Old 08-23-2019, 07:56 PM   #1
tofux86
Drives: 2013 scion fr-s ultramarine blue
hubcentric ring size problem
i recently purchase a new set of rings as my aluminum one are wearing off.
the problem i have is that the plastic ones are stupid thick compare to the ones i have ... can't seem to find the ones with the right size..
any help on where to purchase the aluminum ...
thanks.
tofux86 is offline   Reply With Quote
Old 08-25-2019, 11:45 PM   #2
Impureclient
Drives: 2015 FR-S
This is assuming you need 73.1 to 56.1 below. Most aftermarket are 73.1mm.
Plastic: https://www.amazon.com/Circuit-Perfo.../dp/B01JN0N3ME
Aluminum: https://www.amazon.com/Circuit-Perfo...52WT8DW8CQ1SYS
Also, "wearing off"? I have a set that's been on a car for almost 20 years. Make sure you are tightening to the 89 ft/lb when putting it back on. Thinking about it, maybe you actually had the wrong size on there to begin with. What wheels do you have on there? The only way they should wear is if the lugs aren't fully tightened and those rings are too small to center the wheel on the hub correctly.
Old 08-28-2019, 08:41 PM   #3
tofux86
the plastic ones are 73 to 56. and the same for the aluminum. i ran rpf1 and 57cr with those aluminum hub rings and the fit perfectly. but when i try to put the plastic one its too thick to fit into the hub of the rims.
Old 08-28-2019, 11:19 PM   #4
wparsons
wparsons's Avatar
There's no way both of those are the same size... the plastic ones are definitely the wrong size.
flickr
Old 08-29-2019, 01:22 AM   #5
churchx
churchx's Avatar
Drives: 2014 GT86
+1. They look of different size. And if they were sold as supposedly being same sized, i'd measure real size of bought rings and complain to seller.
Old 08-29-2019, 12:26 PM   #6
Impureclient
Drives: 2015 FR-S
Your plastic one looks like it's correct, the aluminum one that you said fit looks wrong. Here is a 73.1 to 56.1 in both aluminum and plastic. Your aluminum one looks off, it doesn't match the size of these two and they are for sure the right size.
The Following User Says Thank You to Impureclient For This Useful Post:
timurrrr (08-29-2019)
Old 08-29-2019, 02:41 PM   #7
CSG Mike
CSG Mike's Avatar
CSG sell them. Both 73-56 and 65-56.
wparsons (08-29-2019)
Old 08-29-2019, 03:04 PM   #8
asdf
Loading...████████] 99%
asdf's Avatar
Drives: #0517
if the aluminum ring fits perfectly-- what do you mean when you say that it's wearing out? were they damaged somehow?
may want to double check what size hub bore your wheels actually are as it does not sound like they are 73
R1 3 5
. 2 4 6
asdf is offline   Reply With Quote
The Following User Says Thank You to asdf For This Useful Post:
Old 09-16-2019, 02:12 PM   #9
Will BRZ
Damn that's crazy...
Drives: 2015 BRZ
I'm ordering wheels with a hub bore of 73mm. Now just need lug nuts and rings. Seems like hub centric rings are more common in the 73.1 size and I'm sure that .1 makes a difference. Should I go with something like this: https://www.amazon.com/NB-AERO-Alumi...%2C168&sr=8-15
or are the ones from CSG at $10 a pop worth it? Any links to other recommended rings? Kinda dumb, but this is my first set of aftermarket wheels. Thanks everyone.
Will BRZ is offline   Reply With Quote
Old 09-16-2019, 02:23 PM   #10
Icecreamtruk
Drives: Track preped NA FRS
Just dont put hub centric rings, unless your wheels have a flat bolt face (which I cant remember how many years ago was the last time I saw that) you dont need them. Its a waste of money and time.
Icecreamtruk is offline   Reply With Quote
The Following 2 Users Say Thank You to Icecreamtruk For This Useful Post:
Will BRZ (09-16-2019), wparsons (09-17-2019)
Old 09-17-2019, 02:10 AM   #11
Will BRZ
Drives: 2015 BRZ
Thanks. I’ve just heard of people having vibrations or something after installing certain aftermarket wheels. I’ll just throw them on and if I’m having issues then it’s just like a $10 fix
MAF sensor o-ring size SPCorBUST Engine, Exhaust, Transmission 10 08-15-2023 03:35 PM
Hubcentric Rings ry_zillafrs Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 10-31-2016 12:09 AM
Hubcentric rings all_aboard Scion FR-S / Toyota 86 GT86 General Forum 10 08-07-2014 11:42 PM
Omni 3-Bar Map Sensor O-Ring Size? xjohnx Forced Induction 0 10-02-2013 11:29 AM
Size of Centric Hub Ring wheel? Akired86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 10-08-2012 12:19 AM
