Old 09-15-2020, 04:21 PM   #1
thekevinvo
Drives: 2014 Scion FRS
DIY: Transmission Fluid Change
thekevinvo is offline   Reply With Quote
The Following 2 Users Say Thank You to thekevinvo For This Useful Post:
Joveen (09-15-2020), MJones_RB (09-16-2020)
Old 09-16-2020, 07:42 AM   #2
Halo_2
Drives: 2014 MY15 86 GTS
If only someone would do a auto trans video
Halo_2 is offline   Reply With Quote
Old 09-16-2020, 02:23 PM   #3
pope
has a funny hat
Drives: 2014 BRZ Limited
Dry fill is 7.5L, drain and refill is 2L. Most of the 5.5L difference is in the torque converter (4.5L according to the service manual).
The 2L drain and refill procedure is essentially the same as the manual trans. Pull plugs, drain, replace drain plug, refill until fluid reaches overflow, reinstall fill plug, reinstall overflow plug.
A key difference is that the auto then needs to be brought up to 109-117*F to check/adjust the fluid level. There is a temperature check in Techstream or a test mode using a jumper and shifting rapidly between N and D for 6 seconds that will trigger the shift indicator lights to represent the temp being high/low/in range (never done it, just summarizing the service manual instructions).
A slightly more advanced refill, would be to drain and remove the pan. Check the magnets in the pan for shavings. Replace the screen assembly. Replace the pan gasket and reinstall the pan. Then refill. Should still be around 2L refill, but has the benefit of giving access to check the magnets for shavings
With access to the right equipment the trans can have fresh fluid pumped through it to flush and replace more than 26% of the fluid. Back in the day, the DIYer could "replicate" the procedure by disconnecting the trans cooler return line, and running a hose from the trans to a bucket (think gallons not liters) of fresh fluid and another house from the cooler line to an empty bucket and then start the vehicle (on stands) and let the trans flush itself by pumping old fluid into the empty bucket while sucking in the clean fluid (I have no idea of modern autos will still do this; I haven't owned an auto trans in 20 years; try at your own risk).
The alternative method for replacing most of the fluid is to remove the transmission. Remove and drain the torque converter. Refill and reinstall.
pope is offline   Reply With Quote
The Following User Says Thank You to pope For This Useful Post:
BrahmaBull1990 (03-24-2021)
Old 11-11-2020, 09:16 PM   #4
postdrift86
postdrift86's Avatar
Drives: Good old Toyota
Thanks, useful
postdrift86 is offline   Reply With Quote
Old 03-24-2021, 05:56 PM   #5
tankslapper
Drives: None
Am I understanding this correctly in that you are diluting the existing used fluid with only 27% new fluid? If so, is there a method to flush the system and replace with 100% fresh fluid without having to remove the tranny?
tankslapper is offline   Reply With Quote
DIY: Automatic Transmission Fluid Change Tristor DIY (Do-It-Yourself) Guides 33 05-24-2024 11:13 PM
Automatic Transmission Fluid Change? kev0 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 9 02-08-2019 12:18 AM
Automatic Transmission Fluid Change jmaryt Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 169 08-26-2018 08:55 PM
AUTOMATIC transmission fluid change DIY?? qijian DIY (Do-It-Yourself) Guides 3 08-31-2017 09:34 AM
Transmission fluid change from dealership? Jolaessss Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 20 10-15-2014 01:52 AM
