| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
has a funny hat
Drives: 2014 BRZ Limited
Identify This Connector
I am almost finished rebuilding a salvage BRZ Limited with front end damage.
The radiator support front cut I purchased from a local yard had some wiring harness scraps attached. This connector was part of the right side bundle that splits to feed the fans, horns, headlight, crash sensor, etc. My car does not have this connector on it. There are signs that a previous owner made alterations to the wiring harness. There is also crash damage that severed some wiring (different color wires though). So, I am trying to determine if this connector was: a. an option my car did not have b. removed by a previous owner for some reason, or c. severed by the collision and to a part I didn’t know I need to find |
#2 |
Drives: 2020 GMC Canyon Denali Diesel
Turn Signal/Foglight I'm pretty sure...
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
#3 |
Drives: Crapcan
Pretty sure you are correct.
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | Opie (06-08-2020) |
#4 |
#5 |
Drives: Crapcan
All the connectors on my car are grey. Pretty sure OP's picture is the fog.
#6 | |
It is fog but not the one that hooks up to the lights https://onlineparts.toyotasouthatlan...SABEgLTtvD_BwE
#7 |
has a funny hat
My car and the front cut both have these three connectors on both sides, I’ve been assuming they are (left to right): Headlight, Foglight, Side Marker. (Lights are on order but haven’t arrived yet).
The front cut had the connector from the original post only on the right side. |
#8 | |
Wheels for Brains
That is the front turn signal connector for FRS. That 3-pin end connects to the the bulb holder on the signal itself. Where the wires are snipped you would find the 4-pin connector, with 4 pinouts being: 1. Turn Signal (blinking), 2. Turn Running (steady, at night), 3. Fog, 4. Ground See thread for additional pictures: https://www.ft86club.com/forums/showthread.php?t=19169 You can see how to access the fog power via Toyota's instruction manual for FRS Fog Lights: PT413-18130.pdf Last edited by EndlessAzure; 06-08-2020 at 09:11 PM. |
#9 | |
#10 |
has a funny hat
@EndlessAzure Thank you for identifying it.
Thank you to everyone that attempted to identify it. It sounds like it shouldn’t be relevant to my car, so I won’t worry about it. |
#11 |
has a funny hat
Well. I figured out that the connector isn’t what we thought. It’s the connector for the levelers on the factory headlights.
Just found the wires folded up and taped over in part of the harness on the car. Then I watched a bunch of Youtube headlight videos until I found one that showed the connector. Not sure i’ll go to the trouble of fixing the wiring since I’m not using OEM headlights. |
| The Following 2 Users Say Thank You to pope For This Useful Post: | EndlessAzure (06-11-2020), NoHaveMSG (06-11-2020) |
#12 | |
Drives: 2013 BRZ Limited
| Whats the name of this connector (3rd brake light connector) | Chimera | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 01-10-2017 07:13 PM |
| Can you identify this bolt? | junkyard | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 14 | 08-29-2016 01:07 PM |
| Help me identify this part! | ATESIX | Scion FR-S / Toyota 86 GT86 General Forum | 6 | 07-14-2015 08:50 AM |
| Can't identify this car | Bg8780 | Other Vehicles & General Automotive Discussions | 23 | 11-19-2013 05:31 PM |
| Help me identify this car | jimmillion | Other Vehicles & General Automotive Discussions | 14 | 09-13-2012 11:09 AM |
