Old 11-01-2020, 06:09 AM   #1
gmetal
Drives: 2017 86 | UEL + Q300
[RESOLVED] Very Strange Gear Indication Issue
Hi Everyone, long time lurker first time poster.
Recently got a set of UELs + an Invidia Q300 & and Ecutek dyno tune by a reputable local tuner where I live. Everything seems great except for one quirk that popped up after the tune:
When shifting into 5th gear, most of the time, now the gear indicator on the dash does not provide a number, or after some thinking indicates 4th! This happens only for 5th (all other gears fine), and the actual gear engagement feels fine, just the number displayed.
What seems exceptionally strange to me is mys understanding is that this cant be a sensor issue, as the gear indicaiton isnt from a position sensor, but instead is software calculated from speedo & tacho measurements, to find the ratio.
Obviously ive had no gearbox or final drive changes, so this seems weird.
Does anyone have any idea of what may be wrong or troubleshooting steps? is this some kind of software bug?
Things ive tried:
- checking OBD2 diagnostic error codes (none)
- shifted up and down into 5th, at different speeds, fast & slow with the clutch.
- Turned the car off and on
- reset the dash settings & turned off and on the gear speed indication.
2017 86 GTS with the LCD screen in the dash.
Thanks in advance, all ideas welcome!
Edit: problem was resolved by the tuner reflashing the same tune again. May have just been a corruption.
gmetal is offline   Reply With Quote
Old 11-01-2020, 06:53 AM   #2
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Stock wheel/tire size?
Old 11-01-2020, 06:56 AM   #3
gmetal
Yup, stock 17 inch rims & tyres. Hasnt changed before/after the tune.
Old 11-01-2020, 07:23 AM   #4
Compelica
Compelica's Avatar
Drives: 86 GT
Apparently there's a table in the tune which calculates the intended gear position, you can find more details around here but the tuner has to adjust that.
Compelica is offline   Reply With Quote
Old 11-01-2020, 07:46 AM   #5
x808drifter
LMGTFY
I vaguely remember something about that.
But WHY would someone even mess with the table at all if the car has a stock drivetrain.
I'd go to the tuner at this point and ask him to check that for you.
Old 11-01-2020, 07:54 AM   #6
Compelica
Compelica's Avatar
Drives: 86 GT
Probably started from a tune that was based off a different final drive, but who knows. At the very least, the problem can be easily solved with the tuner.
Old 11-01-2020, 12:50 PM   #7
norcalpb
norcalpb's Avatar
Def the final drive table values:
https://www.ft86club.com/forums/showthread.php?t=136569
Old 11-01-2020, 07:14 PM   #8
People look at a gear indicator?
p1l0t (11-05-2020), spike021 (11-06-2020)
Old 11-01-2020, 09:20 PM   #9
sharpsicle
Certs You Dont Care About
sharpsicle's Avatar
Drives: 2013 Galaxy Blue BRZ
You've never tried to go from 6th to 7th?
sharpsicle is offline   Reply With Quote
The Following 3 Users Say Thank You to sharpsicle For This Useful Post:
p1l0t (11-05-2020), soundman98 (11-01-2020), spike021 (11-06-2020)
Old 11-01-2020, 09:53 PM   #10
It's like opening an empty can of peanuts.
sharpsicle (11-02-2020)
Old 11-01-2020, 11:12 PM   #11
gmetal
Thanks everyone, will ask the tuner to check the tables etc and report back!
Old 11-05-2020, 11:06 PM   #12
p1l0t
p1l0t's Avatar
I totally forgot about mine. I turned it on once, but replaced the battery since then and I forgot how you even turn it on now.
Old 11-05-2020, 11:12 PM   #13
I turned it on for about an hour, played Shift Hero by trying to hit the light right on, got bored, turned it off.
p1l0t (11-05-2020), spike021 (11-06-2020), Ultramaroon (11-05-2020)
Old 11-05-2020, 11:14 PM   #14
p1l0t (11-05-2020), Ultramaroon (11-05-2020)
gears, gearshift
2019 BRZ strange issue.. Jdmuscle Issues | Warranty | Recalls / TSB 9 06-07-2019 03:45 PM
Strange light issue DubLord Cosmetic Modification (Interior/Exterior/Lighting) 4 12-03-2018 09:25 PM
Strange reverse issue fanaticalz Issues | Warranty | Recalls / TSB 12 04-14-2016 04:33 PM
Strange acceleration issue mhughett BRZ First-Gen (2012+) — General Topics 11 03-16-2016 12:40 PM
LED Switchbacks strange issue theparagon Cosmetic Modification (Interior/Exterior/Lighting) 21 07-31-2014 03:21 PM
