#15 |
Drives: 2013 Scion FRS 10-series
Plans to wrap header have been postponed indefinitely. I've been seduced by growly goodness and inability to value more wrenching above more driving.
#16 |
Drives: 2016 Steel AT FRS
Figured I'd revive the most recent thread... I ran Tomei UEL, OP, and 60R for two weeks with the HKS FP. I didn't hear any fluttering, but that might just be because the setup was so loud. Now I swapped back to the stock FP and hear the fluttering under load. I went under yesterday to inspect and no leaks at idle or signs of soot from a week of driving... Is it mainly the collector design that causes it? 4-1 at low rpm (not ideal) vs high rpm (ideal)? I think the consensus was that's just how it is, but I wasn't sure if anyone figured it out.
#17 |
Drives: Asphalt 2015 FRS
My understanding is that it's from thinner piping walls combined with the lack of heat shield that would muffle any noise. This allows you to hear the air as it exits the block and hits the bends. No reason to be concerned.
Build Thread: http://www.ft86club.com/forums/showthread.php?t=101096
#18 | |
Drives: 2017 86 Halo
Sent from my ONEPLUS A3000 using Tapatalk
#19 |
Drives: 2015 White BRZ Aozora
I have the same problem
Sounds like a flippin honda! Should get rid of my Berk FP and put my stock FP on? So it will be 1320 UEL Catless & overpipe Stock fp Custom catback ![]() Sent from my SM-G950W using Tapatalk |
#20 |
Drives: 2013 frs raven
Since it does not look like this has been solved.
I had this annoying flutter too. I decided before shelling out another $500 for a different header I would try to wrap it. 1 50' roll of 2" wrap (amazon brand, could have used some 1" too) later and the sound is like 90% gone. So for $15 and 3 hours of your time you can fix this header instead of living with that sound. |
#21 |
Drives: GT86 2013
I had the problem with my ACE header.
I wrapped it and changed to Remflex gaskets, and now the problem is fully gone. I confirmed it was an exhaust leak only noticeable during engine load (on the road). |
#22 | |
This time I wrapped it and re used my ram flex gaskets and the sound is gone. For what it's worth
| ticking sound with el header install. | fluffy-reindeer-slayer | Engine, Exhaust, Transmission | 10 | 05-11-2021 01:13 AM |
| My incomplete sound install | Moe | AFRICA | 10 | 05-27-2014 08:52 AM |
| My Install from Simplicity in Sound | jlu | Northern California | 4 | 06-08-2013 10:20 PM |
| My Install from Simplicity in Sound | jlu | Electronics | Audio | NAV | Infotainment | 3 | 06-05-2013 05:24 PM |
| GT Sound Matt Install | Neilus | Scion FR-S / Toyota 86 GT86 General Forum | 0 | 12-18-2012 06:32 AM |
