Old 04-25-2020, 12:40 PM   #43
Espi
Espi's Avatar
Drives: 17 BRZ
Just made the move from Showas to Sachs and it’s slight different feel. I’d say overall I have more grip and the rear feels a little softer on sharp hard cornering. Front end is still nice and stiff. No confidence or balance lost in the cars ability. The car feels like it went from a more 50/50 approach of comfort and handling to a now mild sporty feel 60 sport/ 40 comfort. I did also install STI springs off a Ts model so that may play a roll in my experience on the rear feel.
Espi is offline   Reply With Quote
Old 04-26-2020, 05:37 AM   #44
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Originally Posted by solidONE View Post
I'm currently running a set of 2015 Showas off a BRZ with 2013 BRZ front spring and my factory 2013 FRS rear spring. The ride using the 2015 was better, initially and for a good while. Now that I've some miles on the 2015 Showas, I dont think I can say the same.
How many miles do you have on the 2015 Showas?
Old 04-26-2020, 12:41 PM   #45
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
lets see.. looking at my records I have roughly 30,000 miles and almost 2 years on them. Thats not including the miles the original owner put on it. He said about 2000 miles, but I'm pretty sure that's bullshit.
Intent > Content
The Following 2 Users Say Thank You to solidONE For This Useful Post:
nikitopo (04-26-2020), norcalpb (04-27-2020)
Old 04-28-2020, 06:03 PM   #46
gpvecchi
gpvecchi's Avatar
My two cents regarding label colors on the shocks: they are 5 of the 7 rainbow colors.
Could it be a scale from softer to harder?
Further investigations on Sachs replacement shocks revealed that they use blue label for OEM replacement shocks (Premium Touring) and red label for more stiff versions (Advantage).
The Following User Says Thank You to gpvecchi For This Useful Post:
solidONE (04-29-2020)
Old 04-28-2020, 09:52 PM   #47
JIM THEO
Drives: BRZ 2018
Resistors use coloring for impedance so same way they may represent with two numbers the actual Kg of each spring!
http://www.sysrecon.com/wp-content/u...ColorChart.png
JIM THEO is offline   Reply With Quote
The Following User Says Thank You to JIM THEO For This Useful Post:
soundman98 (04-28-2020)
Old 04-28-2020, 09:57 PM   #48
JIM THEO
Drives: BRZ 2018
According to resistors impedance scale, my MY17-18 ts springs are Fronts 4,6Kg and Rears 3,7Kg Hahaha...
Old 04-29-2020, 01:12 AM   #49
solidONE
solidONE's Avatar
And that's accurate? Very smart thing they did, if so.
Intent > Content
Old 04-29-2020, 03:40 AM   #50
JIM THEO
Drives: BRZ 2018
I really don't know mate but has some logic!
Old 05-15-2020, 07:40 PM   #51
RickyRacer
RickyRacer's Avatar
Drives: 13 FRS
Which ones should I buy from Toyota/Subaru to give me the 1inch drop but with still good daily driveability? The PP?
RickyRacer is offline   Reply With Quote
Old 05-15-2020, 09:58 PM   #52
BlueWhelan
BlueWhelan's Avatar
Drives: 2013 Blue Subaru BRZ. 6 Spd manual
There is no OEM/STI spring that will give a 1 inch drop. The pinks will yield a 10-15mm drop. Matched with a solid set of dampers and the daily compliance will be more than adequate.
BlueWhelan is offline   Reply With Quote
Old 05-16-2020, 03:48 AM   #53
LancePower
Drives: 2020 BRZ tS
Right, TRD is the only "OEM" Spring that will give you a 1" drop.
LancePower is offline   Reply With Quote
Old 05-16-2020, 04:05 AM   #54
BlueWhelan
BlueWhelan's Avatar
And even that’s just a set of TRD rebranded Eibach Pros
The Following User Says Thank You to BlueWhelan For This Useful Post:
Tcoat (05-16-2020)
Old 05-16-2020, 04:23 PM   #55
RickyRacer
RickyRacer's Avatar
Drives: 13 FRS
Thanks, I was leaning towards pro kit anyways. But which dampers are best paired with them? I don’t track, just spirited drives on the weekend.
I want the Showa evolution custom valved damped/spring set but I’d have to order it from Japan. Can bilstein deliver the same performance?
Old 05-16-2020, 05:18 PM   #56
BlueWhelan
BlueWhelan's Avatar
The bilsteins will be more than adequate. Those get my vote, though if you can find a set of slightly used PP dampers those should match well too.
FS: Performance Package Sachs Springs and Dampers Desai_N Brakes, Suspension, Chassis 3 01-15-2020 07:12 PM
Looking to purchase 2018 BRZ performance package Sachs mitama Want-To-Buy Requests 0 07-01-2019 12:52 PM
Sold...2017 OEM Performance Package shocks 86MLR Australia Classifieds 7 10-06-2018 01:56 AM
WTB: 2017 performance package Sachs dampers panand Want-To-Buy Requests 1 03-16-2018 02:57 PM
FS; 2017 PP Struts performance package shocks brz sokol Brakes, Suspension, Chassis 3 08-30-2017 09:26 PM
