Old 04-11-2020, 11:06 PM   #141
SeizeTheKarp
Drives: 2020 Hakone 86
Has anyone verified fitment of the TE37 saga 17x9 +42? rays site says they do but...
SeizeTheKarp is offline   Reply With Quote
Old 04-14-2020, 04:41 PM   #142
pinoy_dorifto
Tuloy po kayo!
Drives: 2019 Toyota 86 TRD SE
Yokohama Advan TC III 18x9.5 +45
NO Spacers Required!
I.G. @mytoy86
pinoy_dorifto is offline   Reply With Quote
Old 04-17-2020, 10:34 AM   #143
tcoffin014
Drives: 2018 BRZ PP WRB
They are completely different calipers, so yes.
- Andrew
How much different are the dimensions on these calipers? Which ones are larger in each direction?
I have confirmed fitment of a certain wheel on a TRD 86 but now I'm not sure if it will fit my PP BRZ. I was told offset wasn't the issue, it's barrel clearance.
So do the PP Brembos provide more barrel clearance or the TRD Brembos?
tcoffin014 is offline   Reply With Quote
Old 04-17-2020, 12:50 PM   #144
The 6 piston TRD big brake kit is pretty rare, so I have no idea. That's what I was referring to in that post.
The TRD brembos from the factory are the same as the PP Brembos.
- Andrew
Old 04-17-2020, 01:23 PM   #145
tcoffin014
- Andrew
Ah ok. Thanks for confirming. I was about to say they look the same to me lol
The Following User Says Thank You to tcoffin014 For This Useful Post:
Racecomp Engineering (04-17-2020)
Old 04-17-2020, 02:13 PM   #146
gpvecchi
gpvecchi's Avatar
FYI, PP Brembo and TRD 6 pots Brembo are the same as Brembo GT Junior kit...
Old 04-17-2020, 02:38 PM   #147
churchx
churchx's Avatar
Drives: 2014 GT86
gpvecchi: you are sure on that? (checking up in background, as maybe cheaper then PP retrofit). Or you wrote that about same clearance, not about same parts?
Old 04-17-2020, 02:43 PM   #148
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
IDK why I haven't seen this til now. Good info.
Stickied
timurrrr (06-23-2020)
Old 04-17-2020, 03:01 PM   #149
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
The PP Brembo's are 4 pot here.
Old 04-18-2020, 04:46 AM   #150
gpvecchi
gpvecchi's Avatar
Sorry I meant that PP is the same of 4 pot GT Junior and TRD is 6 pot GT Junior.
The Following User Says Thank You to gpvecchi For This Useful Post:
Old 04-20-2020, 06:28 AM   #151
E30wyatt
Drives: 2019 BRZ Performance Package
Originally Posted by timurrrr View Post
Hi folks,
I have a '17 BRZ with PP, and recently started looking for aftermarket wheels.
To my disappointment, it turned out that those Brembos are so big that many wheels don't fit.
On top of that, the available information about what fits was scarce. I even ended up ordering wheels that didn't fit — because I couldn't easily find any information that they don't
I've decided to gather a list of known FIT (without spacers! 5x100 only), as well as popular DO NOT FIT wheels for these calipers. This list is combined from an old post by FT86SpeedFactory (thanks for the starting point!) and some random posts on this forum I've found.
Feel free to post specs of wheels not on this list that clear PP Brembos (preferably with photo evidence that they clear) and I'll try my best to keep this list up to date for a while. Also please share if you know of some wheels that do not fit that might be of common interest (RPF1 17x9, I'm looking at you!).
Hopefully this post will be useful for many people and admins will make it Sticky.
BRZ PP seems to have the same calipers as BRZ tS and 2004–2017 STi, this can be a good lead for more finds.
This list is focused mostly on clearing the brake calipers.
For other fitment questions (will it fit? will it poke? will it rub? will it hit the strut? etc.) it generally doesn't matter if you have Brembos or base trim brakes, so there should be more information on that on this forum, such as in the first three posts in this thread.
Don't forget to use your own judgement before making a purchase — I'm just collecting what I find online, and I can't personally verify every combo / claim.
