Old 10-30-2019, 10:49 AM   #1
Masacur
Drives: Toyota MR2
Oneven Tire wear
Hi,
I noticed today that my front tires are oneven worn. Inside is much more worn than outside.
Rears are OK.
https://imgur.com/a/Ha6WRSo
Is it something I can adjust myself?
I am on HKS Hypermax IV coilovers.
Or should I get an alignment when I put new tires?
Thanks!
Masacur is offline   Reply With Quote
Old 10-30-2019, 11:01 AM   #2
Vital
Drives: 2015 BRZ
Originally Posted by Masacur View Post
Hi,
Rears are OK.
Thanks!
Did you ever get an alignment after installing your coilovers? Yes get an alignment ASAP. Also make sure the tire pressures are set at the correct psi
Old 10-30-2019, 11:15 AM   #3
Masacur
Drives: Toyota MR2
I bought my car with the coilovers installed.
I just changed the wheels including new tires.
Old 10-30-2019, 11:25 AM   #4
Vital
Drives: 2015 BRZ
Ah i see. Well you dont typically need to get an alignment whenever you get new tires. Since you are getting tire wear like that i'd start with the alignment so you dont wear out your new tires too.
Old 10-30-2019, 11:32 AM   #5
SmartedPanda
SmartedPanda's Avatar
Drives: SWP BRZ Limited Manual. 2014
Especially with a coilover set you didn't setup and align.
Until you find an appointment try maybe rotation your tires front to back if possible? See if the wear is starting on the "new" sets from the back.
[| Blox 490 Knob | Mishimoto Silicon Intake | K&N Filter | DD Always-On DRL | Tomei 60S | Weather Tech | RED USDM TOM's Tail Lights | OEM Underbody Panels | Intec High Mount Brake | RexSpeed Heated Wide Mirrors | TC105N 17x9 | Super Sport 245/40R17 |TRD Quickshifter | Porsche Brake Air Duct | TRD Sliding Armrest| OEM Knee Pads | MTEC Shifter Springs| WRX OEM Oil Cooler| Generic PVC Catch Can|]
SmartedPanda is offline   Reply With Quote
The Following User Says Thank You to SmartedPanda For This Useful Post:
Vital (10-30-2019)
Old 10-30-2019, 11:37 AM   #6
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
Check alignment and tire pressure.
Current DD: M235i
8RZ is offline   Reply With Quote
The Following 4 Users Say Thank You to 8RZ For This Useful Post:
i8ur911 (10-30-2019), Racecomp Engineering (10-30-2019), SmartedPanda (10-31-2019), wparsons (11-01-2019)
Old 10-30-2019, 12:33 PM   #7
xdavidx
Emperor McDuck
xdavidx's Avatar
Drives: 2019 86 GT; 2018 BMW S1000RR
Hi,
Rears are OK.
Thanks!
You won't ever get alignment correct yourself. I'd recommend finding an alignment shop that deals with lowered cars also. Standard shops may just put you to factory spec, but good alignment with coilovers can sometimes be more involved or require additional parts for adjustment.
Instagram: @s1kmotodragon
YouTube: S1KMotoDragon
xdavidx is offline   Reply With Quote
Old 10-30-2019, 12:55 PM   #8
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
You are going to want less negative camber and 0 toe. In case you wanted some search terms as to what is happening and how an alignment could help. Good luck.
Old 10-30-2019, 04:56 PM   #9
Tristor
Tristor's Avatar
Get an alignment
Tristor is offline   Reply With Quote
Old 10-30-2019, 05:36 PM   #10
JD001
JD001's Avatar
Drives: Subaru BRZ
Wait a minute, isn't 'oneven' better than 'uneven'? Don't we want to be 'oneven'??
Old 10-30-2019, 06:04 PM   #11
DandoX
Senior gif poster
DandoX's Avatar
Drives: 2013 Asphalt FRS
Hi,
Rears are OK.
Thanks!
First I'm gonna give you a forum pro tip, to have an image show up in the forum vs having just a link. In a browser right click the image in the webpage (in this case imgur) and select copy image location. Then click the little icon in the forum that is and delete all the text in that and paste in what you copied and then you got your picture natively visible on the forum.
It looks to be wearing due to camber, now the question is if you intended camber in your set up with plates or what have you. Now this could occur due to the geometry with your wheels/offset and your new suspension. I think a great place to start would be getting a professional alignment, they would likely be able to also clue to in to why it isn't wearing evenly better than we can on this forum without seeing it first hand.
DandoX is offline   Reply With Quote
Old 10-30-2019, 08:23 PM   #12
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
thats toe wear, if it was camber wear it would be more conical
Old 10-30-2019, 11:29 PM   #13
Masacur
Drives: Toyota MR2
I tried it that way before posting but it did not show the picture for me therefore I put a link.
I’ll go and see a wheel alignment shop and change the front tyres.
I’ll probably get more grip on the front with proper aligned setup, right?
Old 10-31-2019, 04:13 AM   #14
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Yep. Alignment is the fix.
Yes it would be more grippy... lol not! If you want grip get better tires. Camber only does a bit. Tires does the rest.
How does my tire wear look? R_E_L Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 09-08-2018 08:34 AM
tire wear oppiee Tracking / Autocross / HPDE / Drifting 9 08-29-2017 01:55 PM
Tire Wear? Flo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 01-10-2017 04:19 PM
Tire Wear Help babykwiss Tracking / Autocross / HPDE / Drifting 10 07-14-2014 12:31 PM
question about tire wear driver01 Tracking / Autocross / HPDE / Drifting 8 08-05-2012 10:50 PM
