#29 | |
Drives: Q5 + BRZ + M796
It could be a bad switch, or it could be the real deal. Maybe your oil is getting too hot.
| The Following User Says Thank You to Irace86.2.0 For This Useful Post: | kev0 (02-21-2020) |
#30 | |
Drives: '14
#31 | |
Drives: '14
#32 | |
But you know what? I kind of disagree on the aesthetics argument too... that interior. Gauges do not a good interior make. ![]() Then again, sometimes it does work out and looks great. Maybe oil pressure gauges do make good aesthetics... ![]() ![]() ![]()
#33 | |
Gauges look groovy, but as stated, when your balls to the wall mid corner, the last thing your going to look at is your gauges. BUT, a big red light high up on your dash is something even the most possessed driver will see. 15-50 psi http://www.longacreracing.com/produc...e-1%2f8%22-NPT The one I had in my Skyline worked a treat, once I painted it black, leaving only the small circle of red in the middle of the light, at idle the light stays on, mine was set to 30 psi IIRC, the time it did go off, mid corner at Wakefield Park, was when the RB spewed all of it's oil out of the head, into the catch can and finally onto the track. The engine was saved miraculously, and I proceed to thrash it's guts after cleaning up, working out that I was an idiot, then refilling the oil. It turned out the drain back line to the sump from the catch can had kinked after I took it out to clean the internal filter (stainless steel pot scrubbers) with some metho. TL;DR bright light
http://www.ft86club.com/forums/showthread.php?t=133311 I'm only here for the biscuits |
#34 | |
How do you believe oil weight should be determined? Is too much pressure a bad thing? |
#35 | |
#36 | |
In the case of a turbo car, if you have a relatively minor boost leak, your boost gauge wouldn't show it, because your turbo will only work harder to make up for it. |
#37 | |
| The Following 2 Users Say Thank You to CSG Mike For This Useful Post: | Icecreamtruk (02-21-2020), tomm.brz (02-21-2020) |
#38 | |
Drives: brz 2017 hksv2
i have gauges, but only because I also feed their output up to the ecu and use them actively, otherwise... esthetic |
#39 |
Gauges make us all feel like we are fighter pilots..
Sent from my Pixel 3a using Tapatalk |
#41 |
Rust bucket enthusiast
#42 | |||
Too little pressure is a bad thing. Again, I know your opinion on heavier weight oil. I don't feel another debate is necessary here. I see. I just assumed you didn't check them often while driving hard because of your question here: Quote:
https://www.usatoday.com/story/sport...ents/80341170/ ![]() ![]() ![]() ![]() ![]()
| FS: JDL UEL turbo kit V2 and supporting mods | 20061216 | Canada Classifieds | 4 | 12-18-2018 11:05 AM |
| UPDATED: JDL V2 UEL turbo kit with other supporting mods | 20061216 | Engine, Exhaust, Bolt-Ons | 2 | 11-28-2018 11:45 AM |
| WTB Turbo and supporting mods | OzzyGT86 | Want-To-Buy Requests | 2 | 08-26-2017 06:14 PM |
| FS: fa20club turbo kit plus supporting mods | sid3way5 | NY / NJ / CT / PA | 1 | 06-17-2014 09:28 PM |
| turbo kit supporting mods | lbroskee | Forced Induction | 13 | 03-30-2013 08:56 PM |
