Senior Citizen Member
2017+ Battery Terminal Sensors And Power Amp Connections
The 2017+ twins don't have any individual vehicle electrical connections made directly to the battery posts. Instead, there are modules clamped to both posts and all vehicle connections are made to these modules.
1. The module on the negative post is the "Battery Current Sensor" and is used to monitor the voltage, current flow, and temperature of the battery. The ECU uses this information to control alternator output (the 12 to 14 volt fluctuation noticed by many). 2. The module on the positive post *appears* to be just a distribution block with a couple of large fuses protecting major circuits. I want to connect a sub amp in the trunk that requires 4 gauge power cables. I'm going to use a chassis ground in the trunk for the negative side so the amp's current draw will be seen by the Battery Current Sensor. My question is this: Can I connect the positive 4 gauge cable directly to the battery post clamp bolt thus bypassing the "distribution block"? (Does that block do anything other than serve as a fuse holder?) There would be a new fuse in the 4 gauge cable about six inches from the battery post. Thanks! |
[insert cool phrase here]
Drives: BRZ Premium
New to car audio huh?
Yes you can. Yes it's just like you said, it's a distribution thingy.
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
Drives: BRZ Premium
No worries it's pretty much the same tech just in a new wrapper
#5 | |
ProCrastinationConsultant
hopefully you held on to that system! some audio nuts are paying big money for vintage gear now...
#6 | |
I don't have much vintage car stuff unfortunately.
| Negative Battery Terminal | UNCC_BRZ | Electronics | Audio | NAV | Infotainment | 2 | 09-19-2018 10:23 PM |
| Battery Brace touched Positive Battery terminal, car won't start!! | 7m28 | Issues | Warranty | Recalls / TSB | 21 | 09-24-2017 12:55 PM |
| Battery terminal setup | fuddbutter | Electronics | Audio | NAV | Infotainment | 0 | 01-24-2017 04:27 PM |
| Lost my battery terminal nut. | qqzj | BRZ First-Gen (2012+) — General Topics | 3 | 08-05-2014 07:51 AM |
| Battery Terminal for Amp Install | rbizzle004 | Electronics | Audio | NAV | Infotainment | 3 | 06-05-2013 12:46 AM |
