sure if you plan to lower your car or not, but if you are not then stick to a more conservative wheel and offset.
#4350 |
Drives: Soon BRZ
I have a 13’ BRZ. I plan on running the following:
-Sportline springs -KYB Struts -17x9+35 TC105X -255/40/17 continental extreme contact sport tires Will these fit with the 1.5” drop? I am looking for something as flush as possible. Any tips would be appreciated. Thanks! |
#4351 | |
Drives: 2015 BRZ
| The Following User Says Thank You to Vital For This Useful Post: | Dphillips1127 (02-22-2021) |
#4352 |
Drives: Toyota 86
Besides the speedo being off will this setup fit without any rubbing or other issues ?
18x8.5+35 Artisa Art-formed Carriers 245/40/18 or 235/40/18 tires Eibach Sportline springs Sent from my iPhone using Tapatalk |
#4353 |
Drives: 2015 BRZ
It will fit fine. Only thing i would suggest is maybe getting a 245/35/18 tire or a 225/40/18 tire. Only reason I suggest those size tires is because they are close to stock tire size specs.
#4354 |
Drives: 2018 BRZ Premium
Upgrading from stock wheels and suspension.
17x8.5+45 TE37 Sagas (square setup) 245/40/17 Tires Tein Flex Z Coils (likely a 1'' drop, want to retain daily drivability) Any concerns? |
| Tags |
| fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width |
| Determining the proper width size of the tire | CyberFormula | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 49 | 05-23-2014 09:11 AM |
| Correct tire width for each wheel width | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 08-16-2012 02:03 PM |
| TIRE SIZE CALCULATOR | White64Goat | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 08-15-2012 02:31 AM |
| Tire Width vs Wheel Width | Synack | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 40 | 08-12-2012 11:21 PM |
