Old 07-23-2020, 02:37 AM   #29
Originally Posted by LimitedSlip View Post
In agricultural circles that manufacturing technique was widely recognized as a Sperry New Holland innovation in the production of their hay balers. The idea was to identify the part or assembly that is most likely to fail or need replacement and then go to great lengths to make sure the part or assembly is located in the very center of the %#$! machine. Every time.
Brings to mind a short story - of the time when I was a kid, back on the farm, when I learned the difference between a "shear" bolt and a "case hardened" bolt - when it comes to replacing the bolt in the flywheel of a hay baler.
LimitedSlip (07-23-2020), soundman98 (07-24-2020)
Old 07-23-2020, 09:28 AM   #30
gravitylover
So I popped the hose off and stuck a pipe cleaner in the hole and there was a block about 2cm's in. I twisted the thing a little bit and something that looked like a mothball came out. It had sealed up the hole pretty well judging by how gummed up the edges were. I hope that's been the root of the problem the last few years and maybe, just maybe I solved it sufficiently that it doesn't cause wet feet again for a while.
The Following 5 Users Say Thank You to gravitylover For This Useful Post:
Busybee (09-12-2023), humfrz (07-23-2020), Opie (07-23-2020), Tcoat (07-23-2020), Ultramaroon (07-24-2020)
Old 07-23-2020, 11:36 AM   #31
Opie
Opie's Avatar
Drives: 2020 GMC Canyon Denali Diesel
Might want to clean the evaporator core, might be filled with mold & mildew from being plugged.
https://www.amazon.com/dp/B0007PHD0S...osi&th=1&psc=1
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
Opie is offline   Reply With Quote
The Following 3 Users Say Thank You to Opie For This Useful Post:
gravitylover (07-24-2020), soundman98 (07-24-2020), Ultramaroon (07-24-2020)
Old 07-23-2020, 02:17 PM   #32
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
Spider egg sac?
Old 07-23-2020, 02:43 PM   #33
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Originally Posted by dragoontwo View Post
Spider egg sac?
Murder Bees !!
Old 07-24-2020, 12:52 PM   #34
gravitylover
Spider egg sac?
It sure could be. I put that new drain hose in right before I drove down to the Florida Keys at the beginning of Feb. The car spent some time in quiet corners of parking lots where I could definitely see spiders looking to get out of the sun finding a nice damp ac drain hose to hang out in. Then the car did a lot of sitting around, parked on the grass, here at home while we were under stay at home guidance. Perfect cool, damp, quiet time for spiders to do their egg laying thing.
Old 09-12-2023, 06:44 AM   #35
Busybee
Busybee's Avatar
Drives: GR86 Trueno Edition
Just came across while I was further searching the forum (sorry for my post - at least there is a video now).
Little confused regarding the hose you mentioned. Is the the draining hose, under the carpet from the left to right behind the styrofoam like part?
Haven’t checked yet. What would be the best way to clean it. I can also get a new one if it can be taken out easily
Thanks
Mazda 323F BA 1997 - Overseas
Mazda 323 BG 1994 - Sold
Mazda 323 BG 1991 - Sold
Busybee is offline   Reply With Quote
Old 09-12-2023, 02:16 PM   #36
OP sold his twin a couple years ago. The drain tube blockage is common. Sometimes even rodents set up camp.
battery drain along with dtc? _keepkushin_ BRZ First-Gen (2012+) — General Topics 2 09-20-2019 09:04 AM
Need help with mystery connector, and drain hose Gabzor BRZ First-Gen (2012+) — General Topics 3 09-21-2016 02:02 PM
Greddy Magnetic Oil Drain Plug or Fumoto Drain Valve? tracerit Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 20 01-04-2016 08:36 PM
Is 300ma too much drain while the car is off? tracerit Electronics | Audio | NAV | Infotainment 6 11-19-2015 01:20 PM
EZ oil drain same as Fumoto? wbradley CANADA 18 06-15-2015 04:40 PM
