Old 06-29-2018, 05:13 PM   #1
SPCorBUST
SPCorBUST's Avatar
MAF sensor o-ring size
Does anybody know the size of the MAF sensor's o-ring? I can't seem to find it and none of the ones at Autozone seem to fit. Would really hate to buy a new MAF sensor for a rubber seal if I can avoid it, its like $230.
Hoping to pick one up at Home Depot, Lowe's, or someplace similar.
SPCorBUST is offline   Reply With Quote
Old 06-29-2018, 05:27 PM   #2
H2.00 x 22
Buna Nitrile.
Old 08-27-2018, 02:21 PM   #3
1Cor10:23
1Cor10:23's Avatar
H2.00 x 22
Buna Nitrile.
Sorry for my lack of understanding, what does the H stand for?
Having a hard time finding this, there are quite a few 22x2.5 on Amazon.
Old 08-27-2018, 05:20 PM   #4
Part number
Anything that fits the specs will work.
Buna-Nitrile
22 mm ID
26 mm OD
2 mm Width
Old 08-28-2018, 08:54 AM   #5
Trueweltall
Trueweltall's Avatar
Drives: 2016 Subaru BRZ
https://www.amazon.com/dp/B005RUR0F6/ref=biss_dp_t_asn
Trueweltall is offline   Reply With Quote
Old 09-12-2018, 02:20 PM   #6
1Cor10:23
1Cor10:23's Avatar
Originally Posted by Trueweltall View Post
Just tried some 75A Viton o-rings and they are significantly stiffer than OEM, so much so that I can tell the engine is stumbling when slowing down in neutral gear, suggesting that the MAF is leaking.
@CSG Mike any suggestion for shore rating? Internet says 70Ais most common but not sure what the OE is.
Old 09-12-2018, 03:09 PM   #7
mrg666
pessimistic skeptic
mrg666's Avatar
I would make sure that o-ring stays in place while pushing the MAF sensor. MAF sensor should sit flush. Sometimes the o-ring does not stay in its groove while pushing the MAF sensor in place. You can also rub a dab of grease just to wet the o-ring for sealing it air-tight.
Old 09-12-2018, 03:11 PM   #8
1Cor10:23
1Cor10:23's Avatar
Yup, flush and using grease...
Old 09-12-2018, 03:26 PM   #9
Tape around it to check for a seal.
Still stumbling? u got other issues.
Old 09-13-2018, 10:35 AM   #10
Trueweltall
Did you use an oiled air filter?
Old 08-15-2023, 02:35 PM   #11
dynarun55
dynarun55's Avatar
Drives: 2015 midnight blue limited edition.
Part number
Buna-Nitrile
22 mm ID
26 mm OD
2 mm Width
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
dynarun55 is offline   Reply With Quote
Stock MAF sensor screws size/pattern jonbonazza Engine, Exhaust, Transmission 9 07-23-2020 12:39 PM
Crankshaft position sensor bolt size sfruski Engine, Exhaust, Transmission 0 09-01-2017 11:10 PM
Omni 3-Bar Map Sensor O-Ring Size? xjohnx Forced Induction 0 10-02-2013 10:29 AM
02 Sensor Socket Size? swift996 Engine, Exhaust, Transmission 6 08-19-2013 09:30 PM
Size of Centric Hub Ring wheel? Akired86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 10-07-2012 11:19 PM
