Old 10-13-2019, 05:36 PM   #1
mcnvgget
mcnvgget's Avatar
Drives: 2018 Toyota 86
should i be concerned?
rear lines don’t know what they are
mcnvgget is offline   Reply With Quote
Old 10-13-2019, 05:43 PM   #2
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Well, I certainly am.
The Following 5 Users Say Thank You to Spuds For This Useful Post:
arkanist (11-06-2019), JohnJuan (10-15-2019), NWFRS (10-13-2019), p1l0t (10-15-2019), soundman98 (10-16-2019)
Old 10-13-2019, 05:56 PM   #3
extrashaky
Drives: 2014 BRZ Limited
Is that your sway bar? I think I'd be concerned any time a suspension component is damaged.
Old 10-13-2019, 06:01 PM   #4
mcnvgget
mcnvgget's Avatar
no it’s not my sway bar, it’s rubber but i don’t see any fluids coming out of it, they’re shredded on both sides from my wheels being wide, i’ll try to zip tie it away from the wheel i’m not sure what it is tho
Old 10-13-2019, 06:32 PM   #5
I don't know if you should be concerned but I can say with certainty that I am irritated.
Spuds (10-13-2019), Tcoat (10-13-2019)
Old 10-13-2019, 06:50 PM   #6
Spuds
The Dictater
Spuds's Avatar
So, seriously, let's go through the possibilities. Are there coolant lines in the back? Oil lines? Blinker fluid lines? No.
So it's either gas or brake lines. Why would a gas line go into a wheel? It wouldn't. Why would a brake line go into a wheel?
By the power of deduction, it must be a brake line (though possibly the ebrake). I'm always concerned about damage to any brake line.
Old 10-13-2019, 06:54 PM   #7
BEZO760
Drives: Blue 2016 SCION FR-S
Some better angles would help alot with seeing what it is? Maybe Jack up the car and get some pics from underneath? Doesn't look like anything MAJOR but it's definitely something you'd want to find a remedy for asap.
BEZO760 is offline   Reply With Quote
The Following User Says Thank You to BEZO760 For This Useful Post:
Old 10-13-2019, 07:03 PM   #8
86MLR
86MLR's Avatar
Yeap, concerned is a word.
Fix, that's another word you should be using sooner rather than later.
The worn line is for your handbrake cable, remove wheel, bend bracket, test and adjust.
The Following 2 Users Say Thank You to 86MLR For This Useful Post:
soundman98 (10-16-2019), Ultramaroon (10-13-2019)
Old 10-13-2019, 07:52 PM   #9
Oh! Now I see it. Had to turn it upside down.
Old 10-13-2019, 08:16 PM   #10
Impureclient
Drives: 2015 FR-S
How wide are your wheels? From your avatar pic it looks like they are pretty sunken in like stock width. Maybe you just have really wrong offset on those wheels.
Old 10-13-2019, 08:17 PM   #11
mcnvgget
mcnvgget's Avatar
my avatar pic is when i first got my car i haven’t changed it lol my rear wheels are 18x10.5 +22
Old 10-13-2019, 08:18 PM   #12
mcnvgget
mcnvgget's Avatar
once i get some i’ll remove the wheel to fully see what’s going on
Old 11-06-2019, 06:19 PM   #13
Geex
Ebrake line, you can just bend the bracket back. That's what I did.
Geex is offline   Reply With Quote
Old 11-06-2019, 10:12 PM   #14
HaXx
Drives: jrsc_brz
20mm spacers are an option too
HaXx is offline   Reply With Quote
Should I be concerned GotBRZ1691 Engine, Exhaust, Transmission 26 09-17-2014 08:17 PM
Should I be concerned with coolant and oil level? B-R-Z Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 18 01-28-2014 01:03 AM
Concerned with reliability... should I be? hmong337 Scion FR-S / Toyota 86 GT86 General Forum 37 07-01-2013 08:02 AM
wanted white but concerned about paint VENOM~ Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 16 09-05-2012 05:38 PM
