Old 04-14-2020, 03:25 PM   #1
airrick
Drives: TRD R.S. 1.0 FRS
Whirring noise on clutch
Hi,
Recently I noticed this whirring noise when i press the clutch on cold start. Even if i press the clutch a little. Is this the dreaded TOB?
airrick is offline   Reply With Quote
Old 04-14-2020, 03:50 PM   #2
Originally Posted by airrick View Post
Hi,
Yep
airrick (04-14-2020), DarkPira7e (04-19-2020), Spuds (04-22-2020)
Old 04-14-2020, 04:04 PM   #3
Most likely.
Old 04-14-2020, 04:21 PM   #4
Most likely.
It is the start. It get's much much worse if left.
Old 04-14-2020, 05:00 PM   #5
airrick
its at 61500 miles. rarely drive the car. how much longer you think til it goes? Im thinking about attempting to do this job myself. Doesnt seem toooooo hard of a job. Was gonna get a tune from a Racers Line, maybe not now.
Old 04-14-2020, 05:41 PM   #6
I got about 6,000 miles after mine started to make that noise. I also waited too long and it blew and took everything it touched with it. I personally would not wait. The longer it goes the more damage is done.
Spuds (04-22-2020)
Old 04-14-2020, 06:08 PM   #7
airrick
hmm youre right.
SU003-07349
Exedy OEM Clutch Kit
I've read that the 17+ models TOB are better so i guess im purchasing this one. Since im gonna replace TOB might as well replace whole clutch assembly. Thinking about replacing the OEM clutch fork with the Forged Verus ones.
I did the clutch pedal mod, moved it about just equal to brake pedal; did this cause more wear on my TOB/Clutch Assembly? If this caused more wear then i would want to move back the clutch pedal height.
Old 04-14-2020, 06:11 PM   #8
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Yep. TOB.
Mine started with the faint same exact noise at about your same mileage. Mine lived another 10k before it shat itself on the taco bell drive through.
The job itself is not hard at all, given you have a level garage, a buddy and basic hand tools.
Old 04-14-2020, 06:21 PM   #9
hmm youre right.
SU003-07349
There probably is zero need to replace the whole clutch. You do need to ensure you get the right part number for the TOB though.
No the mod probably had nothing to do with it. There were two visibly different TOBs used up until 2017 even though there was only one part number. One seems to be worse than the other.
This is the part number you want.
Old 04-14-2020, 06:32 PM   #10
airrick
SU003-07349
this one right? thanks!
Old 04-14-2020, 06:34 PM   #11
SU003-07349
Yep
Old 04-18-2020, 11:40 AM   #12
sharpsicle
Certs You Dont Care About
sharpsicle's Avatar
Drives: 2013 Galaxy Blue BRZ
Personally, at 60k+ miles, if you're going to drop the transmission you might as well do the whole clutch. The kits themselves are not that expensive, and the labor you're putting in just makes sense to do it all now and not have to worry about dropping it again in the near future.
sharpsicle is offline   Reply With Quote
The Following User Says Thank You to sharpsicle For This Useful Post:
Grady (04-19-2020)
Old 04-19-2020, 08:54 AM   #13
Grady
Grady's Avatar
Yep, Murphy's Law! Not that pulling the transmission is difficult I just would not want to pull it again 6 months later.
Old 04-19-2020, 05:23 PM   #14
It all depends on the driver. If the driver is clueless, for example, chronically gassing before full engagement, then maybe replace.
If the owner is confident in his/her ability to respect the clutch, I wouldn't fuck with it. New parts can be defective.
airrick (04-20-2020)
Clutch creaking noise (not the clutch fork one...) treminaor Issues | Warranty | Recalls / TSB 59 10-23-2017 01:53 AM
whining/whirring noise during high load/rpm clutch engagement 7thgear Issues | Warranty | Recalls / TSB 105 06-19-2017 11:04 AM
Clutch noise new to-day Skye Issues | Warranty | Recalls / TSB 16 11-19-2016 11:42 AM
Whirring Noise When Shifting? Joe-G Issues | Warranty | Recalls / TSB 3 03-01-2015 01:23 AM
Something of a Whirring noise coming from resonance tube after trd intake install? Waffles Issues | Warranty | Recalls / TSB 4 03-15-2014 10:35 PM
