Old 07-11-2020, 07:09 PM   #15
soundman98
ProCrastinationConsultant
soundman98's Avatar
So, THAT'S what I got -
i don't think it counts when you pioneered the technique
humfrz (07-11-2020)
Old 07-11-2020, 07:25 PM   #16
Oh, ya ...... is it nap time yet?
soundman98 (07-11-2020)
Old 07-11-2020, 07:27 PM   #17
Originally Posted by gravitylover View Post
Nah you're just old and missed your nap
Oh, OK.
I rarely miss a nap, sometimes they just come later in the day -
gravitylover (07-14-2020)
Old 07-21-2020, 01:20 PM   #18
gravitylover
Well I finally got under the dashboard and had a look around. The motor comes out in about 1 minute but after that it becomes a real hassle. Getting that cooling unit out is a heckuva project that I'm not sure I'm up to, you can't even see some of the screws that hold things in. I'm just going to pull the drain hose again and this time I'll stick a long pipe cleaner up there and see if it maybe unblocks whatever is causing the water to back up and run onto the passengers feet. Maybe I should stick the compressor spray nozzle in there and give it couple of shots...
The Following 2 Users Say Thank You to gravitylover For This Useful Post:
humfrz (07-21-2020), Ultramaroon (07-21-2020)
Old 07-21-2020, 03:40 PM   #19
What do ya got to lose?
PS - back in the day we didn't have those problems - ya jest reached in there and pulled out the bird.
gravitylover (07-22-2020)
Old 07-21-2020, 04:32 PM   #20
I'm sorry. Spent all last weekend removing the dashboard on the Camry to replace the little IR sensor for the climate control. It's a daunting task but not awful if following the book. I could probably do it again in a half day.
humfrz (07-21-2020)
Old 07-21-2020, 06:32 PM   #21
Where was it hidden?
Old 07-21-2020, 09:15 PM   #22
See that little connector in the top left corner?
humfrz (07-21-2020), Opie (07-23-2020)
Old 07-21-2020, 09:27 PM   #23
DAAAMN! - it looks like they placed that piece then built the dash around it -
Ultramaroon (07-23-2020)
Old 07-21-2020, 10:13 PM   #24
LimitedSlip
Senior Citizen Member
LimitedSlip's Avatar
Drives: Then-1977 Celica GT Now-2017 860SE
In agricultural circles that manufacturing technique was widely recognized as a Sperry New Holland innovation in the production of their hay balers. The idea was to identify the part or assembly that is most likely to fail or need replacement and then go to great lengths to make sure the part or assembly is located in the very center of the %#$! machine. Every time.
LimitedSlip is offline   Reply With Quote
The Following 3 Users Say Thank You to LimitedSlip For This Useful Post:
humfrz (07-23-2020), soundman98 (07-22-2020), Ultramaroon (07-23-2020)
Old 07-22-2020, 10:07 AM   #25
gravitylover
I think that laying on my back, twisted into shape to fit under there and see is annoying enough that I probably won't end up dismantling everything. Since my heart attack if my head ends up below my shoulders for more than a few seconds I get super dizzy and if I stand up will fall over, that makes it pretty unpleasant. If I had a lift and could just lean in I'd be more inclined to take the time and effort to do it. For now I'm going to pull the drain hose and see if some Bubba solutions work, if not I'll probably suck it up and start taking shit apart because I can imagine the dealer charging hundreds to do it.
The Following User Says Thank You to gravitylover For This Useful Post:
humfrz (07-23-2020)
Old 07-23-2020, 01:29 AM   #26
As much as it pains me to admit, Bubba solutions usually work just fine.
gravitylover (07-23-2020), humfrz (07-23-2020)
Old 07-23-2020, 01:36 AM   #27
The truth is even worse. Right next to it is a hole for the optional automatic headlight sensor. That fixture pops right out. The retaining clip for the infrared sensor must be squeezed from underneath. Prying from the top destroys it.
humfrz (07-23-2020)
Old 07-23-2020, 02:25 AM   #28
DID I READ THAT RIGHT!
(I must run and tell Bubba - )
The Following 3 Users Say Thank You to humfrz For This Useful Post:
gravitylover (07-23-2020), soundman98 (07-24-2020), Ultramaroon (07-23-2020)
battery drain along with dtc? _keepkushin_ BRZ First-Gen (2012+) — General Topics 2 09-20-2019 09:04 AM
Need help with mystery connector, and drain hose Gabzor BRZ First-Gen (2012+) — General Topics 3 09-21-2016 02:02 PM
Greddy Magnetic Oil Drain Plug or Fumoto Drain Valve? tracerit Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 20 01-04-2016 08:36 PM
Is 300ma too much drain while the car is off? tracerit Electronics | Audio | NAV | Infotainment 6 11-19-2015 01:20 PM
EZ oil drain same as Fumoto? wbradley CANADA 18 06-15-2015 04:40 PM
