Old 01-10-2021, 01:22 AM   #1
Hamza
Hamza's Avatar
Drives: Widebody 86/F56 Mini Cooper S
Lowering the Rear
Hey so I bought my '13 86 off of a guy who had the stock coils chopped, and it has aftermarket wheels. I bought Tein advance Z's so I can adjust but now I'm having issues on the rear.
1. I remember reading somewhere that the rear cannot be lowered more than 1.5" from stock in the rear before you get into territory of risk breaking the dif axle connection. Is this true? I'm trying to ever avoid the need of any dif risers of some sort.
2. Now if I need to stay within the 1.5" range, how do I measure the height to compare to stock?? As in, the wheels have an effect on the height so I'm confused that I can't just compare directly?
Any help would be greatly appreciated
Hamza is offline   Reply With Quote
Old 01-10-2021, 06:48 AM   #2
marco_mc22
Drives: Toyota 86
Rear stock from hub center to fender is 372mm (14.6in) with gas filled up and spare tire in, I wouldn’t lower the rear more than 1.4in
marco_mc22 is offline   Reply With Quote
The Following User Says Thank You to marco_mc22 For This Useful Post:
Hamza (01-12-2021)
Old 01-10-2021, 09:14 AM   #3
Hamza
Hamza's Avatar
What if I don't got a spare tire
Was just thinking shouldn't the center of the hub stay the same regardless of the wheel and I just measure that to the fendor?
Old 01-10-2021, 08:19 PM   #4
Turdinator
Señor Member
Turdinator's Avatar
Its still gives you a max low point to use.
Yes, that is why he gave you that dimension and why its generally used to determine ride heights.
The lower you go the quicker you will wear out the CV joints in the rear axle and obviously the worse the car will deal with bumps. Are you racing the car or more of a cruiser or daily driver? Are you on stock or near stock power?
1974 TA22 Celica
2013 86 GT
The Following User Says Thank You to Turdinator For This Useful Post:
Hamza (01-12-2021)
Old 01-12-2021, 01:23 AM   #5
Hamza
Hamza's Avatar
Ahhhhh sorry my bad I read it as thinking he meant put the spare tire instead of my wheels and measure. But makes sense, thank you very much!!
And I'm practically stock power. When I bought the car it had a widebody on and I just wanted to get rid of as much fendor gap as I could (I'm not slammed in any way). I sort of daily it, but it's honestly a max of a 20 minute drive a day. Not racing on it.
Old 01-12-2021, 06:30 PM   #6
Turdinator
Señor Member
Turdinator's Avatar
Keep in mind the wide body might change the fender height.
Honestly if you are daily driving it just lower it until you are happy with the look and call it a day. Personally I would try and keep about 2 fingers gap from the top of tire to the fender tho. And make sure you get it aligned asap after you have settled on a height.
1974 TA22 Celica
2013 86 GT
Hamza (01-13-2021)
Old 01-13-2021, 08:16 AM   #7
Hamza
Hamza's Avatar
Noted! Appreciate it!!
Old 01-23-2021, 10:51 AM   #8
Hamza
Hamza's Avatar
Okay I've been fiddling with it and trying different thing but now the confusion has come again.
On the Tein specs, it says the max rear drop is 3". I measured before changing anything and I was at 37 cm from hub to fendor. I've dropped the coil as much as I could in a safe region, but now it's at 2 cm from being completely bottomed out, however the distance from the hub to fendor is still 36ish cm. The numbers don't add up because if I drop 2 cm more (bottom out the coil) I'll be at 34 cm, which isn't nearly 3 inches that the coil is capable of.
Old 01-24-2021, 12:06 AM   #9
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Dumb question.
These have all been measured with the car on the ground right?
Please provide pic of what you have it set to.
Old 01-24-2021, 04:44 PM   #10
Hamza
Hamza's Avatar
Originally Posted by x808drifter View Post
Dumb question.
Yeah yeah ofcourse it's measured with the car on the ground. I can't take a picture right now but I'll attach what I measured. Before the coils that was at about 370mm and now after dropping the coil to only 2 cm of threads left, it's at 360mm (so changing the coil threads by about 3 cm only changed 1 cm of ride height). I'm really curious to what the 3" measurement Tein says of max drop but it doesn't seem like these coils go far enough to break axles?
Old 01-25-2021, 12:29 AM   #11
Turdinator
Señor Member
Turdinator's Avatar
Is that lowering the spring perch, the mounting point or both?
1974 TA22 Celica
2013 86 GT
Old 01-25-2021, 05:01 AM   #12
x808drifter
LMGTFY
This is why I want pics of the suspension.
The Following 2 Users Say Thank You to x808drifter For This Useful Post:
Wally86 (03-03-2021), wparsons (01-25-2021)
Old 01-26-2021, 10:04 PM   #13
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
@Hamza Does the installation manual have a reference on how to set-up the preload and height adjustment collars to factory recommendation? If there are, it will also tell you where the car will sit relative to stock when set-up according to the recommendation. This will be part of the total drop the coils are capable of.
Then, you can adjust from there using the lever ratio (1:1 in the front, 1:1.3 in the rear)
EndlessAzure is offline   Reply With Quote
Old 01-29-2021, 03:31 PM   #14
Hamza
Hamza's Avatar
The spring as far as I know
lowering without aftermarket rear control arms littlealex Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 11-26-2019 03:53 PM
Toyota 86/Scion FR-S TRD Lowering Springs & TRD Sway Bar Kit -Front and Rear burgeralert Brakes, Suspension, Chassis 5 03-28-2019 11:16 PM
Uneven rear camber after lowering springs Euphues Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 11-11-2015 09:27 PM
Any way to lower rear lowering springs further? BlueDubbinTDI Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 02-03-2014 10:03 PM
Rear camber after lowering mike_ekim1024 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 06-09-2013 05:01 AM
