Old 05-31-2013, 02:58 PM   #1
taimysho0
Drives: frs
Windshield Fluid not pumping
anyone have this problem? i see the tank for the fluid is full but when i pull the lever in on the steering column, i dont hear anything and nothing happens..
taimysho0 is offline   Reply With Quote
Old 05-31-2013, 03:10 PM   #2
RallySport Direct
RallySport Direct's Avatar
Drives: 2014 Widebody Cosworth FR-S
I would check the motor itself and the wiring, the motor is located at the bottom of the reservoir in the driver side area behind the front bumper. You can usually access it by removing the plastic clips holding the plastic fender liner in. Or just take it to the dealership if you do not want to have to deal with it
Thanks,
Rick
RallySport Direct is offline   Reply With Quote
Old 05-31-2013, 03:51 PM   #3
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Have someone pull the lever while you listen under the hood. If you hear the pump, check the lines for leaks.
Old 05-31-2013, 03:57 PM   #4
Calum
That Guy
Drives: 2013 asphalt FRS MT
And/or crimping.
Old 05-31-2013, 04:26 PM   #5
OrbitalEllipses
Drives: Attitude
Would be a good time to check blinker fluid and exhaust bearings.
Old 05-31-2013, 04:32 PM   #6
IloveBaldEagles
IloveBaldEagles's Avatar
Drives: Gray.
The fluid line might be crushed somewhere under the hood.
Old 05-31-2013, 09:58 PM   #7
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
I would definitely start checking these ^^
Old 05-31-2013, 10:42 PM   #8
BRZnut
Drives: BRZ DGM Limited
make sure the car is on too when you test it.
Old 06-11-2013, 09:43 PM   #9
Razz
Razz's Avatar
Drives: Fast
Just keep pushing it.
Sometimes you have to prime the pump.
Usually you can use a pin or fine wire to punch through the hole where the fluid comes out to clear it.
But first you have to determine if the head is clogged.
But why should I go into more detail?
Why?
It's under warranty.
Take it to the dealer.
Razz is offline   Reply With Quote
Old 06-12-2013, 12:02 PM   #10
taimysho0
Drives: frs
thanks everyone for their help. the issue was this^ looks like the line was disconnected...
Windshield chip Mr.Corvus Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 14 06-20-2013 07:52 PM
Windshield Protection... Skurj Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 6 02-27-2013 11:30 PM
windshield replacement ravenblackfrs Cosmetic Modification (Interior/Exterior/Lighting) 28 02-17-2013 03:08 AM
Windshield IloveBaldEagles Mid-Atlantic 3 12-05-2012 01:19 AM
New windshield cost? JimmyMac Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 21 11-05-2012 12:04 AM
