Drives: 2020 Subaru BRZ TS
Question Regarding 2017+ Battery
So today I stored my vehicle for the winter. It seems the battery is a little trickier to remove in the recent models vs the pre-2017 ones. There is some sort of black plastic cap clipped unto the front battery tie-down. I found one video online saying to just turn it counterclockwise with a socket but mine seemed to turn but not come off. I tried to pry it off a little as well but no success. I ended up just loosening the back battery tie down and the whole thing just came off.
One concern I had was how the battery wires and cover were pinched from factory with the plastic tie wrap...is that normal? Here is picture illustrating the issue. Let me know what you think.
#2 | |
Drives: 2013 frs raven
Also that cable tie can not hurt a cable what you are seeing squished is called conduit. It is of no concern. |
| The Following 2 Users Say Thank You to Gloonge For This Useful Post: | SUSPECT_BRZ (11-22-2020), Tcoat (11-21-2020) |
#3 |
Thanks for your reply. I'm going to get some new wire loom today, cut the tie wrap carefully and redo the looming. I'll then tape both wires together so they stay in place. Removing the battery will be easier that way in the future.
#4 |
Rust bucket enthusiast
I can confirm, you just need to give it a yoink. It's stronger than you'd expect, don't be worried.
They do this to try and keep the nut from rusting, but foolishly; it's the threads UNDER the bracket that get weak and break off (not on this car, but in general with this style battery hold down) |
| The Following User Says Thank You to DarkPira7e For This Useful Post: | SUSPECT_BRZ (11-22-2020) |
#5 | |
Here is what it looks like now :
| The Following User Says Thank You to SUSPECT_BRZ For This Useful Post: | DarkPira7e (11-22-2020) |
#6 | |
Professional Mechanic
Drives: 2017 86 6MT Oceanic
That's not a garden hose, being squeezed by a zip tie doesn't restrict it's function, the black nub just need a slight tug while you unscrew it, it comes of easily, it's made to get pushed on and unscrewed off, so if you even slightly push down on it while unscrewing it'll just spin in place. |
| Question about tune and dead battery | JR23 | Software Tuning | 2 | 06-16-2020 11:45 AM |
| 2017+ Battery Terminal Sensors And Power Amp Connections | LimitedSlip | Electronics | Audio | NAV | Infotainment | 5 | 02-11-2019 11:57 PM |
| aftermarket AGM battery mounting question | CB390248 | Engine, Exhaust, Transmission | 0 | 01-23-2017 07:51 PM |
| Light Wight Battery Question | 8686 | Engine, Exhaust, Transmission | 22 | 10-22-2013 12:13 PM |
| Amplifier battery wire question!?!? | mbh1101 | Electronics | Audio | NAV | Infotainment | 4 | 03-04-2013 10:07 AM |
