| DIY (Do-It-Yourself) Guides For all DIYs. |
#15 | |
Drives: 2017 toyota 86
#16 |
Drives: 2014 MY15 86 GTS
I got it to work by telling it was a 2017 Toyota 86 in the app, it displayed data is this correct way of doing it since its a 2014?
I noticed the transmission temp reaches past check temp quickly. |
#17 |
You have enough time to do the leveling process but you got to go fast. It helps if you are already under the car setup ready to go and have a 2nd person turn car on and watch temps yelling when its 108 and can make sure you’re done before 117F, first time i did it i was too slow, mostly because of how overfilled i had it before leveling it, it took a while to drain. Had to stop, cool down, and level again.
#18 |
Does anyone know with a bluedriver and app where trans temp is located under live data.
#19 |
Here is the PID for it. works with scangauge, not sure about anything else.
#20 |
Drives: Ultramarine FR-S
@86TOYO2k17. You are a lifesaver. Hopefully this PID works on the OFT
#21 | |
Drives: GT86
Per Nm values in the service manual (SM): Refill plug: 39Nm / 28.76 ft-lbs Overflow plug: 20Nm / 14.75 ft-lbs (incorrectly converted to 27.3 ft-lbs in SM) Drain plug: 20Nm / 14.75 ft-lbs (incorrectly converted to 7.4 ft-lbs in SM) I unfortunately used 27 ft-lbs for my drain plug and stripped it....lesson learned. Hope no one else makes the same mistake!
#22 | |
Ouch. I followed the torque specs I had posted and didn't have any issues, but to be fair I followed what was in the guide inside techstream. You are quite correct that the Toyota official instructions incorrectly convert from metric to standard. Quite an oversight. I'll update my OP. |
#23 |
Does anyone else's trans make a bad crunchy noise when putting it in park only when in fluid level check mode?
#24 |
Drives: 2017 Toyota 86
Great write up, however, when I order the gaskets this is what I got. None of these were correct. The drain and overflow plugs are actually crush washers, both the same size. The fill plug is an o-ring, but none of these were correct.
| The Following User Says Thank You to Daily86 For This Useful Post: | Tristor (02-07-2021) |
#25 | |
Howdy, Sorry about that. I'm not sure if these part numbers changed or what. I just looked it up and the drain and overflow plugs both use the same crush washer which is part number 17008AA000. I'm still looking to find the o-ring for the fill plug. The good news is you can re-use the ones that are on there without too much trouble, usually. |
#26 |
Reused at least a half dozen times with no issues.
#27 |
I did reuse the original parts. No worries. Just wanted to get the information out.
Sent from my SM-G930V using Tapatalk |
#28 | |
Drives: Rallye Blue BRZ
I went to the Subaru dealer yesterday for crush washers and fluid. They didn't know what fluid or know what crush washers I needed. They said they have never worked on a auto BRZ....Go to Toyota to get the stuff. So my local dealer still doesn't have a procedure for the auto fluid change..... So I went to Toyota and they had the fluid, but no idea on the crush washers. Supplied me with a tray of 20 or so different ones and asked me to pick out the ones I wanted. Then he asked why come to them, it's a Subaru.....
| Automatic Transmission Fluid Cooler. ?? | connor_lol | Engine, Exhaust, Transmission | 177 | 01-02-2023 10:02 AM |
| Automatic Transmission Fluid Change | jmaryt | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 169 | 08-26-2018 08:55 PM |
| Automatic Transmission Fluid, is this what you use? | qijian | Engine, Exhaust, Transmission | 2 | 11-30-2017 02:41 AM |
| AUTOMATIC transmission fluid change DIY?? | qijian | DIY (Do-It-Yourself) Guides | 3 | 08-31-2017 09:34 AM |
| AUTOMATIC TRANSMISSION FLUID? How many L | ScionFR-S | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 5 | 02-21-2015 01:43 AM |
