Old 05-01-2020, 07:22 AM   #43
Originally Posted by knucklehead View Post
Was able to get my motor running. Will just have to buy oil again tomorrow as I used up 5 gal of oil and the oil level is just at the middle of the low and high marks of the dipstick. How much oil does this engine take?
WHAT? 5 GALLONS? Check and see if it is running out the tail pipe! It should be overflowing out of the dipstick port at an alarming rate if you put 5 gallons in.
Please tell me you mean quarts!
brandonblt2 (05-01-2020), Opie (05-01-2020), paintdude258 (06-22-2020)
Old 05-01-2020, 10:51 AM   #44
Mike_ZN6
Mike_ZN6's Avatar
Drives: 2016 Toyota 86
Whole wiring harnesses.
CAI components.
ECU as you said.
Many changed sensors.
Different alternator and charging system.
Probably some things I have not thought of.
Sure it could be done with some work and cash but you seriously have to ask if that work and cost is worth it.
I think the security system/keyless entry system has to be changed as well. And likely the ABS control module.
After looking into it, I think it makes more sense for anyone in this position that wants the new engine to just buy a 2017+.
Mike_ZN6 is offline   Reply With Quote
The Following User Says Thank You to Mike_ZN6 For This Useful Post:
Tcoat (05-01-2020)
Old 05-01-2020, 12:21 PM   #45
brandonblt2
The Stig's African Cousin
brandonblt2's Avatar
Drives: 2014 wrb brz
5 gallons or 5 quarts? 5 Gallons is way to much. The engine should hold about 5.5 to 5.8 quarts of oil.
Instagram: brandonblt2
Build Thread: http://www.ft86club.com/forums/showt...86#post2219386
Flickr: brandonblt567
brandonblt2 is offline   Reply With Quote
Old 05-01-2020, 03:21 PM   #46
knucklehead
Drives: FRS
Oops, meant to say 5 quarts .
knucklehead is offline   Reply With Quote
The Following 2 Users Say Thank You to knucklehead For This Useful Post:
Opie (05-01-2020), Tcoat (05-01-2020)
Old 05-01-2020, 03:23 PM   #47
knucklehead
Drives: FRS
Yeah, just realized my mistake. Meant to say quarts. But I guess, I was not expecting emptying a 5 quart container and not even get the mark on the dipstick to the max. Anyway, bought another container of oil and will be filling it up later.
Old 05-01-2020, 03:29 PM   #48
It needs 5.5 to 5.8 so it is in the right spot on the stick with 5 already in it.
knucklehead (05-01-2020)
Old 05-01-2020, 03:43 PM   #49
knucklehead
Drives: FRS
Thanks Tcoat!
Old 05-02-2020, 12:17 AM   #50
knucklehead
Drives: FRS
Finally was able to drive the car home and I am so glad that the swap so far turned well. Will be observing the car the next few days..
I discovered that someone stole my exhaust tips while it was parked while I was waiting to do this engine swap!
The Following 3 Users Say Thank You to knucklehead For This Useful Post:
mrg666 (05-07-2020), paintdude258 (06-22-2020), Tcoat (05-09-2020)
Old 05-02-2020, 03:47 AM   #51
Racenut
Racenut's Avatar
Glad to find this thread as I'm faced with the same project. 2013 FRS needs a motor. Looking for a 15-16, glad to see they will drop right in as long as the harness is there. Now just gotta find a motor. Anyone have any reputable sources for used motors? California if possible.
Racenut is offline   Reply With Quote
Old 05-06-2020, 03:18 AM   #52
Decimus
BAE
Decimus's Avatar
Drives: Asphalt FRS
Glad to see you got it running!
Decimus is offline   Reply With Quote
The Following User Says Thank You to Decimus For This Useful Post:
knucklehead (05-08-2020)
Old 05-08-2020, 11:30 AM   #53
Andz
Originally Posted by Decimus View Post
No problem, i recently swapped a 16 BRZ motor into my 13 FRS too so if you have any questions ill try my best to help
Sorry to piggyback off this thread, but I'm in the same position right now where the engine on my '13 FRS popped and the only engine I've been able to track down was off a '15 BRZ.
A local reputable shop told me there are some subtle differences between the FRS and BRZ engines that it wouldn't be worth it to bother with a full engine swap between the 2. So far I haven't been able to find any differences between them though.
Are there actually any differences at all between the FA20 on the FRS and BRZ and do they pose any additional challenges when doing a full swap (other than transmission)?
Andz is offline   Reply With Quote
Old 05-08-2020, 04:58 PM   #54
knucklehead
Drives: FRS
Yep! Thanks to you and the others who had responded to all my inquiries!
Old 05-08-2020, 05:05 PM   #55
knucklehead
Drives: FRS
I was also told that when I was shopping around. I don't believe that there are any differences between the FRS and BRZ engines (assuming all the same year model being compared). I had mentioned that my car was a 2013 and I was looking for a 2015/2016 engine and they tell me that it is not compatible based on their database. But with the help of members of this forum who had clarified that the 2015/2016 was a "plug-and-play" to the 2013, I just told them that it would work. Just make sure that all wirings, sensors, coilpacks are there. To keep it simple, if your car is manual look for a manual engine so that you will not have to deal with having to change things around say you ended up getting an engine from an automatic car.
Old 05-09-2020, 02:56 AM   #56
Both companies have different designations for the engine (Subaru FA20 and Toyota 4U-GSE) but they are identical in all ways. Both companies use totally different part numbers for all the parts since they use different numbering systems. Other than some body, trim and interior parts everything else is identical except for that part number.
Engine oil dipstick tube replacement Alarik Engine, Exhaust, Transmission 2 01-27-2020 02:33 AM
Glittery engine oil after short block replacement msaikhan Issues | Warranty | Recalls / TSB 17 08-24-2019 03:17 PM
Engine Replacement issue Sloyota Issues | Warranty | Recalls / TSB 5 08-11-2019 12:38 AM
Has anyone here had an engine failure? Replacement cost? Smurfette Engine, Exhaust, Transmission 10 12-02-2015 03:19 PM
Exedy OEM Replacement Clutch Subaru BRZ 2013-2015 / Scion FR-S 2013-2015 **New Site** RallySport Direct Transmission and Driveline 59 09-01-2015 01:18 PM
