Old 07-19-2012, 10:39 AM   #897
boarder1995
Drives: 2013 Subie BRZ Limited, black, 6MT
Is there a waiting list started for this kit?
1. Baker
2. Boarder1995 (Tim)
3.
Of course this is unofficial as I'm sure there were numerous others already mentioning they were "in line" to purchase.
boarder1995 is offline   Reply With Quote
Old 07-19-2012, 11:10 AM   #898
muddog7898
Drives: 2012 Ford Focus SE
So how much have you, Don@Accelerated, spent so far, time and money wise on building this?
muddog7898 is offline   Reply With Quote
Old 07-19-2012, 11:14 AM   #899
mastertech86
mastertech86's Avatar
Drives: 2009 scion tc turbo
im curious on driving impressions cause from what im seeing on the dyno graph the car seems lifeless below 4500rpm...
mastertech86 is offline   Reply With Quote
Old 07-19-2012, 11:18 AM   #900
Chewie4299
Spaceman
Chewie4299's Avatar
Drives: 2013 Firestorm Scion FR-S
Lifeless? The car is pretty peppy down low in stock form (below the dip) and in that dyno both torque and HP numbers are above stock levels as of 3-3.5k and that's right where I am during daily driving.
Sent from my Galaxy Nexus using Tapatalk 2
Chewie4299 is offline   Reply With Quote
Old 07-19-2012, 11:20 AM   #901
blackfireball5
blackfireball5's Avatar
Drives: Scion FRS Firestorm
Originally Posted by CozmoNz View Post
Anyway we can have all the information from this built thrown onto page 1 of this thread?
Sifting through 41 pages to find the goods is a bit of a task for new ppls!
Maybe Don can update the initial post with all the information about it when he gets some sleep and a beer. :happy0180:
blackfireball5 is offline   Reply With Quote
The Following User Says Thank You to blackfireball5 For This Useful Post:
CozmoNz (07-19-2012)
Old 07-19-2012, 11:21 AM   #902
blackfireball5
Don, i know it may be very early in the process to tell, but i figure you have past experiences also.
What kind of fuel economy changes can you expect from going FI?
Old 07-19-2012, 11:26 AM   #903
Ricepuddin
Get a Bowl
Ricepuddin's Avatar
Drives: 2017 BRZ PP
Originally Posted by zooki View Post
Have you driven the "Twisted Sisters" around Leakey? Awesome roads!
not yet, it's on my to do list during my vacation
Ricepuddin is offline   Reply With Quote
Old 07-19-2012, 11:26 AM   #904
mastertech86
the dark lines are actual and the faded lines are baseline...the faded lines are higher than the darker lines below 5500RPM...
Old 07-19-2012, 11:27 AM   #905
Gen
Drives: Scion FR-S
It will be worse.
Gen is offline   Reply With Quote
Old 07-19-2012, 11:30 AM   #906
cobrabyte
cobrabyte's Avatar
Drives: 2013 BRZ, 2002 WRX
the dark lines are actual and the faded lines are baseline...the faded lines are higher than the darker lines below 4500RPM...
Whaa? There are two runs. The blue run and the red run. Look at the legend in the top-left corner. You're getting stuff mixed-up.
cobrabyte is offline   Reply With Quote
Old 07-19-2012, 11:33 AM   #907
Supermassive
Supermassive's Avatar
First post here.
Just gotta say congrats to you guys for working on this kit, and making it require minimal modification of the car itself. I do however have a few questions since its been forever since I have built an FI car (had a 98 Supra...in '99) so I feel a little ignorant and probably backwards as far as some of the things that were common place back then.
With a turbo setup like this with the electric oil pump is a turbo timer recommended to prolong the turbo life or is it not necessary?
Would this setup benefit from a lightened flywheel/clutch pack? I notice that if you rev the car hard that it over revs when you let off the throttle and was wondering if thats a byproduct of the electronics controlling the throttle or if the flywheel/clutch are the culprits...basically since this turbo kit produces power to redline it runs a greater risk of over revving into the rev limiter if you decide to shift at redline versus shifting earlier (stock power output declines before 7k rpm) if it is the flywheel/clutch.
Once you have figure out the boost/power maximums on the stock engine with all parts stock, will you please do a test with this setup with a full aftermarket exhaust, just so those of us who will be running such a setup have an idea of how much of a gain we can get without cats and with less restrictive pipes we can get? At least before you guys go full bore and build the monster we all want to see
I'm sorry if i come off as out of touch, but in reality I am. This is the first car I've owned in 12 years...during my drought I've owned 3 trucks and my main hobby has been my motorcycles...I just bought a 2012 Aprilia RSV4-R and getting that ready for track duty has been my focus, now its the FR-S's turn
Supermassive is offline   Reply With Quote
The Following User Says Thank You to Supermassive For This Useful Post:
blackfireball5 (07-19-2012)
Old 07-19-2012, 11:44 AM   #908
mastertech86
thanks for clearing that up for me i feel relieved now =) =) =) still waiting forv driving impressions and in car camera runs!!! =D
Old 07-19-2012, 11:48 AM   #909
3MI Racing
Pro Subie Engine Nerd
3MI Racing's Avatar
Drives: empty spot for an FR-S/BRZ
Originally Posted by Baker View Post
People said that the compression ment it could not be turboed....
+52.37 WHP :P id be happy with that
I calculate a 32.43% rear power increase at current....
At fly if in preportion
200*1.3243 = 264.86hp
Not sure of drivtrain calcs.
13.0925 per PSI
6 PSI*13.0925 = 240.05WHP
6 PSI at fly estimate 297HP
That would be a fun set up and is right around the same power/psi and weight that I had in my RWD Impreza L. Had an EJ20 swap and was just running a low boost VF39 for fun in it. Made 220 at 8 psi on our Mustang (stock STi's put down 205-210). It was an absolute blast to drive around!
Don and Visconit, I look forward to seeing results when solutions come up from ecutek for whatever the issue is.
3MI Racing is offline   Reply With Quote
Old 07-19-2012, 11:51 AM   #910
cobrabyte
cobrabyte's Avatar
No worries. Your original post actually scared me a bit because I hadn't seen what you were talking about in the dyno plots. Had to go back and make sure I wasn't crazy.
accelerated performance, brz forum, brz forums, brz turbo, brz turbo kit, fr-s turbo, fr-s turbo kit, frs turbo, frs turbo kit, scion fr-s turbo, scion fr-s turbo kit, scion fr-s turbocharger, scion frs turbo, scion frs turbo kit, scion frs turbocharger, subaru brz forum, subaru brz forums, subaru brz turbo, subaru brz turbo kit, subaru brz turbocharger
Accelerated Performance 2013 BRZ Intake Dyno Testing Video Don@Accelerated Engine, Exhaust, Transmission 109 05-17-2013 12:24 PM
Accelerated Performance 2013 BRZ Exhaust Systems Don@Accelerated Engine, Exhaust, Bolt-Ons 135 09-04-2012 12:24 AM
Accelerated Performance 2013 BRZ/FRS Exhaust Systems Don@Accelerated Engine, Exhaust, Bolt-Ons 24 07-07-2012 08:05 AM
Hello from Accelerated Performance! Don@Accelerated Announcements, Contests, Giveaways 5 07-04-2012 09:14 PM
