Old 09-01-2019, 10:02 PM   #1
thinkV
Drives: BRZ Turbo
Complete power out after stall, came back in about 5 mins?
Hi everyone,
Had something really strange happen on the weekend. I was creeping through a slow area/gateed entrance and accidentally stalled, but as soon as it turned off, it went completely off.
Everything was off, like the battery had been disconnected. I checked all the terminal fuses, and everything was okay. After about 4-5minutes it just came back on and I was able to start the car again.
The dashboard and radio had reset like the battery was disconnected.
Has anybody experienced this and what might have caused it?
thinkV is offline   Reply With Quote
Old 09-02-2019, 12:34 AM   #2
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Auto or manual trans?
Well, if it's been a few years usually 3-4 year an oem battery might be on its way out.
Or... check the terminals for excessive corrosion and or loose clamp.
The Following User Says Thank You to Mr.ac For This Useful Post:
humfrz (09-02-2019)
Old 09-02-2019, 02:48 AM   #3
soundman98
ProCrastinationConsultant
soundman98's Avatar
EMP. You entered a restricted zone.
Ultramaroon (09-02-2019)
Old 09-02-2019, 02:57 AM   #4
thinkV
Drives: BRZ Turbo
My terminals are pretty poop, but I didn't realise it could cause something like that. I'll look into a new battery too.
Honestly it felt like that haha.
Old 09-02-2019, 03:06 AM   #5
soundman98
soundman98's Avatar
It would be a good idea to clean an tighten your terminals then.
These kits are a little gimmicky, but they do seem to work. I put one on every one of my cars, haven't had a green sea monster in quite a while.
https://shop.advanceautoparts.com/p/...inal+protector
Old 09-02-2019, 03:58 PM   #6
That joint between the lead terminal and the plastic housing is the weakest part of the battery. Because lead is so soft, it takes very little torque to crack the seal. Once it starts leaking, the only cure is a new battery.
It's all in how the terminals are handled when installing or removing the leads. Don't over-tighten, and always support the lead while torquing the fastener.
Also, when purchasing a new battery, avoid those that show even the slightest hint of weeping around the terminals. They're already goners.
DIY - Easy clutch grab adjustment (~10 mins) Koji_Online DIY (Do-It-Yourself) Guides 745 11-09-2022 01:44 AM
Complete Power Folding Mirror Changeover ChrisJ Exterior Parts (Aero, Lighting, Etc.) 4 05-09-2020 10:09 AM
Low idle/dip and stall/loss of power GoZ21 Issues | Warranty | Recalls / TSB 5 12-08-2017 07:50 AM
Loss of power/stall under light throttle. Model Citizen Forced Induction 49 10-21-2014 09:50 AM