Note that if one variation of the wheel is listed here as FIT, it doesn't guarantee that another variation will fit too, e.g. it's not uncommon for wider wheels to have more concave spokes than narrower wheels of the same model, causing issues on the hub-side edge of the caliper.
Enough boilerplate, enjoy the list!
In alphabetical order:
720Form
GTF1 17x8.0 +35 DO NOT FIT
949 Racing
6UL 17x8.0 (offset?) DO NOT FIT
6UL 17x9.0 +40 FIT
Advanti DST
Storm S1 17x8.0 +35 barely fit, probably need a 3mm spacer
Ambit
RE02 17x9.0 +35 FIT EVIDENCE/PHOTOS NEEDED!
Aodhan Wheels
AH02 18x9.5 +30 FIT, but a bit tight
DS02 18x9.5 +35 probably need a 5mm spacer
APEX
ARC-8 17x9.0 +42 FIT but some tires may have issues with stock suspension
AVID.1
AV-20 17x8.0 +35 FIT
Cosmis Racing
R1 18x9.5 +35 FIT
XT-005R 18x9.0 +25 probably fit? MORE EVIDENCE/PHOTOS NEEDED!
Drag
DR-38 17x9.0 +38 FIT
Enkei
PF01 17x7.5 +45 FIT
PF01 17x8.0 +35 FIT
Raijin 18x8.5 +45 FIT
RPF1 17x8.0 +45 FIT (note that they have convex spokes in 8" wide variant)
RPF1 17x8.0 +35 FIT (note that they have convex spokes in 8" wide variant)
RPF1 18x8.0 +35 FIT
RPF1 17x9.0 +35 DO NOT FIT (need 8mm spacer, but even then sit too tight)
T6S 18x8.0 +45 barely fit, probably need a 3mm+ spacer
TFR 17x8.0 +45 FIT
TS-5 17x8.0 +45(?) FIT
TS-10 18x8.0 +45 FIT
TS-V 17x8.0 +45 barely fit, probably need a 3mm spacer
Focal
F20 17x8.0 +42 probably FIT EVIDENCE/PHOTOS NEEDED!
Gram Lights
57CR 17x9.0 +38 FIT
57DR 17x9.0 +38 FIT
57DR 18x9.5 +38 FIT
57XTC 18x9.5 +38 FIT
57xtreme 18x9.5 +40 FIT the brakes but DON'T CLEAR STOCK STRUTS
GTS
GTS G709 18x8.0 +35 FIT
JNC
JNC030 17x9.0 +30 FIT
Konig
Dekagram 17x8.0 +40 DO NOT FIT (5mm spacer might be enough)
Dekagram 17x9.0 +40 FIT
Hypergram 17x8.0 +40 barely fit, probably need a 3mm spacer
Hypergram 17x9.0 +40 FIT
Hypergram 18x8.5 +38 FIT might need a thin spacer (more photos)
Ultraform 17x8.0 +40 DO NOT FIT (5mm spacer might be enough)
Kosei
K4R 17x8.0 +36 FIT
Mach V
Awesome 17x9.0 +42 FIT EVIDENCE/PHOTOS NEEDED!
Crucial 18x9.5 +42 FIT
Wicked Awesome 18x9.5 +42 FIT EVIDENCE/PHOTOS NEEDED!
Method
MR502 17x8.0 +38 FIT
Option Lab Wheels
R716 18x9.5 +35 FIT
OZ
Ultraleggera 17x8.0 +48 FIT
Prodrive
GC-06H 18x8.0 +43 FIT
Rota
G-Force 17x8.0 +48 seem to FIT
KB-F 18x8.5 +44 FIT
Titan 17x8.0 +?? DO NOT FIT EVIDENCE/PHOTOS NEEDED!
Titan 17x9.0 +35 FIT EVIDENCE/PHOTOS NEEDED!
