Old 01-02-2021, 08:06 AM   #981
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
Originally Posted by Enrgkid View Post
Hi Guys,
Came here looking for a way to change my OFT to display Metric units and potentially locate a better tune for my BRZ with UEL headers and drop in filter, trying to decode, but this isn't making a whole lot of sense.
I'm in AUS and can't seem to work out how to edit my Definition files to metric. though I don't imagine that would change my OFT real time display.
Can't change the OFT display from imperial.
Old 01-04-2021, 02:29 AM   #982
ninjan00dles
Drives: 2015 FRS
Long live the empire
ninjan00dles is offline   Reply With Quote
The Following User Says Thank You to ninjan00dles For This Useful Post:
ML (01-04-2021)
Old 02-10-2021, 11:11 PM   #983
86Quad
86Quad's Avatar
Drives: 16 fr-s 97 sc300
I’m new to this software stuff. I’m trying to find a more step by step process of how to get this done. 2016 frs I have the tactrix open port 2.0 downloaded ecu flash and that’s as far as I’ve gotten. Looking now just to flash an oft tune or something similar. Thanks!
86Quad is offline   Reply With Quote
Old 02-12-2021, 06:28 PM   #984
steve99
Drives: FT86
You need to download and install ecuflash on a windows pc. Install flash definitions
then you can read and write your ecu. Suggest you read first to find your current ecu calibration id
Then you need a matching\compatable tune file to write to ecu
if you need tuned roms and definitions can supply for small fee jist message me
Old 02-12-2021, 06:31 PM   #985
Enrgkid
Enrgkid's Avatar
Drives: 2013 Subaru BRZ
Can recommend Steve’s tunes worth the money I have mine for OFT and they have improved the feel of the car
Enrgkid is offline   Reply With Quote
The Following User Says Thank You to Enrgkid For This Useful Post:
steve99 (02-13-2021)
Old 02-15-2021, 02:19 PM   #986
86Quad
86Quad's Avatar
Message sent!
Old 02-16-2021, 05:10 AM   #987
steve99
Drives: FT86
Added some more 2019 and 2020 stock roms
EAGLE5 (07-15-2021)
Old 07-14-2021, 09:38 PM   #988
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Is ZA1JB01C still the most up to date ROM for the 2013 US MT? Are the ROMs linked in the first post 100% stock or modified?
Supposedly California is now doing checksums on ECUs to see if the ROM is modified, and I don't think I have my stock ROM backup anymore.
Old 07-15-2021, 03:22 AM   #989
steve99
Drives: FT86
Yes for 2013 usa\canada manual car B01C is latest factory rom
all roms in first post stock
The Following 2 Users Say Thank You to steve99 For This Useful Post:
EAGLE5 (07-15-2021), Ultramaroon (07-16-2021)
Old 07-31-2021, 11:01 AM   #990
cheymann
cheymann's Avatar
Drives: Toyota 86 2012
Question about a 2017 ROM: I want to flash an OFT ZA1JK00R ROM via tactrix. The ecuflash definition for K00G seems to open the OFT ROM perfectly, but not the ROM read from the car (tables content is all garbage). So is the OFT ROM really a K00G one, that just got modified to contain a K00R calibration ID?
Most importantly, will it be safe to flash the OFT ROM to the car? It's a 2017 MT in South Africa, which I think follows EUDM calibration IDs, with a black manifold.
cheymann is offline   Reply With Quote
Old 08-01-2021, 07:45 AM   #991
cheymann
cheymann's Avatar
I can confirm, I flashed it and it worked perfectly.
Old 08-01-2021, 08:58 AM   #992
steve99
Drives: FT86
Correct all oft manual 2017+ tunes are based on K00G jist calod hacked to work on oft.
You may need to adjust the maf scaling for your car as i tihnk the black and red manifold cars may have slightly different intakes and air box
Old 08-02-2021, 10:42 AM   #993
cheymann
cheymann's Avatar
Thanks! Yes I see the fuel trim is around -7% when idling, so there would be value in rescaling the MAF. This is not excessive though.
The Following User Says Thank You to cheymann For This Useful Post:
steve99 (08-02-2021)
Old 08-02-2021, 10:56 AM   #994
Jappy
Drives: Subaru 86
Message sent
Jappy is offline   Reply With Quote
ecuflash, tactrix, taxtrix, tuning
ECUFlash - Getting close! xjohnx Software Tuning 698 03-22-2015 01:10 PM
EcuTek Flash finished but now it shows only a Partial Flash... Cross Software Tuning 32 02-12-2014 11:55 AM
Tactrix Openport jamesm Engine, Exhaust, Bolt-Ons 1 01-28-2014 09:27 PM
Visconti Tuning - Latest BRZ Flash Info Visconti Software Tuning 6530 12-24-2013 11:18 PM
Overboost Protection With OFT/EcuFlash? FrX Software Tuning 9 10-23-2013 08:27 AM
