Old 01-02-2020, 02:17 AM   #1
JackRabbit
Drives: '19 Toyota 86, MT, Asphalt
BRZ wheel bearings same as 86?
I need replacement bearings (hub/bearing assy) for both front wheels on my '19 86. The dealer quote was insane, so I took my car to a BRZ specialist shop who says they deal with FRS's all the time too, and they told me they can get me Subaru wheel bearings for a much better price. The guy told me they are the same bearings in both cars, or at least totally compatible, but I'm curious what you all know about that?
JackRabbit is offline   Reply With Quote
Old 01-02-2020, 06:34 AM   #2
ZionsWrath
Thanks
ZionsWrath's Avatar
Same
Old 01-02-2020, 09:07 AM   #3
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Nope
Just kidding same exact car parts.
Old 01-02-2020, 09:34 AM   #4
ZDan
ZDan's Avatar
Drives: '23 BRZ
Should be covered under warranty.
Front wheel bearings were warranteed on my '17
Stomachbuzz (01-03-2020)
Old 01-02-2020, 11:03 AM   #5
toast
Drives: 14 BSP Edelbrock BRZ
What do you do with your car that a '19 needs new wheel bearings?
toast is offline   Reply With Quote
The Following 4 Users Say Thank You to toast For This Useful Post:
soundman98 (01-03-2020), Stomachbuzz (01-03-2020), Tristor (01-06-2020), wparsons (01-06-2020)
Old 01-02-2020, 11:10 AM   #6
Let me guess -
soundman98 (01-03-2020), Tristor (01-06-2020)
Old 01-03-2020, 12:07 AM   #7
JackRabbit
Let me guess -
Not THAT far off the road...
The Following User Says Thank You to JackRabbit For This Useful Post:
humfrz (01-03-2020)
Old 01-03-2020, 12:09 AM   #8
JackRabbit
"pothole damage" (drove over a curb) isn't covered.
humfrz (01-03-2020)
Old 01-03-2020, 12:54 AM   #9
don't do that no more!
Reminds me of a dark, rainy night, back in California, when I left a lady friends party, after "a few beers" - in my new MGB-GT. I discovered I was going the wrong direction, so I quickly pulled into a large, empty, parking lot - trouble was that where I pulled in, wasn't an entrance nor an exit -
The Following 3 Users Say Thank You to humfrz For This Useful Post:
Alpha86 (01-03-2020), Tristor (01-06-2020), wparsons (01-06-2020)
Old 01-06-2020, 11:24 AM   #10
wparsons
wparsons's Avatar
If you hit hard enough to ruin the bearings, I'd be worried about other parts being broken too. Wheels would be toast, shocks might be damaged, I'd also check the strut towers and subframe for possible bends.
flickr
The Following 5 Users Say Thank You to wparsons For This Useful Post:
humfrz (01-06-2020), NoHaveMSG (01-06-2020), RToyo86 (01-06-2020), soundman98 (01-06-2020), Tristor (01-06-2020)
Old 01-06-2020, 02:37 PM   #11
JackRabbit
Thanks, yeah, I had it checked out by the dealer and another shop, and the only damage is one bent wheel and bad bearings. It wasn't too bad, the bearings aren't destroyed, they are just making a light humming noise at freeway speed. The BRZ shop I took it to says if I replace the bearings and wheel then I should be good to go.
Still kicking myself over it. One second of too much throttle and I'm now over 2 months and $1k in the hole and it still isn't fixed. Every day I worry that more things are slightly damaged than the shops found and it will never be as good as stock again. Seriously hard to let go of the frustration. I wonder if I'll ever have peace of mind that it's fully fixed.
Old 01-06-2020, 02:52 PM   #12
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
If it is helps to know I have had the inside tires of my car airborne on many occasions with no issues
The main part I think would take the brunt of that would be the brace that goes from the rear of the lower control arm to the frame. It is just stamped sheet metal, though it is fairly thick for what it is.
NoHaveMSG is online now   Reply With Quote
[HELP] Rear Wheel Bearings VITA Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 18 10-14-2019 02:58 AM
Wheel bearings gone bad rustymuffler Issues | Warranty | Recalls / TSB 25 05-02-2019 12:21 PM
Performance wheel bearings MassTroy Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 03-24-2018 01:03 PM
Oem rear wheel bearings+oem inner tie rods Integramike94 Brakes, Suspension, Chassis 7 09-25-2016 06:48 PM
Wheel bearings sealed? Grease? swarb Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 2 06-10-2016 11:08 AM