Titan 17x9.0 +42 likely DO NOT FIT (need 3mm spacers, might as well just get +35)
Rotiform
BLQ 18x8.5 +35 FIT
KPS 18x8.5 +35 FIT
KPS 18x9.5 +45 DO NOT FIT (need 3mm spacers)
SSR
GTX01 18x8.5 +44 probably FIT, confirmation would be great
Speedwell
RS-1 18x9.5 +45 DO NOT FIT need a spacer and probably don't clear stock struts
RS-R 18x9.5 +40 FIT the brakes but DON'T CLEAR STOCK STRUTS
Subaru
non-PP BRZ wheels 17x7 +48 DO NOT FIT
2017+ BRZ PP wheels 17x7.5 +48 FIT (obviously)
2011–2014 WRX wheels 17x8.0 +53 DO NOT FIT (need 3mm spacers) EVIDENCE/PHOTOS NEEDED!
Titan 7
T-R10 18x9.5 +40 FIT
T-S5 17x9.0 +37 FIT
T-S5 18x9.5 +40 FIT
TRD
TRD Forged 17x7.5 +43 FIT
TRD 18x7.5 +35 may fit if those TRD calipers are the same size as PP Brembos — need more evidence.
TSW
Bathurst 17x8.0 +35 FIT
Nurburgring 17x8.0 +45 FIT, BRZ PP photos welcome
Nurburgring 18x8.0 +45 likely FIT, more evidence welcome
VarrsToen
ES6 18x9.5 +35 FIT but might be too close
Vision
Cross 17x7.5 +40 FIT
Volk Racing
CE28N 18x9.5 +38 FIT EVIDENCE/PHOTOS NEEDED!
G25 19x9.0 +45 FIT more evidence welcome
TE37 18x9.5 +40 FIT
ZE40 17x8.0 +47 DO NOT FIT
WedsSports
TC105N 17x8.0 +42 FIT According to CSG, the clearance is minimal, so you might want to use a 3mm spacer. EVIDENCE/PHOTOS NEEDED!
TC105N 17x9.0 +35 FIT
TC105N 18x9.5 +38 FIT
TC105X 17x8.0 +42 FIT According to CSG, the clearance is minimal, so you might want to use a 3mm spacer. EVIDENCE/PHOTOS NEEDED!
TC105X 17x9.0 +35 FIT
TC105X 18x8.5 +43 might fit, EVIDENCE NEEDED though!
SA-10R 18x8.5 +45 FIT
SA-10R 18x9.5 +40 FIT EVIDENCE/PHOTOS NEEDED!
SA-10R 18x9.5 +45 FIT the brakes but DON'T CLEAR STOCK STRUTS
Yoshihara
D-12C 18x8.0 +40 DO NOT FIT
XXR
XXR 550 18x8.75 +36 FIT
Does anyone know if the new 17x9 +42 te37 rub? I have hks hipermax gt coil overs. And don’t want to run spacers. Will be running a 245/40 re71r
E30wyatt is offline   Reply With Quote
Old 04-24-2020, 06:56 PM   #152
tcoffin014
Does anyone know if the Sparco Assetto Gara 17x7.5 et48 will clear Brembos with a spacer? Tire Rack says they won't fit, but they don't know how close it is. The Trofeo 5 in the same size fit, so I'm thinking the Gara shouldn't be far off. I don't mind running a small spacer. Should the barrel diameter on these 2 wheels be the same?
Old 05-13-2020, 06:56 AM   #153
Msoto80010
Drives: 2016 BRZ LIMITED
Does anyone know if the 949 6UL 17X8 +40 will fit with a spacer and if so, what size?
Msoto80010 is offline   Reply With Quote
Old 05-13-2020, 10:59 AM   #154
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
What clearance do we need to the caliper to claim they fit? 3mm? 5mm?
Is minimum spoke clearance different than minimum barrel clearance?
brz, performance package, wheels
Finding wheels to clear brembos jojosbrz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 11-13-2018 09:46 AM
Performance package Brembos Ernest72 Want-To-Buy Requests 2 07-14-2018 09:06 AM
Performance Package Brembos Freezing to Wheels? texastwurkt3am Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 02-23-2018 09:31 AM
What pads fit the Performance Package Brembos? mistople Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 01-03-2018 06:15 PM
