| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#4103 | |
Damn that's crazy...
Drives: 2015 BRZ
#4104 |
Drives: 6MT '15 BRZ | '89 240sx (sold...)
I'm pretty set on Enkei RPF1s, thinking of going 18x8 + 35 on all four wheels. How well will this line up with the front and rear fenders?
Most of the pictures I'm coming across are for 9.5s +35/38...
la cocaina is not good for you ig: sad_fa20 |
#4105 |
Hey guys.. i'm looking at picking up these wheels in
18x9.5 they come in a +35 offset. Stock suspension. Will they fit? Flush look? Will i be able to throw on coilovers down the road and lower it at all? https://esrwheels.com/products/sr01 |
#4106 | |
Drives: 2015 BRZ
#4107 | |
Drives: 2015 BRZ
This thread should help you out. https://www.ft86club.com/forums/show....php?p=3097900. Even though its a +38 offset it close enough to a +35. |
#4108 | |
#4109 |
Drives: 2013 FR-S 10-Series
Location: SJ/OC/IE California; Temporarily: Glendale,AZ
Hello everyone, I am planning to pick up RPF1's in SBC in 17x9 +35 as that is the narrowest width they have in a 17" size.
I would like to keep the tire width as narrow as possible as I understand my car is quite under powered. I am thinking 235/45/17 or 235/40/17 or 245/40/17. I am unsure how the choices will affect the performance of the car, and I do know that the 235/45/17 will result in a the car sitting higher / more ground clearance. Based on my understanding, a tire with a taller sidewall does not perform as well as a tire with a shorter sidewall in a motorsport setting. I am unsure what the pros and cons are of having a taller vs shorter sidewall. Does anyone have any insight on this? |
#4110 |
Drives: FR-S 10 Series
I have done so much research and I'm still confused on something... will this combo rub on stock suspension?
18x8.5 +45 wheels with 245/35/18 tires? |
#4111 |
Drives: 2015 BRZ
#4112 |
#4113 | |
Country Boy 4 Life
245/35 will be square looking on the 8.5" wheel. I'm running 245/35 on 9" wide wheels and they are slightly stretched.
I LIKE TIRES! |
#4114 |
Drives: Red 86
So as turned out where I live 245/40R17 are the most rare size tiers ever.
Does anyone know if I can fit 235/45R17 on stock car with Eibach pro kit lowering springs and front camber bolts? My wheels are 17×9 +38. Sent from my SM-G975F using Tapatalk |
#4115 |
Drives: 2015 BRZ
You can try ordering them from tirerack.com. Yes, 235/45/17 will fit fine with Pro-Kit and those wheels. You'll actually get a little more clearance and gain more camber since the 235/45 tire wont be as wide as the 245/40.
#4116 | |
Drives: Red 86
As long as the 235/45R17 will be good and won't fuck up the gearing much I guess I'll go with it. Thanks. Sent from my SM-G975F using Tapatalk |
| Tags |
| fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width |
| Determining the proper width size of the tire | CyberFormula | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 49 | 05-23-2014 09:11 AM |
| Correct tire width for each wheel width | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 08-16-2012 02:03 PM |
| TIRE SIZE CALCULATOR | White64Goat | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 08-15-2012 02:31 AM |
| Tire Width vs Wheel Width | Synack | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 40 | 08-12-2012 11:21 PM |
