Old 08-30-2019, 01:29 PM   #15
Originally Posted by Butterballz View Post
Jeez rough morning? Obviously I’m not saying OCD in that manner but anyways. I don’t know how my car started. Maybe the hanging ground bracket was touching the chassis. Are you implying I was imagining the ground bracket wasn’t bolted?
Not a rough morning. My son has REAL OCD and it is a pet peeve of mine when so many people misuse the term.
The first question was just that, a question, and was not meant to imply anything. There is no way the car should start without the main ground hooked up.
Old 08-30-2019, 04:27 PM   #16
Butterballz
Drives: Black FRS
It's the wire in the second circle from the top. The bracket with the wire was hanging not bolted to the starter/transmission. Is it important?
Butterballz is offline   Reply With Quote
Old 08-30-2019, 05:28 PM   #17
Grady
Grady's Avatar
Yes it is important.
I do not remember but my guess is the battery is bonded to the chassis and then to the engine. This means you had high current going from the cassis to the engine thru a lot of little wires/lines. Not a good thing but your car must have survived it.
Yes Tcoat is right if the battery ground was not hooked up nothing would happen!
Old 08-30-2019, 10:42 PM   #18
alan.chalkley
Drives: 4wd zooks
Yes , the "talented technicians" and loose bolts.
My experience was loose tail shaft bolts after a new clutch install on a v8 commodore.The dealer said that the tail shaft was not touched and i had to buy new bolts and install them myself.
How does a clutch get replaced without removing the tail shaft?
The second was loose bolts on a torque converter when an auto transmission was replaced on my old ford, the mechanic admitted he stuffed up and fixed it for free.
Now if anyone works on my cars i double check for loose bolts myself.
alan.chalkley is offline   Reply With Quote
Old 10-08-2019, 10:01 PM   #19
curtdragon
Drives: Acura TSX
Do you have this photo not on photobucket? They are being jerks with their pics lol... I think this was missed on my car too
curtdragon is offline   Reply With Quote
Old 10-09-2019, 01:56 AM   #20
Butterballz
Drives: Black FRS
It's the second red circle. It's on the passenger side bellhousing. It bolts on the bottom starter bolt. You can reach the wire from the engine bay. Just follow the one from the positive terminal down the area.
The Following User Says Thank You to Butterballz For This Useful Post:
Mic7796 (10-09-2019)
Old 10-09-2019, 08:11 PM   #21
curtdragon
Drives: Acura TSX
Sweet thanks!
Old 10-09-2019, 10:33 PM   #22
Impureclient
Drives: 2015 FR-S
What is with Photobucket blurring their pics... And for that matter why not just use Imgur since they don't block and now blur the pics hosted on there.
Nevermind, just looked it up. Now they blur so you have to go to their site which has ads. Still would use Imgur since they never have played games like that.
The Following User Says Thank You to Impureclient For This Useful Post:
Old 06-18-2025, 10:05 PM   #23
FRSToyota86
FRSToyota86's Avatar
Drives: 2013 Scion FRS
I am so mad, i forgot about that ground myself and I need to redo it.....grrrrrrrrrrrrrrr
Vortech V3 Supercharger| 12 PSI|E85 MotoEast Flexfuel kit|Crawford AOS| Mishimoto Oil Cooler|3"Perrin Resonated CBE| 3" JDL Front/Over Pipe|OpenFlash Performance Headers|Exedy Stage 2 Ceramic Clutch |Yonaka Coilovers|17x9 O.Z. Wheels| 245/40r/17|TRD Brake Pads|Perrin Master Cylinder Brace |ChaseBay SSBrake Lines|CF Side Fins|OEM Shark Fin Athena|Yospeed Console Plaque|R/T Shift Knob|Fog Lights|Backup Camera|Navigation| |TRD Quickshifter|Motul Gear Oil|
FRSToyota86 is offline   Reply With Quote
Adjustable Coilovers - Loose Shock Assembly and Spring Unloading EndlessAzure Issues | Warranty | Recalls / TSB 14 09-27-2017 10:23 AM
Broken Assembly Bolt VIP BRZ Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 04-18-2016 11:02 PM
Rust on bolt on headlight assembly slicktop Cosmetic Modification (Interior/Exterior/Lighting) 0 12-13-2013 10:11 AM
Camshaft Bolt Coming Loose After Perrin Pulley Install WhiteBRZ Engine, Exhaust, Transmission 25 09-20-2012 09:07 AM
