Drives: 2013 Scion FRS, 1998 Sentra SE
Pumping gas takes 10 minutes...
Hi
Has anybody else had this or a similar issue? on 2013 FRS models. I think something is wrong with my gas pumping hole? The spot where my gas cap screws in to. Either a sensor is missing or some other part removed or missing? I cannot let the gas pump sit on the auto shut off. The auto lock to hold the gas pumping trigger. It will click off as if it just hit top off in 2 seconds. I have to hold the gas handle trigger in mid pump and it takes over 10 minutes to fill up a whole tank. I cannot even hold the pump at full blast for more than a few seconds. Just tired of this issue if somebody has a solution thanks |
#2 |
Drives: Subaru BRZ
Oh no, not another "burping" issue....
#3 |
Senior gif poster
Drives: 2013 Asphalt FRS
does this happen at different gas stations? I've had an issue similar to that in the past with this car at a certain pump at a certain gas station.
#4 |
Happens at most I can remember
I see there are a few older posts about this issue... something about a tube getting worn out and falling in or being blocked.. I will call a dealership and see if they have a fix they are aware of |
#5 |
Rust bucket enthusiast
Let us know what the dealer says; that's pretty odd. Does it do this every single time?
#6 |
Hold the pump trigger at a slightly different angle.
http://www.ft86club.com/forums/showthread.php?t=133311 I'm only here for the biscuits |
#7 |
Collapsed filler tube or plugged evap cylinder filter. Rare but not unheard of.
https://www.ft86club.com/forums/showthread.php?t=118915
#8 |
Dealership has to order the part for me costing 117$ some kind of hose.
unfortunately it is not under warranty any more so I will have to bring it in and pay them to inspect. |
#9 |
https://www.ft86club.com/forums/show...ht=gas+station
i think this is the issue from similar circumstances. Please pass on any info if you have any. issue from 2013 models but fixed in later 2013 and beyond... thanks |
#10 |
Wes
Mine always clicks after a few seconds, sometimes it clicks a second time and then I fill up no problem. I usually just move the gas pump out a bit
Instagram: @gt86ws
#11 |
Drives: Halo 860
I've encountered this issue with a Cooper S, I think it had something to do with the evap system maybe? Instead of just fully inserting the nozzle you had to back it out slightly or the auto shutoff would just engage constantly.
| FR-S takes 3rd at Targa Newfoundland | DarkSunrise | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 06-11-2015 12:02 PM |
| Takes a certain person | Joeycokeboy | Scion FR-S / Toyota 86 GT86 General Forum | 61 | 04-12-2015 07:43 PM |
| Brakes feel 'stiffer' than usual after pumping | 1Cor10:23 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 3 | 04-14-2014 02:57 PM |
| Brake travel reduced after pumping | 1Cor10:23 | Issues | Warranty | Recalls / TSB | 0 | 04-14-2014 10:12 AM |
| Windshield Fluid not pumping | taimysho0 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 9 | 06-12-2013 01:02 PM |
